Saving Iray skin shader settings for G3/8
RenderPretender
Hello -
If you have a character whose Iray skin shader settings you're really happy with and want to be able to use them across the board or as desired, what is the recommended way to correctly save them as a preset? That is to say, is there a ay to save the settings/values in such a way that they can be applied to other characters as a preset, while still using the other characters' skin textures?
Thank you!
Post edited by RenderPretender on
In the options dialogue, which pops up after the filename dialogue, click the lined button halfway down on the right to get the option menu and use the option to select Values only - that will leave the maps alone. Another way, with a regular presets, is to hold down the cmd(Mac)/ctrl(Win) key when you double-click on the preset and choose the ignore option for Maps.
Thank you very much!
