Can you split full body morphs into head and body morphs?
Hello,
I have recently purchased the Werwulf characters from RawArt and discovered that they come as full body morphs. Is there a way to split them into head and body morphs? I would like to tone down the body a bit but keep the head at 100%.
Thanks for any repiles.
nabob21
  • There are ways, but most of them involve quite a bit of fiddling and none of them work on HD morphs. The Werwulf morphs are HD, so that's an immediate roadblock. In any event, I think it would be very hard to smoothly bridge between the morphed and unmorphed sections if they could be split - which is of coruse a good reason to suply the shapes as full-body morphs.
  • nabob21nabob21 Posts: 1,058
    Thanks Richard, I thought that might be the case. It is too bad that we don't have a version of the Creature Creator morphs for G8. That way I could reduce the body morph a bit and use the creature creator head morphs to get closer to the head that I want.
    nabob21
  • FSMCDesignsFSMCDesigns Posts: 12,855
    This product can do it, but as noted, the hD morphs can't be slpit, but for what you are trying to do, this might just be the ticket.
    https://www.daz3d.com/shape-splitter
  • lilweeplilweep Posts: 2,836
    edited October 2019
    nabob21
    As FSMCDesigns mentioned, Shape Splitter product can be used to some extent.  You can't split the HD details so they will always show up but you can "dial out" morphs with negative values and dial in other morphs.
    There is a big thread on this topic.  https://www.daz3d.com/forums/discussion/248176/shape-splitter-divide-combine-and-save-released-commercial#latest
    Post edited by lilweep on
