Fang Freebie for Genesis 8 Female
Ghosty12Ghosty12 Posts: 1,979
edited October 2019 in Freebies
In time for Halloween here is a set of fangs for Genesis 8 Female.. The reason I made these was the ones I had seen for Genesis 8 did not look right, so after many trials and errors and agravation.. I made these in Hexagon as a morph and they came out pretty well..
Be aware that on some G8F characters the teeth may come out weird, not sure why be a case of who knows..  Anyway hope you enjoy these and as far as I can tell no other morphs have crept their way into this teeth morph..
Drop them into your \data\DAZ 3D\Genesis 8\Female\Morphs\leith_p\G8 Fangs directory and you should be good to go..
Fixed my mistake on where to install the morph.. And have added an extra download link..
https://drive.google.com/open?id=1TOQBkDRQUdYjnBVvIP3L_MNlmzPAlAHw
https://mega.nz/#!8JsHDIYQ!NR3orFU9slUyDBRnZFQWJEqe8KqdH04AbiylhVqNYVw
Post edited by Ghosty12 on
  • Catherine3678abCatherine3678ab Posts: 8,010
    edited October 2019
    Drop them into your \data\DAZ 3D\Genesis 8\Female\Morphs directory and you should be good to go..
    Thank you.
    We were "good to go" after deciphering the file and putting it into its expected folder structure ;-)
    Needed one more folder ...
    1390 x 514 - 108K
    1600 x 832 - 467K
    Post edited by Catherine3678ab on
  • JackyBrownJackyBrown Posts: 579
    edited October 2019
    I did put it here and it works perfectly fine: ..\DAZ 3D\Studio\My Library\data\DAZ 3D\Genesis 8\Female\Morphs\Ghosty12\FangsG8\Fangs G8.dsf
    Thank you very much Ghosty12 for making this also for G8! Have been using your V4-Genesis version in the past too! Both are great!
    Post edited by JackyBrown on
  • I did put it here and it works perfectly fine: ..\DAZ 3D\Studio\My Library\data\DAZ 3D\Genesis 8\Female\Morphs\Ghosty12\FangsG8\Fangs G8.dsf
    Well that's interesting. Learn something everyday. And here I was thinking that we always to use the folders the morphs were made for when all along we could have just been dumping them into one big folder. wow.
  • I'm glad I could help you with that one Catherine3678ab! Where would we be without your G8-G3-T-Pose Clones for Autofit?! Thank you so much for those! And DAZ for allowing you to share them ofcourse!
  • Ghosty12Ghosty12 Posts: 1,979
    Thank you and glad you like them.. smiley Also if you want them a little bit shorter you can dial in .6 to .8% and they will retain their shape..
  • Good work! Thanks :)
  • nabob21nabob21 Posts: 916
    My download crashes everytime I click the link and try to download the zipfile. Can I get it somewwhere else?
    nabob21
    nabob21
    Have added an extra download link..
    Thanks Ghosty12
    nabob21
  • airjoeairjoe Posts: 13
    Thank you. This is great.
