So I use Genesis 2. I found a way to get dforce products to work with Genesis 2. The only problem is that dresses seem to stay parented to the feet even when I tell DS the the clothing is a shirt and use the dforce setting that I purchased from DAZ 3D (drawing a blank on the vendor but there was one fo shirt and skirt and dress, etc.) I am wondering how to unparent a piece of clothing from a body part. I have included a render of the issue post draping. The only way that I have successfully made this look right so far was to hide the feet bones on the dress. Any ideas? I want the skirt to drape Genesis 2 without unnaturally attaching to or seeking out the figure. Thanks for your help.
Try bending the feet down, memorising the pose (Edit>Figure>Memorise>Memorise Figure Pose) and running the simulation - it looks as if there's just a bit of intersection, which the simulation won't free up.
I tried to tilt the feet down and this was the result. It looks like the bottom of the dress is attached to the feet somehow? I am looking to unattach it. Anyone know how to do that?
Yes. But only because it fit that was when I parented it. I am trying to de-bone, unparent, whatever the skirt from the feet. I told DS that it was a shirt and it still parented the feet. Where the legs go, the skirt goes. It is not treating the "feet" of the dress as cloth if that makes sense.
If it is intresecting then it is going to stick - that's why I suggested bending the feet down, to make sure theya re clear of the edges of the dress at the outset (so you need to memorise the bent down pose, assuming you can make one that clears the edge of the skirt and that you are simulating from the memorised pose - which is the default).
You should be able to make such a pose, but the parameters tab under the Display section gives you the option to set specific models or individual bones/selection zones (not sure which is more accurate) to be invisible in the simulation. If you make the shoes invisible in the simulation, as well as the feet and their children, then the dress should no longer interact with them.
Alternatively, another option is any morph on the dress that stops it intersecting the feet - for example, if there's a sway or wind morph, dialling it it in just enough should work. If there are no such morphs, it's entirely possible to make one yourself, which isn't especially difficult with a modeller like Blender or Hexagon.
The option you are looking for is "Visable in Sim"
-DrDrk
Sorry for the typos in the original.
Cool. I will try that. Thanks.
-DrDrk
-DrDrk
Is the dress intersecting the feet in the starting pose (the memorised pose, which is usually the zero pose, by default)?
Also, I am unsure why the feet are even connected, since when I transferred it to G@ i chose "shirt" not "dress."
*G2
What do I do if I cannot make a pose where the dress clears the feet?
This technique works for me all the time.
Thanks to you all. Through your wisdom, experience and patience, I have finally been able to get this right. Mattymanx solution worked this time!
Enjoy,
-DrDrk
