Purging face transfer data?
BobvanBobvan Posts: 2,653
Where is the FT data being held? I would like to try to purge it or remove it completely since I strongly suspect that it is what is causing G8F to beraly load. It takes 10 minutes figure alone and now over 20 so far to merge to a large scene. I never tried FT with G8M and it loads normally.
Post edited by Bobvan on
  • What Face Transfer data? The files that are used by FT are not loaded with the base figure, as far as I know, and it certaily doesn't keep the maps or morphs after a restart (unless you choose to save them, using one of the three free saves or havingb purchased a license).
  • BobvanBobvan Posts: 2,653
    edited September 2019
    I did not but since then I can barely load G8F I have submitted a tickit.  This is on both machines. On another matter I think I figured out the mouse problem I am connecting a cooler pad in USB may be messing things up. I may try purging and do a fersh DS intall this week
