Purging face transfer data?
Bobvan
Where is the FT data being held? I would like to try to purge it or remove it completely since I strongly suspect that it is what is causing G8F to beraly load. It takes 10 minutes figure alone and now over 20 so far to merge to a large scene. I never tried FT with G8M and it loads normally.
Post edited by Bobvan on
What Face Transfer data? The files that are used by FT are not loaded with the base figure, as far as I know, and it certaily doesn't keep the maps or morphs after a restart (unless you choose to save them, using one of the three free saves or havingb purchased a license).
I did not but since then I can barely load G8F I have submitted a tickit. This is on both machines. On another matter I think I figured out the mouse problem I am connecting a cooler pad in USB may be messing things up. I may try purging and do a fersh DS intall this week
