Problem with importing models
Hello
I got problem with importing some of models. the problem is some of mesh parts disappear when I import them into Daz. Does anyone know what the problem is ??
screenshot is attached
  • What is the model from? What format did you use to import?
  • Really ?! No help ?!
  • LeanaLeana Posts: 13,711
    edited September 2019
    Nobody can help you unless you give more details. there’s not enough in your original post to diagnose the problem.
    Richard asked you some questions, start by answering those...
    edit: and for the record, you’re posting to a user-to-user forum, this is not Daz tech support. You can open a support ticket using “help > contact us” in the site top menu.
    Post edited by Leana on
    Oh I just realized my reply isnt sent. I did reply but I dont see it. Thanks for informing me !
    I used .Dae format. But same thing happens for some of .Obj formats I import. Not all the .Obj files though. I always use a specific program to export the posed models into .Obj. but some of the .Obj files get imported correctly while some others dont.
  • Where are the models coming from, though? It may be a consequence of soemthing in the source.
    They're from different websites. The obj files which I mentioned are from Deviantart but the one in screenshot is from Sketchup. Link to the exact page : https://3dwarehouse.sketchup.com/model/593f4e14-36dc-4e54-875c-7439d5bc6a40/The-Mad-Hatter-Johnny-Depp
  • Sketchup exports have in the past been problematic in some cases.
  • FSMCDesignsFSMCDesigns Posts: 12,859
    one thing to check for is the opacity is not turned all the way down. I have imported a few meshes where the opacity/transparency was at 0% thus making the object invisible.
  • one thing to check for is the opacity is not turned all the way down. I have imported a few meshes where the opacity/transparency was at 0% thus making the object invisible.
    No , I already checked them all. But all parts are at max cutout opacity
  • AscaniaAscania Posts: 1,857
    Just checked against C4D. D|S definitely does not import all meshes in that file but damn, this thing is an unholy mess.
