Face Transfer Free not loading
lordofchaos_1
I just upgraded to Daz 4.12 and egarly looked for this new plugin and its free trial, but Window>Pane>Facetranfer is missing.
Looked in the installed Plugins window and it is there, but it says it failed to load/
Any help?
I've got the same issue. Anyone else?
Oh, I'm haveing this issue with the free version of the plug in. I'd like to have this looked into before I dish out the money to buy the program only to find out I've wasted my money because the plugin won't work.
Yeah this is the free one too, it's not loading to try before buying.
I just purchased the PAID version and it is ALSO not working
Same here.
It's not working for me either. On the plugin page it says it failed to load because it wasn't a Daz file or that it was for the wrong version.
Same here too. I don’t even find it among installed plugins. Windows 7 and 64-bits Daz. Here is what log-file says:
C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzfacetransfer.dll failed to load. Cannot load library C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzfacetransfer.dll: the module not found
Try uninstalling DS, make sure it has really gone, and then reisntall - your settings will be preserved.
Completely removed Daz 4.12 reinstalled and nothing. I have 4.12.0.86 64bit Windows 10 version. and the Error again, that dzfacetransfer.dll failed to load.
Updated and Merged, even tried the ludicrus Load a G8 and select the face, and checked Window pane menu and it is still missing.
I installed Daz Studio on to my MSI laptop (Which would be my perfered machine but Daz won't work right on there) and the Face Transfer is working right there. Now there is a vast difference in machines here, my Desktop is an AMD Phenom II x6 with a non NVidia GPU, but my Laptop is i7 Nvidia 980 GPU, is my Desktop to old?
And as for my Laptop not working with Daz, this is the problem, It won't conect to Smart Content and stalls Daz. Product menus take about 5 to 10 minutes to open. But if I wait and load something in the view pane posing and all is normal, and the IRay render is almost instant.
From Rob:
that worked, they should have thought about unique libraries, to at least they could have warned about it.
I cant get it to install. About halfway though the installation stops and I get an error message.
Which can't you isntall - the Visual C++ Redistributable? What is the error message?
Sadly it wasn't caught in any of the testing stages - internal, private, or public. Once it was reported Rob was able to figure it out and post a workaround for now.
That worked for me.
Visual C++ Redistributable:
Setup Failed
One or more issues caused the setup to fail. Please Fix the issues and then retry setup. For more information see Log File
0x80240017- Unspecified error.
Is there a log file to see? Whata re your system specifications, and what security software are you using?
The Log:
[12D8:0DB0][2019-09-28T12:54:13]i001: Burn v3.7.3813.0, Windows v6.1 (Build 7600: Service Pack 0), path: C:\Users\Shannon\Downloads\vc_redist.x64.exe, cmdline: ''
[12D8:0DB0][2019-09-28T12:54:13]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Shannon\AppData\Local\Temp\dd_vcredist_amd64_20190928125413.log'
[12D8:0DB0][2019-09-28T12:54:13]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Shannon\Downloads\vc_redist.x64.exe'
[12D8:0DB0][2019-09-28T12:54:13]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Shannon\Downloads\'
[12D8:0DB0][2019-09-28T12:54:14]i100: Detect begin, 10 packages
[12D8:0DB0][2019-09-28T12:54:14]i000: File search: windows_uCRT_DetectKey, did not find path: C:\Windows\system32\api-ms-win-crt-runtime-l1-1-0.dll
[12D8:0DB0][2019-09-28T12:54:14]i000: File search: windows_uCRT_DetectKeyExists, did not find path: C:\Windows\system32\api-ms-win-crt-runtime-l1-1-0.dll
[12D8:0DB0][2019-09-28T12:54:14]i000: Setting numeric variable 'windows_uCRT_DetectKeyExists' to value 0
[12D8:0DB0][2019-09-28T12:54:14]i052: Condition '(windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10137.0)' evaluates to false.
[12D8:0DB0][2019-09-28T12:54:14]i101: Detected package: vcRuntimeMinimum_x64, state: Present, cached: Complete
[12D8:0DB0][2019-09-28T12:54:14]i101: Detected package: vcRuntimeAdditional_x64, state: Present, cached: Complete
[12D8:0DB0][2019-09-28T12:54:14]i101: Detected package: Windows81_x86, state: Absent, cached: None
[12D8:0DB0][2019-09-28T12:54:14]i101: Detected package: Windows81_x64, state: Absent, cached: None
[12D8:0DB0][2019-09-28T12:54:14]i101: Detected package: Windows8_x86, state: Absent, cached: None
[12D8:0DB0][2019-09-28T12:54:14]i101: Detected package: Windows8_x64, state: Absent, cached: None
[12D8:0DB0][2019-09-28T12:54:14]i101: Detected package: Windows7_MSU_x86, state: Absent, cached: None
[12D8:0DB0][2019-09-28T12:54:14]i101: Detected package: Windows7_MSU_x64, state: Absent, cached: Complete
[12D8:0DB0][2019-09-28T12:54:14]i101: Detected package: WindowsVista_MSU_x86, state: Absent, cached: None
[12D8:0DB0][2019-09-28T12:54:14]i101: Detected package: WindowsVista_MSU_x64, state: Absent, cached: None
[12D8:0DB0][2019-09-28T12:54:14]i052: Condition 'VersionNT64 >= v6.0 OR (VersionNT64 = v5.2 AND ServicePackLevel >= 1)' evaluates to true.
[12D8:0DB0][2019-09-28T12:54:14]i199: Detect complete, result: 0x0
[12D8:0DB0][2019-09-28T12:54:15]i200: Plan begin, 10 packages, action: Repair
[12D8:0DB0][2019-09-28T12:54:15]i052: Condition '(VersionNT64)' evaluates to true.
[12D8:0DB0][2019-09-28T12:54:15]i000: Setting string variable 'WixBundleLog_vcRuntimeMinimum_x64' to value 'C:\Users\Shannon\AppData\Local\Temp\dd_vcredist_amd64_20190928125413_000_vcRuntimeMinimum_x64.log'
[12D8:0DB0][2019-09-28T12:54:15]i000: Setting string variable 'WixBundleLog_vcRuntimeAdditional_x64' to value 'C:\Users\Shannon\AppData\Local\Temp\dd_vcredist_amd64_20190928125413_001_vcRuntimeAdditional_x64.log'
[12D8:0DB0][2019-09-28T12:54:15]i052: Condition 'VersionNT = v6.3 AND NOT VersionNT64' evaluates to false.
[12D8:0DB0][2019-09-28T12:54:15]w321: Skipping dependency registration on package with no dependency providers: Windows81_x86
[12D8:0DB0][2019-09-28T12:54:15]i052: Condition 'VersionNT = v6.3 AND VersionNT64' evaluates to false.
[12D8:0DB0][2019-09-28T12:54:15]w321: Skipping dependency registration on package with no dependency providers: Windows81_x64
[12D8:0DB0][2019-09-28T12:54:15]i052: Condition 'VersionNT = v6.2 AND NOT VersionNT64' evaluates to false.
[12D8:0DB0][2019-09-28T12:54:15]w321: Skipping dependency registration on package with no dependency providers: Windows8_x86
[12D8:0DB0][2019-09-28T12:54:15]i052: Condition 'VersionNT = v6.2 AND VersionNT64' evaluates to false.
[12D8:0DB0][2019-09-28T12:54:15]w321: Skipping dependency registration on package with no dependency providers: Windows8_x64
[12D8:0DB0][2019-09-28T12:54:15]i052: Condition 'VersionNT = v6.1 AND NOT VersionNT64' evaluates to false.
[12D8:0DB0][2019-09-28T12:54:15]w321: Skipping dependency registration on package with no dependency providers: Windows7_MSU_x86
[12D8:0DB0][2019-09-28T12:54:15]i052: Condition 'VersionNT = v6.1 AND VersionNT64' evaluates to true.
[12D8:0DB0][2019-09-28T12:54:15]w321: Skipping dependency registration on package with no dependency providers: Windows7_MSU_x64
[12D8:0DB0][2019-09-28T12:54:15]i052: Condition 'VersionNT = v6.0 AND NOT VersionNT64' evaluates to false.
[12D8:0DB0][2019-09-28T12:54:15]w321: Skipping dependency registration on package with no dependency providers: WindowsVista_MSU_x86
[12D8:0DB0][2019-09-28T12:54:15]i052: Condition 'VersionNT = v6.0 AND VersionNT64' evaluates to false.
[12D8:0DB0][2019-09-28T12:54:15]w321: Skipping dependency registration on package with no dependency providers: WindowsVista_MSU_x64
[12D8:0DB0][2019-09-28T12:54:15]i201: Planned package: vcRuntimeMinimum_x64, state: Present, default requested: Repair, ba requested: Repair, execute: Repair, rollback: None, cache: No, uncache: No, dependency: Register
[12D8:0DB0][2019-09-28T12:54:15]i201: Planned package: vcRuntimeAdditional_x64, state: Present, default requested: Repair, ba requested: Repair, execute: Repair, rollback: None, cache: No, uncache: No, dependency: Register
[12D8:0DB0][2019-09-28T12:54:15]i201: Planned package: Windows81_x86, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[12D8:0DB0][2019-09-28T12:54:15]i201: Planned package: Windows81_x64, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[12D8:0DB0][2019-09-28T12:54:15]i201: Planned package: Windows8_x86, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[12D8:0DB0][2019-09-28T12:54:15]i201: Planned package: Windows8_x64, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[12D8:0DB0][2019-09-28T12:54:15]i201: Planned package: Windows7_MSU_x86, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[12D8:0DB0][2019-09-28T12:54:15]i201: Planned package: Windows7_MSU_x64, state: Absent, default requested: Repair, ba requested: Repair, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: None
[12D8:0DB0][2019-09-28T12:54:15]i201: Planned package: WindowsVista_MSU_x86, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[12D8:0DB0][2019-09-28T12:54:15]i201: Planned package: WindowsVista_MSU_x64, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[12D8:0DB0][2019-09-28T12:54:15]i299: Plan complete, result: 0x0
[12D8:0DB0][2019-09-28T12:54:15]i300: Apply begin
[122C:040C][2019-09-28T12:54:18]i360: Creating a system restore point.
[122C:040C][2019-09-28T12:54:43]i361: Created a system restore point.
[122C:040C][2019-09-28T12:54:43]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{e46eca4f-393b-40df-9f49-076faf788d83}, resume: Active, restart initiated: No, disable resume: No
[122C:0CA4][2019-09-28T12:54:43]i304: Verified existing payload: vcRuntimeMinimum_x64 at path: C:\ProgramData\Package Cache\{0D3E9E15-DE7A-300B-96F1-B4AF12B96488}v14.0.23026\packages\vcRuntimeMinimum_amd64\vc_runtimeMinimum_x64.msi.
[122C:0CA4][2019-09-28T12:54:43]i304: Verified existing payload: cab5046A8AB272BF37297BB7928664C9503 at path: C:\ProgramData\Package Cache\{0D3E9E15-DE7A-300B-96F1-B4AF12B96488}v14.0.23026\packages\vcRuntimeMinimum_amd64\cab1.cab.
[122C:0CA4][2019-09-28T12:54:43]i304: Verified existing payload: vcRuntimeAdditional_x64 at path: C:\ProgramData\Package Cache\{BC958BD2-5DAC-3862-BB1A-C1BE0790438D}v14.0.23026\packages\vcRuntimeAdditional_amd64\vc_runtimeAdditional_x64.msi.
[122C:0CA4][2019-09-28T12:54:44]i304: Verified existing payload: cab2C04DDC374BD96EB5C8EB8208F2C7C92 at path: C:\ProgramData\Package Cache\{BC958BD2-5DAC-3862-BB1A-C1BE0790438D}v14.0.23026\packages\vcRuntimeAdditional_amd64\cab1.cab.
[122C:0CA4][2019-09-28T12:54:44]i304: Verified existing payload: Windows7_MSU_x64 at path: C:\ProgramData\Package Cache\42D5BEC7DDFBD49E76467529CBC2868987BF8460\packages\Patch\x64\Windows6.1-KB2999226-x64.msu.
[122C:040C][2019-09-28T12:54:44]i301: Applying execute package: vcRuntimeMinimum_x64, action: Repair, path: C:\ProgramData\Package Cache\{0D3E9E15-DE7A-300B-96F1-B4AF12B96488}v14.0.23026\packages\vcRuntimeMinimum_amd64\vc_runtimeMinimum_x64.msi, arguments: ' MSIFASTINSTALL="7" NOVSUI="1"'
[12D8:0DB0][2019-09-28T12:54:46]i319: Applied execute package: vcRuntimeMinimum_x64, result: 0x0, restart: None
[122C:040C][2019-09-28T12:54:46]i325: Registering dependency: {e46eca4f-393b-40df-9f49-076faf788d83} on package provider: Microsoft.VS.VC_RuntimeMinimumVSU_amd64,v14, package: vcRuntimeMinimum_x64
[122C:040C][2019-09-28T12:54:46]i301: Applying execute package: vcRuntimeAdditional_x64, action: Repair, path: C:\ProgramData\Package Cache\{BC958BD2-5DAC-3862-BB1A-C1BE0790438D}v14.0.23026\packages\vcRuntimeAdditional_amd64\vc_runtimeAdditional_x64.msi, arguments: ' MSIFASTINSTALL="7" NOVSUI="1"'
[12D8:0DB0][2019-09-28T12:54:50]i319: Applied execute package: vcRuntimeAdditional_x64, result: 0x0, restart: None
[122C:040C][2019-09-28T12:54:50]i325: Registering dependency: {e46eca4f-393b-40df-9f49-076faf788d83} on package provider: Microsoft.VS.VC_RuntimeAdditionalVSU_amd64,v14, package: vcRuntimeAdditional_x64
[122C:040C][2019-09-28T12:54:50]i301: Applying execute package: Windows7_MSU_x64, action: Install, path: C:\ProgramData\Package Cache\42D5BEC7DDFBD49E76467529CBC2868987BF8460\packages\Patch\x64\Windows6.1-KB2999226-x64.msu, arguments: '"C:\Windows\SysNative\wusa.exe" "C:\ProgramData\Package Cache\42D5BEC7DDFBD49E76467529CBC2868987BF8460\packages\Patch\x64\Windows6.1-KB2999226-x64.msu" /quiet /norestart'
[122C:040C][2019-09-28T12:54:54]e000: Error 0x80240017: Failed to execute MSU package.
[12D8:0DB0][2019-09-28T12:54:54]e000: Error 0x80240017: Failed to configure per-machine MSU package.
[12D8:0DB0][2019-09-28T12:54:54]i319: Applied execute package: Windows7_MSU_x64, result: 0x80240017, restart: None
[12D8:0DB0][2019-09-28T12:54:54]e000: Error 0x80240017: Failed to execute MSU package.
[122C:040C][2019-09-28T12:54:54]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{e46eca4f-393b-40df-9f49-076faf788d83}, resume: ARP, restart: None, disable resume: No
[122C:040C][2019-09-28T12:54:54]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{e46eca4f-393b-40df-9f49-076faf788d83}, resume: ARP, restart initiated: No, disable resume: No
[12D8:0DB0][2019-09-28T12:54:55]i399: Apply complete, result: 0x80240017, restart: None, ba requested restart: No
As far as security goes I'm currently only using windows defender as I'm looking for a Virus program that doesn't delete programs that are not virus or malware.
Unfortunately you are using an unsupported version of Windows, version 7 without SP1. I don't believe there is anything you can do, other than updating Windows.
Glad I didn't waste my money on the plug in then. As far as Updating Windows goes I'm not doing Windows 10. I've tried it and I hate it. Besides, it probably won't run well on this laptop.
At least I still have Facegen.
You don't need Windows 10, just Windows 7 SP1 or later - which will also give you alot of bug fixes and security updates (and is free, and available from MS, for now).
Well, here's an update.
Got service pack 1 installed and the plugin sorta works. I get this error while it's processing the picture:
Face Transfer failed to load the base material preset.
Image will still trasfer, but with reduced quality.
As for the finished results. It's a mix bag. I think I'll save what I think about it for another Discussion thread.
make sure you have the updated Geensis 8 Starter Essentials, which adds some files needed for Face Transfer.
I redownloaded essentials from my product library list. I get the same error.
How did you install?
Copy and Paste. Why? The DAZ Installer hasn't worked for me lately. All I get is a download error. But that's a subject for another thread.
Try downloading the zip manually and placing it in the DIM Downloads folder, or use the Install pane inside DS - a copy and paste won't list the new files in the database, without reimporting metadata, so Face Transfer probably won't know they are there.
Thanks Richard, worked a treat! followed the microsoft link, restarted and all good, Cheers.
Hey, my problem is that the face transfer now after several impeccable figures always shows take a new picture. I tried several times but it does not work anymore. Have the full version. Would be very grateful for help, LG Inga Klein
This worked for me after face transfer plug in failed to load after installing Daz 4.12
