3Delight for V4 and clothing
will the clothing and products for V/M4 work with 3Delight rendering without any changes? I've been using iray exclusively since i started using DS a year or two ago and have not tried 3Delight at all. there are some cool products on sale for V4 right now.
    IMO, no:) Poser handles specular, ambient and bump/displacement slightly differently than 3DL. As a rule of thumb, check the glossiness parameter and lower it to get a more natural highlight, 100% glossy means an infinitely small highlight. Kill ambient strength if you don't want the stuff to look like they're glowing. Set bump min and max values to -0.1 and 0.1 as a starting point. Poser displacement uses black as the zero value, so the min- and max values may need some tweaking.
  • ...and a tip if you have not used 3DL before, in rendersettings tab set gamma correction to on and gamma to 2.20, or you will not have accurate shading!
  • LeanaLeana Posts: 13,421
    Those with DS settings should. Those with Poser settings only will usually require adjustments.
  • HavosHavos Posts: 5,680
    All those V4 items should work just fine in Iray with some tweaking of the shaders. I am not saying you should not try out 3DL, but this should not be the reason to swap.
