No one asked me - Diomede screenshots on whatever - Warning AI Discussion OK
1272830323351
  • StezzaStezza Posts: 8,896
    awesome and hot  stuff @diomede  .. great looking start to the skull yes
    carrara 3 book came.  cd intact.  looks like theres a modeling tutorial for a toon dino heart
  • Bunyip02Bunyip02 Posts: 9,292
    +1
  • DiomedeDiomede Posts: 15,410
    Yay, glad you got the cd included with the book.  There are a bunch of models included.  Unfortunately, many have unhelpful names like "VP4009."  That happens to be a flying monster.
    1426 x 793 - 135K
    edited September 2019
    Thanks, Stezza and Bunyip.  No time to finish the model this weekend, but hope to get to it soon.
    Post edited by Diomede on
    yeah. not helpful name.  lol  looking for ships in the lot. something like a firefly class or romulan bird of prey
    face rigging works fine and dandy in carrara.
    but no clue how to set it up from scratch
    edited October 2019
    Not sure if the following is a good way or not, but this is what I did for the Brash Lonergan character.
    I took my Brash mesh and set up a bone skeleton like normal, with bones up the spine to the top of the neck.
    For the head, I created a bone from the top of the neck to the middle of the head, and then another bone at the top of the head to finish.
    From the bone at the middle of the head (which is not meant to move or twist), I extended bones forward, one to the base of the chin (makes it easier to prevent neck rotations from distorting the head), one to the middle of the face, etc.
    From the bone at the mddle of the face (still interior to head and not meat to move), I extended bones to the corners of the mouth, etc. that I wanted to use to help with expressions.
    It might be hard to see, but if you download and expand the screenshot you might see some bone skeleton in the face, and the bone list on the right.
    1
    In my experience the facial bones are best used subtly as a supplement to traditional morphs.  Here, I select Brash's mesh and you cn see on the right that I still have morph areasand a few of the (many) traditional morph channels can be seen.
    2
    Assuming the skeleton is attached to the mesh, if you enter the mesh's modeling room and go to the animation tab, and select a vertex, you can see which bones can currently influence that vertex.  The other eightmapping tools are available as well.
    3
    And here is an example of moving the bone for the right corner of the mouth upwards.  Again, ths is an over-distortion, but I hope you can see how it could be used to suppement a traditional expression morph.
    4
    1596 x 841 - 196K
    1470 x 839 - 178K
    bb03 mesh modeling room animation mode select vertex se bones that can influence.JPG
    1569 x 748 - 138K
    791 x 823 - 69K
    Thanks!
    did you have to do anything with smoothing?
    The Brash model is very low poly for a humanoid figure, so yes I apply smoothing.  I'm not sure that the smoothing is necessary for the facial bones to work in general, smoothing is just enabled so that the facial bones will work reasonably well.
    edited October 2019
    on the rigged text thing, had to parent the bones to the text, then i was able to save the text as rigged.
    don't understand the detach and attacb skeleon,
    i detach the skeleton, from the text, and tried the poser version sea dragon.
    it lets me detach the skeleton but the attach is greyed out, it won't let me re attach the skeleon
    when i go the model room, animate, i see the save and load weightmap.  don't see anything to save and load a skeleton.
    Post edited by Mistara on
    Hmmm
    I can attach a skeleton, and then reattach it.  But if I do, then I lose any weight adjustments I made after the first attachmet, but the skeleton does attach again.
    Can you list the steps you are using?
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,561
    Honestly I just use that plugin DAZ studio mostly now unless I want a quick dirty rig to reshape something to a nice tpose then Carrara shines for that as DS is slow and twiddlier but retains weightmapping adding bones etc, both have their strengths.
    Reusing stuff and multiple software usage DAZ studio is better but a fast adjustment and needing to just animate something Carrara.
    Yes moving text I would use Carrara too but I would convert it to other modeller vertex which I think is your issue.
    edited October 2019
    I inserted a text object and typed Hello World
    I used the edit menu to convert the text object to a vertex object.
    (optional) In vertex modeler, leaving the default sharp edges, I selected a polygon to bring up the smoothing menu, applied oe level of smoothing, and converted to add mesh density.
    I used the orthoganal cameras and bone tools to create a skeleton for the mesh object
    I selected the root bone and the mesh, and then used attach skeleton from the animation menu
    I tested a pose or two then undid to return to base pose.
    I then went t animaiton menu and did unattach.  Worked fine.  Could move skeleton and mesh separately.
    I realigned the mesh and the skeleton and used attach again.  Poses worked again.
    See attached zip file.
    zip
    zip
    Hello World.zip
    226K
    1409 x 809 - 155K
    thanks.  root bone?  bone 1?
    when i go into the model room, the animation menu disappears.
    tried activating the bone tool.
    first i played with the text in the native content demo
    then i tried the sea dragon poser model. the detach skeleton works
    but no matter what i select, attach skeleton stays greyed out.
    selecting hip doesn't give the attach option, hip should be the root bone?
    OH JEEEEZ  had to select the geometry ANND the bones  LOL
    holy crappe.
    thank you both for suffering my ignorance  lol
    830 x 542 - 90K
    It didnt work while the bones were parented to the text.  had to reparent the bones to the 'scene'!
    Then!
    It worked!  transferred the skeleton to a new text converted vertex
    now to put the animated shader on it.
    if only consolidate shader worked on text , every shader domain is assigned to default 1
    can't paste the keyframes into the default1
    was able to duplicate the keyframes down the track to match the animation, that one relief
    now i just need some of that old benny hill music for the sound track
    1143 x 665 - 184K
    I create an animation group myself
    edited October 2019
    tee hee
    i dont see how to add music from the yt free lib
    stopped audioswapping for me too just makes videos unavailable and never adds
    need creator studio classic too
    next skeleton test is transferring a figure skeleton to clothing object  all with skeleton obj.
    and then back to the soft sim testing.
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Mystarra said:
    tee hee
    Ha!  Got a chuckle from me. smiley
    Mystarra said:
    tee hee
    now, if you re-do that with a line of sprinkles heading for a finger bun yes
    cutesy wink
    doh, trying to push some verts, but when i click animate to see where they are, the handles disappear. i go back to model tab, the handles come back but the verts go back to default position.
    tpology protect is off. tried again after saving as .car file. same thing. tried create morph and edit, but then it doesn't let me select anything.  i can randomly puth the verts in model tab, but is pure guess work where the verts need to be
    984 x 647 - 108K
    oh i get it.   have to export the mesh mess as a morph target.  re import it and do the morph correction on that.
    Hope you get it to work Misty !
    I tried creating a morph target using just those toe vertices pulled down myself in DAZ
    but sadly it didn't work in Carrara
    Wow!  I’m a whole page behind my own thread!  Love the video Misty. You are awesome.
    cant help with the morph. Now that I’ve been dabbling more in other Daz programs, I wonder if the ties could be re-weightmwpped, saved as another character, then converted to blended. Talking out of my As$. Probably out of my depth.
    i been comparing the left and right bigtoe2 all weekend.  trying to figure out what the difference is
    like, is something wrong with the vert order?
    edited October 2019
    October 2019 is a Month of Tutorials for Me
    Not directly Carrara tutorials, although almost everything I've done so far can translate to Carrara.  During my month in Maine, I'm watching/reading lots of tutorials and taking lots of reference photos.  I've been noting which tutorials I've completed and posting occasional freebies and reviews.
    https://www.daz3d.com/forums/discussion/comment/4966351/#Comment_4966351
    Hopefully soon, I will have learned enough to
    - model a building exterior and door in Hexagon (and UVMap)
    - create PBR shaders in Substance Painter
    - load the shaders in Daz Studio
    - rig the outer door in Studio
    The result should be a small set that is compatible with Carrara.  When done, and if I'm satisfied, I will make it available as a freebie.
