Missing Poser Content
In Studio 4.9.2.70, all of my Poser content shows up, in the "Poser Formats >" category, and as custom products in the Content Library.
In newer versions of Studio, 4.9.4.117, 4.10. 4.11. 4.12... nothing but textures, every set is a warning triangle, and a "File does not exist" message when clicked.
The "Poser Formats" section of the Content Library doesn't even have the arrow, it's as if I have no Poser content at all.
I hope someone can tell me why the older version of Studio sees my Poser content, and the newer versions don't, and how I can correct this.
Thank you.
Edit: If I load it in 4.9.2.70 and save it as a Scene Subset, then it shows up in newer versions of Studio under DAZ Studio Formats >. Weird.
That sounds as if they are separate erlease channels and you don't have the folders added as Poser Format content directories. You can add them by right-click on Poser Formats in the Content Library. You can also run
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/save_mapped_paths/start
in the version with the folders, then run the script it saves out in the other versions.
That script did it, thank you.
