My Renders, Now I can go to bed
1…1112131517
    That's a stemay valentines for sure!
    Really like the last one she looks very mysterious
  • XaatXuunXaatXuun Posts: 882
    edited November 2018
    " heh . .  ahh maybe it's in the next grove"
    " This is the third one," . . ."admit it, you don't know where we are, and we're lost"
    been a while since I shared, so whipped this up for ya
    1800 x 1800 - 3M
    Post edited by XaatXuun on
    G3F
    petite 5'2"
    1800 x 1800 - 2M
  • SaphirewildSaphirewild Posts: 6,729
    Some great renders as always @XaatXuun
    Perfect expression!
    Thank you Saphirewild
    Thanks IceDragonArt, when I came up with the expression I had to fill in the rest, forgot where I was going at first, but yeah, saw that expression and had to create something to go with it
    edited February 2019
    been  a while,  dialed  this G3F to post here
    there were some previous ones, but not something I was happy with, I like this one, but one part, and you can't see it  cheeky,
    maybe later, if I decide to fix it
    1800 x 1800 - 2M
    fixed that problem I didn't want to show, but for some odd reason, I cant get  the lighting  light, every thing is dark, still going to show any ways, need a break and wanted to share
    1800 x 1800 - 409K
    discovered these free body & Head morphs, for G8, and gave it a try. enough to get  some desired morphs in, happy I found it
    1800 x 1800 - 2M
    did another render of  G8F I dialed in, one thing that was off was the left eye,  for some reason it doesn't move correctly, not sure if it  something  due from using the fre morphs or not,  had to select the left eye and  dial it in to look close to normal.
    my DOF  seemed to be a bit off, showing the render any ways, don't have time tonight to do another render
    1800 x 1800 - 2M
    dunno why I  be having problems getting that camera right  blush
    2 things since last image of Genesis 8, I fixed the eye problem,   what it was one of the eye dials I turned off limits,
    and I have her height, by useing G3F, and measure metrics , I don't have Measure metrics for Genesis 8, so just did  stand in same spot adjust G8F to G3F height.
    1800 x 1800 - 2M
    dialed another G3F
    just something to do, nothing special
    1800 x 1800 - 2M
    I think I am going ot call you the dail in King @XaatXuun!
    some great renders!
    thought I try out Genesis 8  female again,  had something  that also happens with G3F,  once it happens can't remove it, but I can hide it, doesn't happen  all the tine, and I figured how to avoid it with G3F, just need some practice with Genesis8, and should have that taken care of. I used another  free morph and did some scaling to get the desired look.
    don't know measuements
    2000 x 2000 - 2M
    I think she looks amazing!!
    You've been busy!  I actually quite like this one, its very moody.  I know the lights werent working right but I like it!
    thank you
    I was  surprised she came out like that, with the limited dials I have for Genesis 8, was happy with the results
    thanks
    I didn't mind it, and thought it worthy enough to post here, still wanted better lighting, still at aloss  why the lighting ended up so dark, later I removed the scene, and place the lights back in, and everything was fine. just haver not got back to actual render of it, I just like creating wink
    tonights new G3F, I decided to see if I could dial in a over byte, google didn't show me what I was looking for , for some examples to go from, so here is my attempt
    2000 x 2000 - 3M
    thought I would see  what I could do with those free dials for Genesis 8 Male.
    interesting how quick one can dial in morphs when you have  few dials to use
    I used a hair from G3M,  now that I look at it, it should had been adjusted some
    2000 x 2000 - 2M
    Wow you did a great job on the dial morphs!!!
    Keep up the great work!
    thank you
    edited September 2019
    been a while, thought I would post something I recently dialed in
    1600 x 1598 - 1M
  • Excellent render! Nicely dialed in!
    edited November 2019
    Hey, been a whie thought I post something
    1600 x 1598 - 2M
    edited December 2019
    G3F
    just head, where I put 10% of ever head I have in the dials
    adjusted brows and eyes, and scalled nose smaller using Gia7 mats, Awesome eyes for the eyes
    and that's it. Later I finsih up the body
    1600 x 1598 - 672K
    todays dials was with G3M
    couldn't find a background to go with this
    1600 x 1598 - 648K
    did some adjusting of a previous model
    GM3
    1800 x 1800 - 1M
    Wow where did you get that neat mustache and hair!
    Great looking character for sure!
    Adrian Hair and Beard for Genesis 3 Male(s)
