Mirror
I was wondering if you have an object (example) a building and you'd like to mirror the building without having to completely compose the mirrored building again is there a way tosave the building in a 360 duplicate building?
Do you need a mirror image? Or just another instance? If the latter, you could just create an instance of your building model then move that second instance wherever you need. Changes to the original would also apply to any instances.
If you do need a mirror image, this may or may not work, but try duplicating the first building, then scale the second copy to -100%. It works sometimes depending on the geometry of the object and how it was built.
PMFJI but I am mystified re: the term "instance" here. What exactly is an "instance"?
There are a few other terms that escape me that are possibly related to instance... decals, billboards and something else.
