Problems with DS4.12 smart content (DS4.11 is fine)
Xyetzt
I have a particular problem with the DS4.12 beta that is not occuring with DS4.11. Nothing is shown as installed with DS4.12. I know that 4.11 has a freebie content folder but that is all I see that is different I think.
Do the Content Cluster directories match?
Do you mean the info found in these screenshots?
You are not getting any actual errors on starting DS?
I did check the log file and found errors like
I meant general errors, like the one saying a valid PostgreSQL connection is required. I can't readily see why this is happening for you.
I did find this
Try loging off (from the Connect menu).
Okay trying that now.
