Problems with DS4.12 smart content (DS4.11 is fine)
I have a particular problem with the DS4.12 beta that is not occuring with DS4.11.  Nothing is shown as installed with DS4.12.  I know that 4.11 has a freebie content folder but that is all I see that is different I think.
  • Do the Content Cluster directories match?
  • XyetztXyetzt Posts: 27,516
    Do you mean the info found in these screenshots?
    572 x 529 - 75K
    582 x 577 - 61K
  • You are not getting any actual errors on starting DS?
    I did check the log file and found errors like
    2019-08-24 09:18:54.360 WARNING: ..\..\..\..\..\src\sdksource\contentmanagement\dzassetmgr.cpp(8924): Missing asset file: Environments/Architecture/Apartment Patio Set/3Delight/APS Patio Table.duf
  • I meant general errors, like the one saying a valid PostgreSQL connection is required. I can't readily see why this is happening for you.
    I did find this
    2019-08-24 11:05:47.035 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to parse returned JSON: <html>
    <head><title>Error 302: Hotspot login required</title></head>
    <body>
    <h1>Error 302: Hotspot login required</h1>
    </body>
    </html>
    I did find this
    <body>
    </body>
    </html>
    Try loging off (from the Connect menu).
    I did find this
    <body>
    </body>
    </html>
    Okay trying that now.
