VMWare and DForce OpenCL problem
Hi,
I use Daz3D in a VMWare Workstation (current major release) with Windows 10 and all Drivers in the Host and Guest are up to date.
In the Guest System, when I would like to use DForce, I get an "Can not find OpenCL() Device" error. In my host windows 10 it worked with the GTX 960.
On the same machine, it do not in the Guest virtual machine.
Is there a way or driver to get Daz3D DForce to work?
If I remember correctly, virtual machines don't have the kind of root access needed to use the hardware for things like renders and calculations. Although, when I was looking into it it was a few years back, so it might have changed since then.
Do you mean this is not possible in a VMWare? NVidia Iray worked.
There are other limits with Daz3D in VMware too?
