bullet physics for DS 1, 2, 3, 4 PC/Win ... teaser
13468911
  • mCasualmCasual Posts: 4,607
    edited November 2013
    MCMXC said:
    The "feet on pedals" part made me think of one thing... would be possible in the future to apply it to the pedals of a car?
    the feet cycling animation did not use physics
    it was made easy by using the following free scripts
    mcjAutoLimb : https://sites.google.com/site/mcasualsdazscripts/mcjautolimb
    mcjKeepOrient : https://sites.google.com/site/mcasualsdazscripts/mcjkeeporient
    mcjHoldOn : https://sites.google.com/site/mcasualsdazscripts2/mcjholdo
    mcjAutoLimb is my most important tool for animations
    the physics engine will include springs and hinges,
    so you could create a "real" gas pedal and push it using an invisible cube attached to a foot
    320 x 180 - 194K
    Post edited by mCasual on
    today, the standard two-bodies hinges
    400 x 400 - 891K
    1200 x 1200 - 463K
  • RAMWolffRAMWolff Posts: 10,381
    Looks better and better.
    How do you create paths like that? Not in DS or yes?
    in this case the lines and circles are simply a texture image on a plane
    but on my site there's a plugin to display render paths
    see
    https://sites.google.com/site/mcasualsdazscripts/mcgtracepath-for-mcjtracer
    https://sites.google.com/site/mcasualsdazscripts2/mcjtracerds45
    in some of my images you sometimes see those lines
    800 x 450 - 293K
    Ah, thanks so much. Not sure when I'll have the time to play but got them both. :-)
    we know that if we make abstraction of air resistance, all objects, large and small, heavy and light as a feather all fall with the same speed profile - on Earth objects falling have an acceleration of 9.8 m/s/s, after 1 second they fall at 9.8 m/s
    so ... the new thing for me is to realize that, when i see something like the image below, the fact that the movement seems slow, means that the objects are big !
    i could even evaluate the size of the objects just by observing the movements
    the balls are 1 meter in diameter and the swinging rod is 4.5 meters long
    and this explains why a pencil falls quickly while a 100 ft tall chimney falls slowly
    600 x 600 - 179K
  • ghastlycomicghastlycomic Posts: 2,531
    I can't help but mentally hear a calliope playing "Entry of the Gladiators" while looking at that animated unicycle gif.
    the acrobat skills needed to do it without a seat are Barnum and Baileyesque
    320 x 320 - 253K
    OMG! LMAO
    Amy still on board for more death defying experiments
    ( maybe i understand the bullet physics 2-bodies-hinges a bit better )
    anyway, enough to include them in the inpending release
    impending as in next Saturday
    600 x 600 - 638K
    WEEEEEEEEEEEEEEEEEE
    yes
    chains
    dangling
    could eventually be used to indirectly animate tresses and dresses
    ( 3 hinges )
    600 x 600 - 273K
  • sjfryer_a638239a69sjfryer_a638239a69 Posts: 19
    Rag doll physics too?
    there's a type of ragdoll joint / hinge n the bullet physics engine
    called "cone-twist" http://bulletphysics.org/mediawiki-1.5.8/index.php/Constraints
    ( bullet physics engine is the open source program kit that performs the simulations )
    so, i'll have a ragdoll test soon
    initially it may be a stickman prop made of capsules
    but i'll also try a "real" figure ... Amy may volunteer if it's minimally safe :)
    example of Blender (not by me ), which uses the same engine :
    http://www.youtube.com/watch?v=tiiDmr-V-D8
    note that my system packages the physics engine as a PC-Windows .exe program
    plus a Daz Script, so it's not Mac compatible except if someone will volunteer to compile my source code for the mac
    another avenue i may try is to have the daz studio script
    make Blender perform the simulation
    which would have many advantages and most probably be mac compatible
    480 x 270 - 266K
    mile high
    728 x 1200 - 105K
    364 x 600 - 411K
    728 x 1199 - 707K
    math error while plotting ( insert nefarious plan here ) a trajectory
    figure 2 is the same without the error
    1280 x 960 - 181K
    512 x 288 - 573K
    1200 x 675 - 63K
    1200 x 1200 - 521K
    the white stick indicates where i want a hinge to be located and its orientation
    i tell the physics engine that the 2 balls are attached to this hinge
    then i ... guess ... i have to tell the physics engine
    where this hinge is in a green-ball-centric universe
    and where it's located in a pink-ball-centric world
    it almost almost works except for a jump at the beginning of the simulation
    600 x 337 - 616K
    I noticed that the lollipop in "yupall" changes colour ;-)
    For the one doing the jumping, first thought was that it would be caused by a spider! I'm sure that's helpful :-)
    you're the second person who saw it as a lollipop :)
    in the first tests i saw the cone as jujubes
    1300 x 957 - 186K
    well i think i figured the 2-bodies-hinges
    i must specify the position of the hinge ( the now detached lillipop stick )
    in the green-ball-centric universe : : [ 0, -25, 0 ] centimeters
    then in the red-ball-centric universe : [ 0, -75, 75 ] centimeters
    600 x 337 - 641K
    30 seconds YT video ... for real Amy fans and nerdy physics people
    https://www.youtube.com/watch?v=xbtYredDvX4
    the goal is to have a first beta version out by 6pm east coast time
    with the 3 types of hinges seen so far
    - object attached to the world : example Amy on the wrecking ball
    - steer and roll : example the BMX wheels
    - 2-bodies : example all the recent examples
    and simple objects
    -static objects ( example the ground-cube and the green ball
    -dynamic objects - the red ball and falling cement blocs
    -kinematic ( animated ) objects
    600 x 600 - 326K
    Looks really good there Casual!
    in case you're in a hurry and want to read the manual, as it is being written
    the home of the beta release will be
    https://sites.google.com/site/mcasualsdazscripts3/mcjbulletservice01
    though i'm less sure 6 pm will be the release time
    lets say before midnight :)
    480 x 360 - 112K
    i will post the client script and server program in the next hour
    but it will really be intended for the adventurous nerdy kind
    because the manual is probably not very detailed
    and there must remain bugs and quirks and it may be crash prone
    ( though i did not crash daz studio during development (
    836 x 627 - 19K
    i wont shout it too loud but the first beta kit is ready !
    version 01
    i'll probably work on it Sunday, to improve the manual and make many test and bug fixes
    it will then become version 02
    ( for instance, the Steer-and-roll hinge is presently not steerable at all and has hard shock absorbers )
    first thing today i'll fix the steer and roll constraint/hinge
    and give access to the parameters of the steering and the suspension
    900 x 900 - 302K
    the "steer and roll" a.k.a. Type 3 /hinge was fixed
    if you installed the server program
    you only need to update the daz client script ( mcjPhysicsClient01.zip )
    600 x 600 - 351K
    note: there seems to be issues with scaled objects, better use non-scaled objects for now
    hopefully next weekend's version will be more stable
    but for now there's enough to play with !
    .... later that evening ... found the issue !
    450 x 450 - 292K
