DWG save failed
jeht01_11f062ec46jeht01_11f062ec46 Posts: 18
edited December 1969 in Hexagon Discussion
I'm trying to save something i made as a DWG file so i can import it to another program, but any time i try to save it as that file type hexagon tells me that the save failed. is there a size issue or a poly count requirement to be able to use a DWG? maybe i over looked something. i could use some help on this anyone have any ideas how to fix this?
  • Design AcrobatDesign Acrobat Posts: 459
    Does the file have any dynamic geometry that is not collapsed?
  • dot_batdot_bat Posts: 373
    Try saving the file to another folder or disk. i can only save hex files to the daz folder. im on a mac
  • jeht01_11f062ec46jeht01_11f062ec46 Posts: 18
    no i don't have any dynamic geometry in the design. i also have tried saving to a different location, still save failed. i tried saving to the daz folder and it didn't work either.
    i dont see where you can save or export as a dwg file. thats autocad extension. perhaps xport as object or dxf
    if you go to "save as" and then click the "save as type" its near the bottom. also you can go to export and find it there as well. yes it is an autocad format and I'm trying to upload it into autodesk inventor.
    edited July 2012
    Im using 2.5.179 and i dont see those options as you can see from the screen shots. the lower screen shot is save as. not that i will ever use it but where is the dwg option? i also get those temp folders when i save anywhere else than the daz folder
    284 x 217 - 21K
    334 x 218 - 16K
    Post edited by dot_bat on
  • ds-mail_2e0cb9c256ds-mail_2e0cb9c256 Posts: 70
    You need to use "save as" not export
  • edited July 2012
    *IF* your model isn't proprietary or otherwise secretive, could you save it as an HXN and upload it here? (HXN is the only non-image file that can be uploaded here).
    Then we can load it into our's and see if we can save it as a DWG - or alternatively, see if we can figure out why it can't be saved that way.
    ADD:
    Christ...DAZ apparently "fixed" the uploads. I just tested with an HXN file and it wouldn't let me upload it.
    C'MON, DAZ!!! Ya think we're gonna turn your website into a warez site with your HXN files?
    Post edited by emfederin_9bc0c524c8 on
    i tryed to do something simple and made a box and couldn't even save as one. try making a box or a object and see if you can save as a DWG file. when i try it dose make a empty folder and also tells me the save failed.
    467 x 463 - 58K
  • RoygeeRoygee Posts: 2,247
    I get exactly the same - save failed and an empty tmp folder. Never had a need to save as .dwg before, so can't say if it ever worked in previous versions.
  • GhostmanGhostman Posts: 215
    Just tested in 2.1 and ended up with a empty folder.
