@David - those yellow ones look intriguing. Got to check what you're up to now.
@Dave - good start, I think we're all great fans of Peter.
I'm still in experimental mode. Shapes from David's last Wings videos. A high contrast image wrapped around them. Specularity, Anisotropy and Transparency controlled with a hyper texture. A fully white HDRI supplies light and speculartity.
Dave :I hope peter will be for sale in the states also......heres how far I have gotten with the house ...I imported vic and was able to make her a little larger.....still a WIP
That last one, Horo, is super - great effect whatever you're doing. Sadly, not into Wings3D (can't start in to another 'ware right now) but it looks like a great piece of kit.
Bullit...very nice house - worst about these house projects is you then want to furnish them afterwards, but you learn so much in the process.
@Trish: Cute looking Albert. I see you solved your roof problem, and it looks very nice.
@mermaid: That image really looks nice, love the colors.
@Horo: Hmmm, using portrait ratio is a thought I'll have to try next time. The cubes you've made are gorgeous.
@David: Results of your current experiments are quite nice.
@Dave: Another great Peter image. That particular one would be a market grabber for sure. Nicely done. Tried your roof procedure and, except for the roof material, came up with the following.
@Horo: Thank you, Dave's roof solution was something I hadn't considered. And it's for extremely small people. I like the results you got with David's Wing object using the hyper texture, and watched David's video, but wonder how the different colors were achieved. I did the Icosahedron in Wings which separates into ten parts, and have assigned two different materials to each group of five. Can hyper texture be used with existing materials?
@fencepost: Thanks. I saw that when I went to Bryce 5 to find material someone was looking for. Knowing me, I more than likely have downloaded that material but haven't used it yet.
@David - I can't wait until I get home to watch your newest video. The renders that you did are beautiful.
I have spent much of my quiet time today noodling about with some Wings3d objects based on your Art Wade Twisted shape video. In the video you did a cube, I decided to try the other shapes. This render is my take on the video. From left to right the objects are a Tetrahedron, an Octotoad, an Octahedron, and Icosahedron, and finally a Dodecahedron. The materials on the objects are all from the P34 metals. It is light using Obscure TA at 36 RPP with soft shadows. TA scattering and boost light are both turned on. I used Horo's "Garage-Door Closed" HDRI for the lighting along with the Bryce sun at 50 Diffuse and 100 Specular.
I really like how the Icosahedron turned out, shape wise that is. I'm going to do a render of just it and possibly a separated bit of it to show off the geometry.
fencepost52: That's a good idea to use it for Alberts home....
mermaid; nice field scene with the flowers and mts.
Horo: The colors in post #1411 are very cool really like the shapes
Guss; Your roof came out great..I just was so lost in building I could not figure out how to make the roof...LOL brain was on overload
David; Your experiments are moving right along and you are getting some very nice and interesting shapes.
Jay: Thanks the important part for me is having fun....LOL I didn't even think about the inside........Oh well
ok one more for tonight.....Albert while visiting the lost Island of Boondoggle....being the ever vigilant scientist has discovered a new sub-species of callinectes sapidus........
@GussNemo - the different colours are from a high contrast spherical panorama wrapped around it and used for Specular and Transparent. A positive hyper texture controls specularity, transparency and anisotropy. Light and specular come from an uniformly white HDRI.
@Trish - thank you. I like your toon scene. I wonder if Albert has already come up with a formula that relates the number of leg segments and the number of clippers.
@Dangerlad: That image turned out well, they all look like colored balls of wire. Reflections are a nice touch.
@Trish: Thanks, I just had to give Dave's roof instruction a try. I tried a building some time in the past but used the Del key before it was finished. The Albert image is great, though I was thinking he was a bit crabby seeing the crustacean in the scene.
@Horo: I take it a high contrast spherical panorama is different than an HDRI? What is it exactly? The positive hyper texture sounds similar to David's overdriven material. I take it preset materials can't be used with this method?
Yes it is. It is still just a conventional LDRI but contrast and saturation was boosted. I took one of my Wallpapers and rendered it with the Spherical Mapper as 4000 x 2000, saved as 48-bit TIFF and then processed it to an HDRI and finally reduced it to an LDRI.
What I call Hypertexture is the base of overdriven materials. An overdriven material is a material using a hypertexture in one or several slots and/or controls. The hypertexture (positive and negative) has been discovered by David and it exists since Bryce 5.0. Preset materials can be enhanced by using a hypertexture. There are many possibilities and we are still trying to fathom the extent of how they can be used and discover queer behaviours on the way. It's quite exciting.
Horo – All your experiments are looking great especially the ones on the top of this page
David - awesome results with all your renders, thanks for the new videos.
Fencepost- great results, both are looking nice.
Dave – another cute Peter render
Trish – the house is looking nice and Albert’s new discovery is ready for a book cover for a kiddies book.
Dangerlad – nice going with the tuts, the shapes look good.
I tried David’s experiments with the solid videos with the Octahedron, but I did not get the results he got. David got 2 parts in the 1st video whereas I got one part. The other objects are from the twisted cube-Another looped shape. I used the default materials and used Horo’s Sramp Hdri –Premium 256 RPP.
The second is just a simple render with the 8 parts from the same video and the last is the shape again with two materials.
I will try the other shapes later in the week and the new videos later this week.
@Mermaid010 - I really like the first render. I know you said that it was just the default material but it looks a lot like bone or unglazed porcelain.
As promised here is my Art Wade style icosahedron. It was made in Wing3d and when I finished I decide to "Separate" the model and got 12 pieces. The two thing to the left of the icosahedron are just 2 of the 12 loops/pieces. I like how they kind of look like flowers. I think that the geometry is very elegant.
as Albert calculated the number of leg segments as related to the clippers.... he soon realized that the sub-species.... was not quite as docile as he first appeared.........!!!!!!! ( good night all...Trish)
The little present is made with Wings3D, the ashtray and the cigarette are pure Bryce. A bit of smoke would have been nice, but my attempts looked so AAAAARGH that I thought it would be better to let it away. Light is IBL with HDRI.
This was an ideal opportunity to use the gift from Horo and David last Christmas. The materials are default (Wings 3D default) with 20% reflection. Thanks David and Horo not only for the gift but also for sharing your knowledge with us.
@electro-elvis - really nicely done. The table top looks great. This must be outdoors with an open sky and with a slight breeze, it is difficult to see the rising smoke.
@mermaid010 - The shapes look great, perhaps a tad on the bright side. Good to see this freebie in use.
@Trish: That's becoming cuter as time goes by. Hope Albert doesn't forget that crab has two claws.
@electro: You've done a bang up job in that image. I like the overall effects of the ash tray.
@mermaid: Shapes are real nice, though purple upholstery?
Images below are the 10 segmented icosahedron. At first I couldn't figure out how to light them, then decided to try obscure lighting to see what resulted. I'd never tried obscure lighting before but I liked how these turned out. I wanted to really increase reflection but 100 is as high as it goes. So, in images 3,4 and 5, I whipped up the overdriven material setting and applied it to reflection. I thought these results were nice as well.
Thank you mermaid010, GussNemo and Horo for the kind comments.
@mermaid010: No it is not an image. This are all Bryce materials of the library, except the filter material, that I have made especially for this cigarette. The ash is a volumetric material, which is lit by an orange sphere light with very small range.
@Horo: The smoke is my problem. And the surface of the present. First I intend to make a material, that looks a bit like gift wrap, e.g. golden stars. I am sure, you can do ist with the DTE, but not me. ;-) The table material is a photo. I added a bit reflection
@Guss: I built the ash tray with metaballs, to avoid harsh edges. I think that's why the HDRI works quiet well here.
Two variations of this Peter the Polar Bear render... Not sure if one is better than the other.
I much prefer the first, though both are good. The closer crop onto the bear's face gives the image a more intimate feel, which makes it more peaceful to me than the second. It's interesting that the first image breaks a few compositional rules yet still works really well.
A fast rendering effect.
Bryce 10 minute scene - SFX hyper texture for shadowless HDRI - by David Brinnen
Jay
If you did the last one this is easy. Quick conversion of SFX hyper texture for shadowless HDRI - by David Brinnen
@GussNemo - thank you. Nice roof. The lower part of the house is a bit on the small side :-P
@Jamahoney - thank you. Just tinkering.
@David - nice space scene.
Dangerlad: very nice effects with your shapes
New render Challenge announced. This one will run till the end of the Year.
http://www.daz3d.com/forums/discussion/32280/
Thanks to everyone who commented on my renders.
Super work going on here. I love all the shiny twisted objects. I wish I had more time to play, but RL gets in the way of computer time...
@mermaid010 - thank you. Your new shapes look great. The coloured ribbons looks particularly nice.
@Dangerlad - shapes are great. I agree that the one at left looks a bit like a flower.
Can't blame the crab with how it is handled by Albert.
Dangerlad –nice shapes and render and the one on the left does look like a flower.
Trish- the story continues……
Electro-Elvis – interesting, did you use an image of a cigarette for the material?
Tried a few more shapes from
Wings 3D project - Twisted loop test on five perfect solids - by David Brinnen
Wings 3D project - Art Wade twisted loop test on five perfect solids - by David Brinnen
@GussNemo - oh yes, all renders look great. Good use of the IceFire HDRI. Obscure Lighting is a great lighting scheme.
@Dave - they are both cute. For a Xmas card, the second one is probably better.
Elvis very nice model job so good that now I need a smoke......
Guss; These would make very cool Christmas ornaments for a tree
Dave: I like Peter in the second one with the tree.... it looks like he fell asleep waiting for Santa
Mermaid: your shapes are very neat ...Did you use shadow capture???
