I Forgot What My Complaint Was - Complaint Thread
1…7677798182…100
    My jeans from high school no longer fit... cryingcryingcrying
    it all droops south crying gravity is not kind
  • chaynawolfsmoonchaynawolfsmoon Posts: 675
    edited July 2019
    indeed. gravity seems to be making my thighs and butt swell... which probably isn't all bad but...
    sub complaint: my first attempt to convert genesis 3 clothes to 8 was not entirely successful.
    reverse complaint: i must learn how to do reflective surfaces... [that was easy]
    Post edited by chaynawolfsmoon on
    Phil Collins cant find billy again.  mebbe he's at the piano bar with Davy from the Navy.
  • complaint: when you finish a shot and realized you missed several very bad hair clips. no chance of even cropping it out...
    so many tears... i don't think i saved the scene even.
  • DanaTADanaTA Posts: 13,413
    Mystarra said:
    my coffee is broken.
    DanaTA said:
    > greater than
    < less than
    >= greater than OR equal to
    <= less than OR equal to
    Dana
    thanks
    Is null
    IsNull()=true
    The last two are useless.  Nothing is equal to NULL but NULL.  NULL is nothing.  Not zero, just nothing at all.  It doesn't exist.  Therefore it can't be less than or greater than anything, not even zero.  NULL has no value at all.  As for the expressions, it depends on the programming language you're using, but those first two expressions seem fairly common.
    Dana
    DanaTA said:
    DanaTA said:
    > greater than
    < less than
    Dana
    thanks
    Is null
    IsNull()=true
    Dana
    i use is null to filter date fields.  the "" doesn't always work for some filters, dang annoying.
    null / "" messes with my
    DO Loops
    do you spell fubar, fubar or foobar ?
  • HoroHoro Posts: 11,719
    edited July 2019
    fubar = fooled up beyond any repair (where fooled replaces a word I must not write here). It appears that it originally came from furchtbar (German for dreadfull).
    Post edited by Horo on
  • XyetztXyetzt Posts: 27,559
    Apparently I need to be connected to a WiFi for my DIM to work.  I was trying to log in to my DIM but it would not work.  Then I checked my internet source.  It said I was still connected to train WiFi so I had to turn off WiFi and turn it back then connect to the correct WiFi for DIM to work.
    What does WiFi mean?
  • LeatherGryphonLeatherGryphon Posts: 12,508
    This was a very difficult question to answer.  I Googled for "what does wifi mean" and it took nearly a half second for the answers to appear and another two seconds for me to pick out a proper answer.
    https://www.quora.com/Why-is-Wi-Fi-called-Wi-Fi
    I made a favorite in DS and I put it in the wrong folder.  How do I fix it?
  • McGyverMcGyver Posts: 7,103
    Non-complaint:  My A/C is working OK today.  I'm cool and comfortable.  Outside it's been rainy most of the day and it must be really humid out there because my kitchen window is fogged up on the outside. surprise  Somedays it pays to not open the door even once.
    Single layer glass?   Yeah, today would be one of those days to not go outside...
    It is super-gross out there... Is it possible to be 2000% humidity?... Because that what it feels like... every time I go outside, I’m drenched is sweat within a few minutes. To make matters worse I need to solder some copper pipes and I’ve been postponing it all day in hopes it would either rain or the humidity would decrease a bit.
    edited July 2019
    Doh... I wrote that last post about an hour ago... I thought I sent it...
    So, instead of soldering the copper pipes, which I determined it was too humid for,I decided to grill pork chops...
    but on the bright side, it started to rain while I was grilling.
    The hard lemonade made the drizzling less annoying...
    Post edited by McGyver on
  • GoggerGogger Posts: 2,535
    Well, THAT's two and half seconds you can't get back!  <LOL>
    I grew up in a hot, but dry climate. When I was moved to a humid hot climate I proclaimed, "Ugh! Living here is like being tucked into someone's sweaty armpit!"
    I always assumed it either meant “Wireless Fiction”... because Sci-Fi stands for Scientifical Fiction and we all know that even though you aren’t actually wired to the internet, there are lots of actual wire involved in the internet, so to say one is truly wireless, would be fiction... or it stood for “Finklewaves” which are the primary carriers of internet particles and cat pictures.
    It’s more like being in a hot bulldog’s mouth right now... A warm bulldog... not a sexy bulldog. I had to clarify that because of a prior misunderstanding once.
    I've heard it as ...beyond all recognition.
    Dana
    Mystarra said:
    DanaTA said:
    DanaTA said:
    > greater than
    < less than
    Dana
    thanks
    Is null
    IsNull()=true
    Dana
    DO Loops
    Concerning NULL and ""...consider this...
    Your piggy bank may be empty.   ""
    Your Rolls Royce is NULL (it doesn't exist, unless there's somethign you haven't told us)
    Dana
    DanaTA said:
    Mystarra said:
    DanaTA said:
    DanaTA said:
    > greater than
    < less than
    Dana
    thanks
    Is null
    IsNull()=true
    Dana
    DO Loops
    Dana
    Existence is overrated.  Imaginary Rolls Royces work just fine in my dreams.
    I have a similar philosophy about beautiful, unique and unaffordable items I see in stores.  I just pretend that I own the item but I'm letting the vendor display it to the public for me.indecision  And I drop in to the store once in a while to look at my item.  When it's no longer in the store I assume that it has found a good home and many many people had a chance to see my precious item.
  • Subtropic PixelSubtropic Pixel Posts: 2,403
    surprise  I don't know how you did that but I find many many games completely unwinnable.  Like, they are dead in their tracks within 10 -15 moves.  All possibilities tried.  Are you using a "novice" switch?  If not, then I bow to your superior skill or luck.
    Nope. No novice switch. The only difference is that I am using the 'Draw One' option and you are using the 'Draw Three' option. I think the Draw One option may be easier to win.
    Ah, that may be the case.  Many times I can see the card I need but it's procedurally out of reach because of the three card draw even if I backtrack and try creatively navigating a different sequence to bring the card to the top.  This is what retirement is about, having the time to play at honing one's skills to try to accomplish yet another meaningless goal.frown
    Come to think of it, almost my entire career was a meaningless gesture.
    Well now, that is not true, and you know it.  How do you know it?  Because somebody thought your work was important enough to pay you for it.  This was important in the time that it was needed by the people who needed it.
    In the big scheme of things, it really does not matter if your work left some sort of a "legacy".  If it did matter to you, I think you would have gone into something else, like maybe carving statues for money, writing books for money, teaching (for money, as a profession to people who were PAYING for it).   Just about the only thing you can do to leave a long lasting legacy (and not get paid for it) is raising kids.
    Think about it:  George Lucas, by some accounts only a so-so storyteller, wrote a little story about some kid on a godforsaken desert planet.  The kid learns an ancient martial art, goes to war, and makes good by saving the galaxy from certain ruin.  Then he made a film about it with a bunch of actors who, for some unknown reason, decided they could brave the desert heat during production.
    And then a bunch of people PAID to see it.
    At least you and your dodgy AC aren't in Florida.  It would be about 92 in your house today.  Can you say "fires of Hell?"  devil
  • TaozTaoz Posts: 10,368
    Are you in a submarine or something?
  • PetercatPetercat Posts: 2,324
    F'd Up Beyond All Recognition.
    First heard it in the Army, usually when a Hudson High* Lieutenant tried to do something hands-on.
    Learned in College Criminal  Justice class that F*** started as a courtroom term for rape because the phrase "Forced Unlawful Carnal Knowledge" was improper for use in the courtroom. It gave people the vapors, or something.
    About as credible as anything else heard in college, I guess.
    *West Point
    IBad day, good computer tech. I tried to clone an SSD, and my computer wouldn't boot up afterwards. Not even the boot menu. Power on, fans spin, perpetual black screen. Took it to the shop, tech told me that my expensive motherboard had fried. He called up Amazon, we chose a better (still expensive) one and ordered it for me, with zero markup. Then asked if I wanted him to install it! Will (should) have computer back Tuesday. More PCIe slots, more SATA connections, now I can have more internal storage!
    Would have installed new board myself, but he'll reinstall Win7 Pro for me, just in case it needs fine tuning.
    Told me this was the third motherboard he'd seen fried right after use of Acronis to clone a drive. I'd used it before to clone an SSD for my laptop. Oh, well.
    If it weren't for the thunderstorms, I would have taken a week away from Studio to tour on my motorcycle. Poor timing. But Autumn is coming!
    edited July 2019
    Should not be possible for software to damage a motherboard unless it is messing with the BIOS in ways it should not do, but I doubt that a company like Acronis would do that. Can't find anything on google about Acronis and fried boards either.
    Post edited by Taoz on
    Taoz said:
    Should no be possible for software to damage a motherboard unless it is messing with the BIOS in ways it should not do, but I doubt that a company like Acronis would do that. Can't find anything on google about Acronis and fried boards either.
    I have no idea, could have been a coincidence.
    is there a quick test i could do in the morning to find if i'm brain dead for the day?
    in which case is safer to stay home
    a simple math problem?
    like is paying 24.99 for 3000 crowns.
    a better deal than paying 40 for 5,500 crowns?
    or a philosophical problem?
    like the existence of depeche mÖde
    or like explaining to management the printer or parts they want is obsolete
    the county doesn't believe in maintaiing shock absorbers on the paratransit busses.  feel sea sick woes
    and what does dragon3 have to do with hoof and tusks.
    had a moment of near hard attack thinkin new dragon was out.
  • starionwolfstarionwolf Posts: 3,670
    edited July 2019
    I am going to be busy this weekend because I need to retype part of a text document.  I found a backup copy but it does not have my new text.
    Post edited by starionwolf on
    edited July 2019
    First Complaint for Friday: Hair is the cause of many of my rendering failures. Hair styles do not be conducive to poses other than upright.
    Note to Self: Rotate Sets!
    Strike that... it won't work... I growl at thee hair... grrr grrr grr
  • Richard HaseltineRichard Haseltine Posts: 111,715
    Are you checking the morphs? Also, dForms are your friend - especially combined with weight maps
    edited July 2019
    Yes, checking the morphs, checking them twice... gonna find... wait... wrong job...
    I'm still learning my way around. I'll add dForms and weight maps to my to do list. (Yesterday I learned how to make a harrowing hall of mirrors.) [All the images so far have been nudes so I can't share my madness...]
    My big thing right now is to put every outfit on my models and decide I don't have a thing to wear... I mean my models don't have a thing to wear... I haven't found the Genesis 3 to RL tutorial yet.
