Windows 10
I had to upgrade to win 10 at home hex will not run took it to work and installed on the same OS and it works... what to do ????
  • AscaniaAscania Posts: 1,858
    Instructions unclear, duck stuck in fridge.
    Hex works one Win10 without issue.
  • ViallyVially Posts: 348
    re-install Hex on the home PC. Windows 10 has a bunch of shared files that hex no longer knows where they are do to registry setting on locations.
  • My Win10 machine is set to Admin. Hex installed and runs just fine.
    Note that there's a difference between using an Admin account, and running a program (e.g. Hexagon or its installer) with the "Run As Admin" function. Some programs are known to act up with one or the other.
    Hexagon is profile-smart when it comes to installing. "Run as Admin" is a bandaid rather than a cure.
