Remember, "There's Always Another Sale™" (Report sales errors here.)
Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
It's working now, thanks!
Thank you.
Can you even possibly imagine trying to shop on Daz without being in the forums and visiting this thread?
Considering they have over 2.000.000 users, a lot probably do.
I recall that 2,000,000 number was the number of people that had downloaded Daz Studio. I suspect the number of active shoppers will be and order of magnitute or two, less than that.
Hello! This is my first post here, and so I hope I don't make an idiot out of myself, but I can't figure out this current sale... As I understand it, if I purchase one of those new releases on the "Vendor Fast Grab" sale, I should be able to receive 70% off on items in the catalogs featured at the bottom of that page, but the only discounts I'm seeing are on the new releases.
Is there a possible issue with the sale, or is this something to do with me not understanding the rules?
Thanks in advance!!
What do you have in your cart?
Have you put the items in the cart? You will only see the 70% discount in the cart (if you have one of the listed new releases in the cart, too).
I'm having the same problem whenever I add Genesis 8 Female Body Morph Resource Kit 2 to my cart. If I remove it, the sales on the other items come back.
Never mind, it really helps if you read the fine print :D the vendor sale is limited to 7 items.
Holy cow, this was it! Thank you! I suppose I've learned a valuable leasson here, as well. I never read fine print, just full steam ahead haha!
Thanks all!!
Reading the fine print is definitely a good habit to have here, sales often have special conditions.
Welcome and don't worry about making an idiot of yourself- it's a requirement for posting on the forums....(I should know.)
The Meeting Lodge ( https://www.daz3d.com/the-meeting-lodge ) has lost both its PC+ discount and its new discount.
Garden Flowers - Wall Flowers ( https://www.daz3d.com/garden-flowers--wall-flowers ) has lost its new discount
So, all the other promos except Jane 8 are gone, and the One-Day Megafastgrab is, well, one day. Something big starting tomorrow?
Reported.
And now fixed. Thanks, Cris
Today's 1 DAY ONLY Mega Fastgrab has a sneaky 7 item limit...
New purple banner for X amount off Daz originals gives two coupons which appear to be an either/or deal, can't seem to use both on consecutive orders, so choose wisely.
I just used both on separate orders
I used one and tried the other - didn't get an error, so it might be worth a try in the cart.
I used the same coupon three times, and now it's not working the fourth time on similar items. Is this limited to just three uses, or should I be able to still use it?
In the small print it states that the first coupon ($5 off ) is usable once only, whilst the second (10$ off if new release in the cart) does not state a limit, so can be used as many times as desired until tomorrow. That is the behaviour I am seeing.
I was able to use both. I used the $10 coupon one first to grab a couple items I'd been wanting for a while (one the new release, and one the DAZ Original), and then I did the $5 one. As a note, the $5 one doesn't appear to exclude Fast Grab like some of the sales do, or at least it didn't with the Willow Tree.
Thanks for the coupons, Daz! :-)
Hmm. I'll try with different items. I couldn't get it to work a fourth time.
Nope, I can't get the $10 coupon to work the fourth time, not even with different items.
Same here. For me the $5 coupon only worked once and the $10 couupon only worked 3 times.
Side note, just because I was curious to see what the actual sales prices would be for the "Are You Feeling Super" promo, I found that if you have the four super items in your cart that should get Related Items for 70% off, it kicks out the sale price and makes it back to normal. (This is without the $10 coupon, though I did test it with it first). (I tested this with the Karen 7 bundles).
It appears to keep at least partial sale price (I didn't run calculations, only watched to see the general change) for three or less of the Super new releases, and it's the fourth item that causes issues.
Not sure if it was just me, or if it's a glitch that should be reported.
The 70% off related items if you have 4 new Super items in your cart doesn't work at all for me... I've tried various items of the related page, no joy, just the PC discount.
Some Free Stuff...Just Because promotion. On the first part of the coupon, there's no requirement other than Daz Original yet it fails. On the second code part, even picking something new in addition to the chosen item also fails. Not sure how to make either coupon work in this matter.
Okay, the $5 one seems to only work on items over $5, so it's not actually totally free. The second coupon doesn't seem to work at all :(
It worked for me on this item:
https://www.daz3d.com/weeping-willow-trees
Which was 4.49 at the time (although it is showing full price now).
