A.I. based Open Source De-noiser for Daz Studio PC and MACs
mCasualmCasual Posts: 4,607
edited January 2021 in Freebies
so it's a front-end for Intel Open Denoiser and Imagemagick-convert
it can process one image or a sequence of numbered images ( videos! )
https://sites.google.com/site/mcasualsdazscripts9/mcjdenoise
new for 2021 - Mac Compatibility
January 19th 2021 15:15 the file type for imagemagick and Intel Open Denoise was changed from (*.exe) to "Any File" for MAC issues with opendenoise which is extensionless
January 21st 2021 mcjDenoise2021ForMacs
there's a new version of mcjDenoise, my Daz Script that lets you use Intel Open Denoise to A.I.-Denoise your renders, for now i only have an antique macbook so apparently i cant run openDenoise, but your modern macs should , there's also the version for PCs https://sites.google.com/site/mcasualsdazscripts9/mcjdenoise
i had to figure out the not-well-documented execute-permissions of Daz Scripts, then use the .command extension then avoid quotation marks when running that .command file
Post edited by mCasual on
«13456
  • Silver DolphinSilver Dolphin Posts: 1,640
    Thanks, this is great. I this is gonna be very useful.
  • Hemi426Hemi426 Posts: 231
    Hmmm,
    when I try to execute the script, I receive this:
    2019-06-21 16:46:15.158 Loading script: C:/Users/oliver/Documents/DAZ 3D/Studio/My Library/Scripts/mcasual/mcjDenoise.dsa
    2019-06-21 16:46:15.170 WARNING: Script Error: Line 144
    2019-06-21 16:46:15.170 WARNING: ReferenceError: Can't find variable: edBdFilenameIn
    Any idea?
  • mCasualmCasual Posts: 4,607
    edited June 2019
    i will repair it
    i probably created this variable, changed its name, then since i didnt exit Daz Studio, Daz Studio  didnt see a problem about this variable
    ok i found the problem ... updating in 5 minutes ...
    Hemi426 said:
    Hmmm,
    Any idea?
    edited June 2019
    UPDATE - DEBUGGED - UPDATE - DEBUGGED - UPDATE - DEBUGGED -
    ________________________________________________________________________
    Version History
    June 21st 2019 7:00AM - Release
    JUN 21, 2019, 11:49 AM - V2 - CORRECTED A BUG PREVENTED THE PROGRAM FROM STARTING
    Sure is worth the trouble wouldnt you say?
    1102 x 570 - 145K
    Post edited by Cris Palomino on
    Works! Thank you!
  • DigiDotzDigiDotz Posts: 515
    awww....
    Resolution: 1000x995
    Initializing
    Error: SSE4.1 support is required at minimum
    on core2quad  laugh  New pc soon though so I will be able to use it then. Thanks!
    edited June 2019
    ah i see it mentioned here indeed
    https://www.foxrenderfarm.com/share/post-id-1584
    i also have a project for a trainable neural-net plugin for daz studio i want to make, the Intel and Nvidia denoisers are trained neural nets
    mine could be trained for anything, animating self-driving cars or actors
    i worked on that project a bit, trying different libraries but didnt complete that yet
    but but i did make a shallow-neural-network script+app here: https://sites.google.com/site/mcasualsdazscripts9/mcjnn
    DigiDotz said:
    awww....
    Initializing
    1192 x 670 - 47K
    Post edited by Chohole on
    surprise You could train it to make figures auto-dance! wink
    edited June 2019
    Version 3 has a new time saving option
    https://www.deviantart.com/mcasual/art/version-3-of-mcjDenoise-802746178
    version 3 of mcjDenoise can auto-name the output image
    so if input noisy image is c:\pics\InspectorGabrielleIsNotAmused.jpg, the output file will be named c:\pics\InspectorGabrielleIsNotAmused_out.jpg
    baaaaad facebook for overcompressing images
    1054 x 397 - 52K
    Nice update. Thank you
    edited June 2019
    10 iRay render passes then denoised using mcjDenoise ( Intel Open Denoise ) https://sites.google.com/site/mcasualsdazscripts9/mcjdenoise
    1800 x 1080 - 280K
    1800 x 1080 - 3M
    I wonder why this is not just integrated into daz studio? It would save alot of people time rendering iray.
    well in daz studio 4.11 the one released a week ago, there's a post render denoiser by nVIdia/daz3d it may be only for CUDA/gpu ... i dont know if it works on amd ati cards and CPUs i didnt seriously test it
    Yeah, I know>>> I wanted the independent one from Intel. Works better!!! The internal nvidia one slows down render and does not work as well!  Thank you for your hard work this works great when I'm done with a render I just run it thru your script and presto it's done. I also made it part of my top custom actions script menu.
    edited June 2019
    everything but the kitchen sink
    222 iRay passes + intel open denoise
    2000 x 1200 - 404K
    edited June 2019
    The virtues of cherry ice cream crystals
    Peachy finds it cute that Gabrielle thinks the "cherry ice cream crystals" can "activate her DNA" and generate "3D body upgrades". Well it's cute but it's also true.
    (240 spp + mcjDenoise )
    1920 x 1200 - 407K
    1920 x 1200 - 213K
  • IvyIvy Posts: 7,165
    wow thank you very much
  • Fabulous! Thanks very much! :)
  • JackyBrownJackyBrown Posts: 585
    edited June 2019
    Had a little trouble to get it working, but it was worth the effort... it works like magic! Thank you very very much! This is soooooooo useful!
    Before        After
    662 x 331 - 167K
    Post edited by JackyBrown on
  • Thanks very much !
  • lukon100lukon100 Posts: 849
    I'm trying to figure out how to install Intel's denoiser. The instructions are very confusing.
  • y3kmany3kman Posts: 852
    You just have to unzip it somewhere and point the script to its location.
    Speaking of ImageMagik, what's a good setting for the converter to cut down the size of the denoised image? I usually get around 1.5x the original file size if the source is a PNG.
    I just use Photoshop or GIMP for that.
    edited June 2019
    The effect is really amazing!
    EDIT: Ok, I noticed the floating sandals in the back!
    1920 x 1440 - 1M
    1920 x 1440 - 602K
    Post edited by Hemi426 on
  • JOdelJOdel Posts: 6,322
    Looks good. Does it run on a Mac?
    Current Macs are Intel, but they aren't Windows.
  • FirePro9FirePro9 Posts: 456
    Looks like the ImageMagicK executable has changed from convert.exe to magick.exe (win64).
  • I couldn't find convert.exe either but if you tick the box that says install legacy components when you first instal ImageMagicK it will be there.
    edited July 2019
    one could install a version of imagemagick in a folder anywhere
    and use the convert.exe in there for the needs of this daz script
    i downloaded the imagemagick installer from here
    https://imagemagick.org/download/binaries/
    and installed it in f:\\imagemagick69105 so i can remember the version
    i unselected the extras, this imagemagick will be for mcjDenoiser
    1000 x 1500 - 3M
    1000 x 1500 - 324K
    584 x 438 - 58K
    424 x 311 - 30K
     I'm a lazy bum and just use the portable version of ImageMagick.
  • mindsongmindsong Posts: 1,743
    This and the LUT tool are greatly appreciated, as are all of your gifts.
    Maybe it's time for some more of us to kick some beer money your way via paypal, eh?
    So, how about it folks, this week, rather than buy another fastgrab item that you'll probably never use. Kick a few bucks to mCasual at the link at the bottom of this freebie page:
    It feels really good to do so, and the effort, wit, and wisdom mCasual shares for free is amazing - just look at all of the stuff on his site!
    (thanks mCasual!)
    --ms
