Using the New Forums (In Progress) - Please Post Questions and Issues Here !
17072747576
  • eyet33theyet33th Posts: 112
    it really doesn't seem like this thread is paid attention to.
  • DarkElfDarkElf Posts: 518
    I get emails from DAZ3D showing contest winner pics but for as long as I have been here I have never figured out where to go to participate in any contests. How does one enter?
  • Daz Jack TomalinDaz Jack Tomalin Posts: 13,849
    Do you mean the Platinum Club ones?
    You can find them stickied at the top over in the Members Only forum
  • Nyghtfall3DNyghtfall3D Posts: 813
    If you're not going to fix the board to eliminate auto-logouts, then I suggest you remove the "Keep Me Logged In" button because it obviously doesn't work.
  • kyoto kidkyoto kid Posts: 41,984
    ...so why am I suddenly unable to embed videos in posts?  Others seem to be able to do it.  I tried everything I could think of including using the paste/linking tools, and all I get is just the link not the actual video window.
  • 3dcheapskate3dcheapskate Posts: 2,728
    edited July 2019
    I think it depends on whether you let the forum automatically apply the link...
    ...or whether you manually set the link
    https://www.youtube.com/watch?v=QereR0CViMY
    Let's see how those look when I post...
    Edit:Yes, that's correct. Here's how I did the post:
    918 x 460 - 50K
    Post edited by 3dcheapskate on
    ...I tried both, and still only the link shows.  For some reason the Form software is refusing to do the auto application when I simply just past the link in the edit window.
  • IvyIvy Posts: 7,165
    edited July 2019
    Hey KK click the  source button and place your youtube link between the <p> brackets  then click post comment , when you post the daz forum embeds the link as a video . thats how i do it anyway
    Click to play animation
    I hope that helps
    1708 x 479 - 76K
    Post edited by Ivy on
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,983
    @Ivy. Love this!
    Thank you very much ALLIEKATBLUE,smileyheart
    I hope that helps
    ..that's new.  Never had to do that before but Ill give it a try.
    There must be some subtle changes being made to the site software or it's compatibility with various browsers as I also no longer can log into the DIM even though my sign on data has not changed.
    edited July 2019
    That has been the way I always have posted my animations since the new forum was developed., for some reason my firefox does not see videos posted using the link manager all I get is the link, so i always posted them in source code.
    I can't say whats up with your dimm I have had no issues so far, I downloaded the new version 4.12 beta last night and I just download some pose set through dimm i bought tonight so I can't give you any help there sorry indecision
    edited August 2019
    ..I've been on Chrome for a while and it always worked when i simply pasted the link to the video into the body of the post.  Now all of a sudden it doesn't.
    Yeah, I submitted a tech support ticket about the DIM issue. Must have missed their office hours as I got an email mentioning they don't have a 24 hour help service.
    Post edited by kyoto kid on
    edited August 2019
    Same as before but using Chrome - it says it's Version 75.0.3770.142 (Official Build) (64-bit).
    First letting the forum do its automagic...
    And secondly by manually adding the link to the text...
    Edit: after posting this Chrome updated to Version 76.0.3809.87 (Official Build) (64-bit) - it did that when I went to check what version it was.
    edited August 2019
    ..test:
    Direct paste int edit window: only the link.
    using the link button: only the link.
    Using the Source button like Ivy suggested:
    Strange that the behaviour would have mysteriously changed as it worked only a couple weeks ago when I simply pasted the link directly..
    kyoto kid said:
    ..test:
    I always used the source to pos my videos , The posting a direct link for a video never had worked for me.   & At Renderosity you have use the complete YT embedding html tag to embed videos in their forum,  I work on a lot of web sites fixing designs issues & most common issue is a change in how the users browser reads a site, because of a new jquery codes,or new security layer, updating SSL certificate, or a dated head tags with expired data  , new software upgrades even some hardware upgrades as well,  anyone of those things can effect the interactions of a website. I have not heard or read anywhere anything about daz updating their forum so maybe it had to do with a browser update.
    and if you use Foxfire since version 65.1  The Javascript off by default, so you might check something like that if you use streaming gaming or Java services like that  .
    I know I am not having any issues with The Daz Site or Dimm,   sometimes  if you change to a new a ISP you may need to clear your connection login cache to make sure you getting the full read write/connection unless you have a set proxy on you ISP , are you using a firewall or a AV? those buggers are always giving me issues viewing & downloading from sites. my AV hates Rendereotica   I have to turn Kasperkey off to use Dimm too, so maybe it one of those issues .
    Those are just some random issues you can check if you have not already. smiley
    ...I just find it odd (and somewhat annoying) that few weeks ago pasting the link into the post body worked fine, now nothing.
    About the same time I started having issues with the DIM.
    Its properly the Nargles wink
    ...I think it's just sloppy code. I have the Magento programming book and it is, well, ugh.
  • TaozTaoz Posts: 10,280
    If the link shows as a normal link (underlined, blue), try right clicking on it and select "Unlink". Then it should work.
  • RAMWolffRAMWolff Posts: 10,363
    edited August 2019
    Might be Opera but maybe not but the bookmark stars used to be gold now they are showing as the same color as the non bookmark stars.  So while the bookmark stars are smaller it's still hard to discern which is which when your bookmarking a new thread you want to keep tabs on....
    OK, I think I found the problem... seems that the site darkening plugin that I use (Sauron) is the cause.  Wasn't like that before so I think they updated the plugin and it's now decolorizing that particular set of site elements.  Grrrrrrrrrrr
    Post edited by RAMWolff on
    edited August 2019
    ...test:
    Ah, it works.
    Just to clarify, the forums dont run on Magento.
    ...though I get a Magento icon on the tab of attached images that I open.
    Yea, I assume (as I'm not 100%) it's because thats the same web host it's being served from.  But still, the forums aren't built on Magento.
    Yes,  because the galleries are on the magento side all images are stored there.
    I hate to say this but that's just a convoluted mess.  You have Cloudfare (which is always lagging), you have Magneto and you have what ever the store is built on and then what the forums are built on and then the Help pages, whatever those are built on .  What a frigging mess.  Can't DAZ find one package that covers all the areas?
    No wonder there are so many complaining about spurious log out issues (including me)
    edited August 2019
    Only the forums are non Magento.  If you remember when we first changed form the old old forum and store,  the one stuck together with duct tape, chewing gum and string, we had a magento style forum and no one had a good word to say about it.  So a search was made,  a different store software was found  and the change was made with no loss of posts, or post counts. All you lost was little green boxes.
    Post edited by Chohole on
    I'd be willing to bet my mortgage there isn't just one solution that would meet all of those very specific needs.
