Wacky Modelling ~ In Carrara ~
1…2425272930…100
    edited June 2019
    Thank you
    Sees oreos and feffenues cookies
    nomms checkers board
    Post edited by Mistara on
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited March 2021
    Post edited by Persona Non Grata on
    edited March 2021
  • Bunyip02Bunyip02 Posts: 9,345
    edited June 2019
    Selinita said:
    Building A Simple Triangle
    How would you do it..? (See attached PDF for how I did it - could you imporove on the method?)
    I used the Text tool with Wingdings 3 font
    2262 x 1046 - 193K
    2265 x 1035 - 958K
    Post edited by Bunyip02 on
    edited March 2021
    edited March 2021
    edited March 2021
  • DiomedeDiomede Posts: 15,464
    edited June 2019
    Sounds like a quick job for the spline modeler, using the COMPOUND function and controlling bevels.
    But within the vertex modeler, without yet looking at the pdf, here is how I did it.  I decided that my desired result was a triangle that could be used with smoothing, and that means the corners have to be braced with lines.
    - In the vertex modeling room I inserted an oval and set the desired number of sides to 3, which yields a filled triangle.
    - I then used the tessalate menu to divide the triangle mid edge to center, which yields quads.
    - With all selected, I then used shift-extrude to get a middle area polygons and edge polygons, if that makes sense.
    - I deleted the middle polygons.
    - I selected the corner lines and used extract-around to create lines bracing each corner.
    - I selected all of my hollow flat triangle and added thickness.
    - I used control-extrude to so that the triangle was four polygons thick (allows each edge to be braced independently).
    It would be easy now to morph the triangle to make the faces, legs, or corners more round.
    Even with smoothing ramped up to 3, the triangle holds its basic shape well.
    1313 x 644 - 88K
    1092 x 758 - 50K
    1260 x 799 - 87K
    1355 x 786 - 81K
    798 x 747 - 41K
    872 x 624 - 34K
    1010 x 757 - 66K
    1196 x 774 - 89K
    1242 x 832 - 103K
    640 x 480 - 11K
    Post edited by Diomede on
    edited June 2019
    And I just looked at Selina's pdf.  Pretty much the same, except I used extrude after adding thickness, while Selina selected the edges and used quick filet.  Model ends up similar, but can see that Selina's has the roundness baked in, while mine is more flat.  yesyes
    edited June 2019
    splines very mysterious
    prolly the way to go for making a slinky?
    taper scaling?
    edited June 2019
    Here is a way using a cross section and a polyline.
    - in vertex modeler, use the pen and polyline tool to draw a triangle on a drawing plane
    - insert an oval and choose the number of vertexes for the cross section
    - shape the cross section if desired
    - use Construct : Sweep, makin sure link polygons is not checked.
    - use select edge tool to just select the corners
    - use extract around to get the support braces
    - apply desired smoothing
    1517 x 739 - 94K
    1521 x 787 - 115K
    1310 x 736 - 95K
    640 x 480 - 11K
    taper scaling?
    For slinky, could use spline modeler.  There is a spiral preset that would be good for a slinky.  Could also use a cross section and a polyline in the vertex modeler similar to 2nd method I did for triangle.
    Here is a slinky using (a) vertex room cross section an polyline curve, and (b) spline room spiral preset
    903 x 829 - 83K
    1478 x 699 - 122K
    slinky  thanks
  • StezzaStezza Posts: 9,265
    great inputs...
    I would just use the rack of eye and draw a polyline triangle extrude add thickness, extract around the corners and then smooth....
    for the slinky I think I would just use the spring plugin by sparrowhawke and adjust the settings to get me a slinky. devil  cool
    edited June 2019
    rainy Sunday downunder today... so I have done some wacky modeling on Woody and also boned him!
    up to this stage..
    800 x 600 - 244K
    Post edited by Stezza on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,678
    Boned a Woody blush
    you should be proud
    up to this stage..
    Love the hat !
    edited March 2021
    edited June 2019
    starry food... mmmmm .... for our star models yes
    modeled a wacky spaceship for Buzz to buzz around in.. smiley
    800 x 600 - 224K
    edited March 2021
    Model->Crease Edges is probably your best bet.
    edited March 2021
    Selinita said:
    Nice ToyStory models ...
    Still at basic - proper polyflow, is there a way to cheat?
    image image image
    Smoothing: 1 Smoothing: 2 Smoothing: 3
    1. Two octagon tubes manually joined by edge extraction along,individual vertices aligned before welding and thickening (if that makes sense)
    2. Said tubes now one contiguous mesh with center diagonals filletted by odd number (1)
    3. Ditto, center diagonals filletted by even number (0)
    Starting reading my new book - Carrara doesn't offer Edge Collapsing (there are alternative ways of doing this though it just takes longer and I'm lazy) that I can find. Anyone know any better?
    Select loop dissolve?
    edited March 2021
    edited March 2021
    edited March 2021
    edited June 2019
    Two wacky models today... Duke Caboom and his bike !!
    640 x 480 - 206K
    Had to search for Duke Kaboom, but so glad I did.  Fantastic job on the models and textures.
    edited March 2021
