HELP! Denoiser not working (sometimes)
MortzeMortze Posts: 186
Hello folks,
Perhaps someone could help me with some annoying problem I encounter in DAZ Studio 4.11 Pro Public Build. (I render with 2x GTX 1080)
When the scene has more than two Genesis 3 figures, sometimes with only two G3 figures, the Post Denoiser doesn't work when rendering. I've checked and triple cheked that it is enabled, default settings, and I render at 1920X1080 resolution.
It simply doesn't work, it renders normally as if it was disabled, with the grainy rendering.
Has anyone encounterd a similar problem? Is there a way to fix it? An does someone knows why it happens?
(I run DAZ on a Windows 10 64bits computer with 48GB RAM)
Post edited by Mortze on
  • Richard HaseltineRichard Haseltine Posts: 110,355
    It seems unlikely with 8GB cards, but hav you checked it isn't dropping to CPU? The denoiser is not supported on the CPU.
  • MortzeMortze Posts: 186
    It isn't. The CPU is unchecked.
    Both GPUs and the Optix Prime are checked.
    But are they being used? If they run out of memory (and OptiX Prime does, I think, increase the demands) then Iray will drop to CPU regardless of the check boxes.
    They are always being used I think. Is there anything in the log that points out they aren't?
    Yes, once the render finishes the log will contain a block listing how many iteratioins each device performed.
