the ironman free promotion fixed now.
13»
    swissmiss said:
    Just a follow up... I actually got it working by adding a second item to my cart. My ironman item finally appeared! I deleted the extra item, added the promotion code for the freebie and... PRESTO! We have liftoff!
    It's a pretty common error, it happens when the store loses its electronic marbles and gets confused about your state of logged-in-ness. And yes, that is how we're supposed to fix it.
    <headdesk> What a way to run a railroad...
  • Still not working here, I've tried adding a second item and removing it, but no. None of the others are working this morning, either. :(
  • LeanaLeana Posts: 13,138
    The flash sales probably stopped at Daz midnight, which would have been roughly 15 minutes before you posted. Unfortunately banners sometimes don’t disappear immediately after the changeover.
  • EllessarrEllessarr Posts: 1,395
    well to be fair i was able to get 2 free stuffs, one for each promotion", ofcourse the first one i had to wait for a "lonnnng" time until they could fix but the second one was pretty fast, as soon i saw it i was able to use the code and worked fine.
  • LinwellyLinwelly Posts: 6,070
    Yes that was the trap I ran into as well
    Yeah, that's the problem I always have, since I'm in the UK. If I log in first thing in the morning, the banners are still up but the promotions never work. And the banners were up for a fairly long time until I got frustrated and stopped trying. As an ex ecommerce web developer I know that kind of thing is easy to fix, but it really has a negative effect on customers' goodwill. :(
  • TaozTaoz Posts: 10,308
    edited June 2019
    Yea, I wonder why they don't fix those easy-to-fix small annoyances first of all. The gift card code input field e.g. used to throw an error if the code had invisible leading or trailing spaces when you copy/pasted it,  so people were complaining all the time that their codes didn't work. Can be easily fixed using Trim (one line of code) - I believe it has been done now but the problem was there for several years.
    Post edited by Taoz on
