DAZ DIM Installs to Default instead of Directed Directory
Installing DAZ 4.10 in a new computer. My C: is a solid state that I want to keep clean, using my D: for programs and content.
In DIM I changed configuration settings for Download, Installation and Applications. See attached screen clips.
I also changed the location in Content Directory Manager. See screen clip.
During content installation it installed to default C:\Users\Public\Documents\My DAZ 3D Library instead of my D: drive.
I believe DIM/Gear/Applications was blank when I started the content installation.
My question is: Can I simply move to files to D:?
Thanks for your time.
Tom
  • Richard HaseltineRichard Haseltine Posts: 111,465
    Ypur content path is still the recommended C:/Users/Public/Documments/My Daz 3D Library/ - you need to add a new path (+ button) and set DIM to use that (Current, at the bottom of the Installation tab). Also, it looks as if you installed DS to C: before you chnaged the paths for software - uninstall and reinstall (with DS closed) if you want to change that.
  • tomsfo1tomsfo1 Posts: 87
    Thanks for a prompt response. I'll give it a try a little later.
    Hace a good day.
    Thanks again Richard. Looks like I got it the way I want it now. I appreciate your time in responding.
    Tom
