I had an idea for this based on the screensaver on the TV in one of our office conference rooms. The inspiring image was a top-down shot of a very complex looking highway interchange. Since I am working in a digital world and not limited by physics I decided to take it to the next level.
"Infinite Highway"
The roads are a pretty basic vertex model that I just duplicated a couple times to make longer; each road is made up of 5-7 duplicates of the basic section. I added spot lights under the lamps then duplicate the road a whole bunch of times, rotating it, changing the depth, and adding bends and twist modifiers to some of them. The fog is a volumetric cloud and there is a little bit of camera depth of field blur and some glow on the whole thing.
The car lights are just strips of the road that I duplicated and set to a different material zone so that I could apply different glows to them and are part of the base road section model.
For postwork I adjusted the colors a bit, pumped up the bloom on the lights, and increased the saturation.
Oh, wow MDO2010 - that's beautiful! Amazing what can inspire us. I can't say for anyone else but...you never know when or where an idea will come from. Often for me it's just like that...see something when I least expect it and suddenly a whole story unfolds.
Catching up on the thread. Until now, only had time to pop in and out quickly.
- Selina - thanks for the fog tip. Great effects.
- Bunyip - MadMax image looks ready for another rampage. Car probably boobytrapped. Good one.
- Mmoir cafe - great camera angle and mood. One of your best.
- Stezza - the first power drill looks exactly like the ools used by my dentist. Wonderful expression.
- Foot on legos - ouch, I bet most of us have had to deal with that one.
- Mystarra - always enjoy watching the late, great, Cripeman. Are there backups?
- UnifiedBrain - Soggy Bottom is tremendous. It is a nice set, but you really enhanced everything.
- MDO2010 - Love how you took such simple elements and put together an abstract complexity. Great shader work.
MDO2010 - Awesome, although I would hate to be the designer for all of the on/off ramps, signage, and road markings that would be needed !!!
Diomede - thanks. Super Lego man needs a Super Cape !
Stezza - thanks. Love your critters in your Dominoes render !
And another one from me - Bridge Troll, the dangers that often lurk under structures
The bridge indicates the structured environment being a safe place to cross. The Troll indicates the unstructured troubles that can occur in our supposedly structured lives.
The female is LaRoo2, from RDNA and Daz. Love those older gals. The shorts are LaRoo clothes, and the top is from V4 Barbarian. Hair is Radiant Jaguar.
In the background is After the War from Stonemason several diffrent Ron's PSE brushes.
For the monochrome-ish look (LaRoo), I used the Anguish filter in GMIC. It provides an interesting darkening/smoothing effect., with several control sliders to play with:
Among them are Smooth amplitude, Noise amplitude, and Sharpen amplitude. Small adjustments can make great changes, so it takes some patience to work out the best combinations.
A bunch of postwork on the background in PSE. :) In the renders below, I left in the one which is 95% Carrara.
In the background is After the War from Stonemason.
Processs include Carrara clouds and Carrara text. For the monochrome-ish look, I used the Anguish filter in GMIC. It provides an interesting darkening/smoothing effect., with several control sliders to play with:
I had to use PSE for about 5 minutes to fix some unruly surfaces (common when you use complex filters). Otherwise, it was more than 99% done in Carrara.
Great seeing some older content being used, very nice render as well !!
Very high-quality render, Bunyip. I had the Cafe in my wishlist for many months, but never pulled the trigger.
+1
Oh, ouch!! Think we all can relate to that image. I love it.
Great use of putting together cubes and cylinders to create a model Stezza!
Thank you Selinita!
Beautiful image Bunyip!
could use one of those for my flying fortress
Thanks UB, Vyusur, & DesertDude, most of the work is mmoir's !
"Infinite Highway"
Scene Setup
Render
Render with Postwork
Looks like a painting that should be in a museum.
Thanks for the explanations. Brilliant
Sorry if I missed anyone.
More Awesome Lego WIPs, because...
Everything is awesome!
Procedural shaders for first 2. Use Carrara's 3D Paint tool to paint a face on the third WIP pic.
@MDO2010 this is how imagine the USA to be like ... multi lane highways with things flying everywhere all over them.. great start
awesome Lego pieces and lego peoples... may have to have a seperate Misty Lego Challenge thread just for all the Legos
great use of your Butte @Bunyip02_Carrara
here's a quickie for a Sunday arvo....
modelled the dominoes using a boolean operation... yay
also used @Philemo_Carrara free light dome plugin set for lighting
Building Dominoes
Cyclopstritch Parade
Because parades are structured. The cyclopstritch cavalry veterans are paradingwith their Carrara 9 power member regalia (see shields).
Simple scene. Rendered out a backround then replicated the cyclopstritches over a shadow catcher.
- Stezza - your ants are awesome as they play dominoes. Wonderful faces and poses.
- Bunyip - if the person wants to cross, must answer questions three. Awesome render.
Sweet! Great modeling job Diomede. Great hair, and Carrara 3D paint. yay!
Depending on where you live in the US it's more like a multi lane multi billion dollar parking lot.
Great image Stezza! I agree, love the facial expressions and poses. Dominoes modeled with boolean operations?...you are far braver than I am.
Nice work Bunyip! Great composition and nice lighting.
The Carrara 9 brigade! Bring 'em on!! Love that model, so clever. Thanks for sharing the technique, you rock.
made a video on how I modelled the dominoe
@Diomede_Carrara I wonder if cyclopsemus would be more terrifying! ... love your thought patterns
@bunyip02_carrara ... bridge over troubled waters by the looks of it !! eeeek! in need of the cyclopstritch cavalry veterans to help out the damsel
I can't spell today!After the Apocalypse
OK, got some ruins. :)
wow :) love this thread,
sorry some bad things in real life are taking me away at the moment - apologies for not participating more,
must say @DesertDude is doing a wonderful job
And they are all in step as well, excellent !!
Thanks, another one for the tute library !
Sending man hugs your way, hope you get some play time in !!!!!
