Anaglyphs - red and cyan glasses required to view.
135
  • AtlantisAtlantis Posts: 133
    Alien Corridor ( inside one of the Derelict's arms )
    1180 x 574 - 443K
  • David BrinnenDavid Brinnen Posts: 3,136
    Thank you @lantis. Again, you have tackled a difficult subject for an anaglyph. I've spent most of this evening fiddling with this scene to get a decent sense of depth.
    750 x 750 - 693K
    @ David... Watching this anyglyph made me almost step into my monitor ... very convincing depth
    How could I missed this one... that's a excellent anaglyph
    Horo said:
    Yet another try, colours work quite nicely. Original here http://www.bryce5.com/details.php?image_id=3014 The facade is from Urban Future http://www.daz3d.com/shop/urban-future/ and the toon bots from here http://www.daz3d.com/shop/toon-bot-chomper/
    Had a go at a tunnel effect. This scene is taken from the Scene Converter. Converted it in a different way now.
    750 x 562 - 745K
    Whoa...love it !!!!
    How do you feel about creepy crawlies?
    750 x 750 - 926K
    Not keen on bugs? How about cakes?
    750 x 750 - 643K
    @ David.... Both renders are awesome..... the crawlers one as special... the one crawling over the edge gives extra 3d dimension
    Here a experiment with some M.C. Escher like object...
    1189 x 557 - 386K
    edited July 2012
    And another M.C. Escher experiment
    1186 x 548 - 570K
    Post edited by Atlantis on
  • HoroHoro Posts: 11,738
    Oh, the Escher objects renders are beautiful. I thought an anaglyph would spoil the illusion.
    edited July 2012
    Another one....
    (Its very complicated to create these lot of tweaking different parts, when creating the right side image... to keep the Escher illusion )
    1183 x 572 - 322K
    Very good. As typical for these illusions, onepart is correct, the other part is correct, too. But they are "wrongly" combined. The anaglyph works for the upper and the lower part separately. Only if I look at the whole picture, I get a funny feeling. But then, this we also get if it is not an anaglyph, and is what makes these oddities so charming.
    Interesting @lantis, very interesting indeed. You have done very well to translate these illusions into 3D! The last one is particularly baffling. I like them.
    And another one....
    1200 x 575 - 507K
    In this case @tlantis, the 3D effect - which is working very nicely - is also working very nicely against the illusion, since it shows clearly that the nearest spar has been cut. So swings and roundabouts.
    edited July 2012
    @ David... I Know... I think I shouldn't had add the glass tube in it..drawing these in 2d is much easier...
    1200 x 575 - 795K
    I thought you might know... the fact that it was so clear is at least testament to 3D effect. In this case I am not sure how the illusion in anaglyph form can be achieved. It is an interesting puzzle. And possibly and impossible one?
    edited July 2012
    @ David ... I think your right... it's impossible to get it right in Bryce... I think using 3dmax or carrara where you can morph the critical parts in real time.. it will work better..In these software packages you can select any face or edge or point ... and resizing / morping it instantly...
    If you can see a solution in other software, by fair means or foul, it is usually possible to replicate the results in Bryce - all be it, as said, with some use of a crowbar along the way. In this case though, I wonder if it might be possible to cheat in a different way, perhaps by using alternative models for the left and the right eye, so that the front back crossover for the anomalous parts are hidden in a 3D anomaly. I'll have to ponder this. But as I said, right or wrong, or almost right and a bit wrong, it's still an very interesting topic you have brought up for consideration. Interesting and baffling by degrees. Thanks @tlantis!
    @tlantis - the famous cube. It works on 3D splenditly but it spoils the illusion. We see too clearly how it's done.
    @ Horo... well if it's seen clearly..then this could be used as a tutorial..to build these cubes :)
    edited July 2012
    Well, not THAT clearly. ;-) http://www.daz3d.com/forums/smileys/# (horrible smilies).
    Post edited by Horo on
    Another optical illusion
    ( Sadie character made by me in wings3d, She is from my 3dcommune days :) )
    1186 x 575 - 380K
    Pondered and pondered some more... OK, not impossible but very tricky indeed. Rendered all on one go, with no post work.
    750 x 750 - 698K
    Excellent :)... I found already 5 different way's to create these cubes.. from very easy till extreme difficult...
    and used some of the techniques in my alien project... now the world gonna even look more and more strange..:)
  • shaykallshaykall Posts: 109
    edited July 2012
    My attempt :) just a basic image..
    Need to work on the settings a little more.
    1514 x 885 - 189K
    Post edited by shaykall on
    @ shaykall looking cool already
    @shaykall - parts that extrude from the screen should not hit the picture frame - the flying machine is ok, the mountain is not. When aligning individual pictures, you can move them so that the part that is to appear on the screen plane has no colour finges - i.e. no red or cyan.
    edited July 2012
    @tlantis: thank you
    @Horo
    I see whaht you mean about the mountain hitting the picture frame, I have been looking at your tutorials on the Bryce Mentoring DVD (in fact I have watched the about 5 times already trying to understand and absorb your teachings) And I remember the part about not hitting the picture frame so I will go back to Bryce and redo the images.
    I am not sure I understand this, are you saying that I should make something in the image a target?
    ps: maybe a little off topic, is it possible to make an image (for example a jpg) into an anaglyph image in HDR Shop or another image program?
