bullet physics for DS 1, 2, 3, 4 PC/Win ... teaser
1246711
  • RAMWolffRAMWolff Posts: 10,373
    I have no idea what you just said except for the last line! lol
  • mCasualmCasual Posts: 4,607
    the low down is
    you will be able to install a hinge ( which may be a car axle by the way ) without having to mind how the door / wheel is positioned
    512 x 512 - 143K
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,250
    edited October 2013
    This is awesome, if you can briing bullet type physics into Daz you'll make a lot people happy! Including me!
    Epic work! Be great to see a mac version tho.
    Post edited by Design Anvil - Razor42 on
  • ghastlycomicghastlycomic Posts: 2,531
    Me three!
    I'd love to have bullet physics in Daz.
    Amy yet again serene and completely confident in the safety of the experiment pertaining to hinge2Constraints
    1024 x 1024 - 642K
    I don't know, looks dangerous to me! YIKES!
  • edited December 1969
    hey Casual, just came across this, and it's fascinating to watch the process you're going through. i'm new to DAZ, DS and 3D modelling/animation, but i'm sort of generally aware of toolkits and libraries, etc for game engines. what you have looks pretty good to me.
    i'm on a Mac, so i'm interested to know why exactly what you did is PC/Win only. as far as i know you can incorporate external libraries via the SDK on either platform. so, are you doing any of the following?
    1. using a bullet physics engine library compiled for PC, and most of the scripting/configuration is scripted inside DS, or
    2. are you using a PC-based toolchain and script setup (Javascript?/Python?/.NET?) and then just calling the engine within DS?
    3. something else?
    either way, it doesn't look trivial, but i'd be curious what porting it to Mac would mean in terms of the code requirements.
    keep it up - excellent start you have!
    scott
    edited October 2013
    3. something else?
    scott
    the "client" is a daz script (very javascript-like ) it can mark objects in the scene as being static or dynamic bodies or constraints
    , it can compute their mass. Physical bodies get new properties in their parameters tab, ex: hinges get a drop down list to select which objects are attached to the hinge.
    then the script can package all that information and place it in a file named in.txt
    for the 'server' ( more like a processor for now )
    i copied the big Visual Studio 2010 C++ solution, that comes with the Bullet Physics sdk
    i stripped everything except support for collisions, dynamics, linear maths
    the program gets the Daz Studio physical scene as a text file (in.txt) that looks like
    0 Cylinder1 0 0 0 0 0 0 0.707 0.707 0 0.01 0.25 0.01 121
    0 Cube1 27 0 -0.653 -0.762 -0.343 0 0 0.939 0 0.15 0.15 0.15 121
    0 Cylinder3 0 0 0 0.5 0 0 0.707 0.707 0 0.01 0.25 0.01 121
    0 Cube2 27 0 -1.001 0.494 0 0 0 1 0 0.15 0.15 0.15 121
    2 Cylinder1 1 0 0.009 1.003 -1 0 0
    2 Cylinder3 3 0 1.001 0.006 -1 0 0
    it creates (instantiates) in the bullet physics world the objects in that list at the positions specified
    in this example there's 1 static body 2 dynamic bodies and 2 hinges
    it runs the simulation for the number of frames specified ( 121 )
    and writes the results in a text file (out.txt) which looks like
    body Cylinder1 static
    body Cube1 dynamic
    body Cylinder3 static
    body Cube2 dynamic
    0 0 0.000000 0.000000 0.000000 0.000000 0.000000 0.707107 0.707107
    1 0 0.000000 -0.656674 -0.759261 -0.345072 0.000000 0.000000 0.938576
    2 0 0.000000 0.000000 0.500000 0.000000 0.000000 0.707107 0.707107
    3 0 0.000000 -1.001496 0.494033 -0.000017 0.000000 0.000000 1.000000
    0 1 0.000000 0.000000 0.000000 0.000000 0.000000 0.707107 0.707107
    3 119 0.000000 -0.897749 0.056050 0.224813 -0.000000 0.000000 0.974402
    0 120 0.000000 0.000000 0.000000 0.000000 0.000000 0.707107 0.707107
    1 120 -0.000000 -0.952922 -0.314600 -0.582578 0.000000 0.000000 0.812775
    2 120 0.000000 0.000000 0.500000 0.000000 0.000000 0.707107 0.707107
    3 120 0.000000 -0.893711 0.047989 0.229199 -0.000000 0.000000 0.973380
    once the simulation ends the Daz Studio client script reads out.txt and animates the specified objects
    the daz studio script would run on a Mac without modification
    i'll almost certainly publish my source code so it wont be hard for any volunteer to compile it for a mac
    later i may make a real-time version, since daz studio scripts can establish sustained communication ( stdin/stdout) with external programs
    if you look at https://sites.google.com/site/mcasualsdazscripts/mcjwiikit-for-daz-studio-3-pc-version-zero-beta-not-stable-yet
    that's how i allowed real-time control of daz studio with a wii-mote
    also see https://sites.google.com/site/mcasualsdazscripts2/mcjhidkit for gamepads
    eventually i may make a plugin for DS4 and DS3 which will be more responsive
    1280 x 720 - 181K
    281 x 755 - 48K
    Post edited by mCasual on
    edited October 2013
    currently adding "Hinge 2" constraints
    steer and roll with a suspension !
    in ODE it's called "A hinge-2 joint"
    http://ode-wiki.org/wiki/index.php?title=Manual:_Joint_Types_and_Functions
    in Bullet Physics ot's a btHinge2Constraint
    http://bulletphysics.org/Bullet/BulletFull/classbtHinge2Constraint.html
    720 x 807 - 145K
    400 x 300 - 14K
    wow Casual! that's pretty amazing and awesome, i have to say, and it's a good idea to start the project out by offloading processing to a separate app and then send the results back to the Animator in less than real time. overall though it should still be pretty responsive as long as someones not trying to model 3000+ Tenga blocks crashing down. as you refine it you may be able to make it efficient enough to run it in real time with good performance, but it's better to start small and manageable and grow from there.
    although i'm not a programmer i understood most of what you're up to. i've never yet compiled anything on the Mac, but i'm definitely getting closer to a point where i'll need to do it. one curious thing for those of us on Macs (and for anyone scared of compiling from source) would be if you could call an emulated version of your Win based app from Daz on a Mac via scripting. i've been able to wrap a number of Win apps up in a standard OS X bundle through Wine and Wineskin - like BVHacker for instance which just _barely_ runs (don't resize the program window or you're doomed). so it makes me a bit curious if a script could call an emulated EXE directly. it's certainly possible to copy a text file within a MacOS bundle and have the emulated program believe it's in the filepath of a Windows machine. so as long as the filepaths were logical to each platform, it would be pretty easy to import the data from within a Wineskin.
    anyway it sounds like a really promising plugin. thanks a huge amount and i'll look forward to working with it when i have some time.
    scott
    edited October 2013
    Amy ... not afraid
    a nice scooter looks more interesting than boxes and cylinders
    i realized just now i didn't really make this scooter steerable
    1024 x 1024 - 243K
    1024 x 1024 - 430K
    1024 x 1024 - 228K
    1280 x 720 - 157K
    1024 x 1024 - 186K
  • Eustace ScrubbEustace Scrubb Posts: 2,732
    Casual said:
    Amy ... not afraid
    I realized just now i didn't really make this scooter steerable
    So THAT'S why she's riding off the edge in the fourth picture!
    edited October 2013
    Casual said:
    Amy ... not afraid
    she's taking all those risks for Science ( and the public good or something )
    985 x 435 - 94K
    1024 x 1024 - 344K
    edited October 2013
    rough ride for the first simulation of the "hinge 2" constraint ( steer, roll and shock absorber )
    it just needs stiffer shock absorbers :)
    480 x 480 - 50K
    480 x 480 - 552K
    not sure yet why the wheels lock
    i know that for cars and the likes, bullet suggests we don't use hinges ,
    rather use "ray-Casters" meaning the car slides above ground, supported by invisible rays
    and i guess, bullet spins the wheels according to the movements
    480 x 480 - 635K
    i made the bike frame heavier
    the rear wheel wider ( wider than shown )
    and it looks like it did the trick
    i'll give users access to most of the hinge parameters
    since default values are not enough to make things work out
    480 x 480 - 664K
    That's working better :-)
    note that this, albeit simple, 4 seconds/120 frames simulation takes 2 seconds to compute
    so eventually if we go real-time, we could play GTA0 in DS
    480 x 270 - 138K
    new setup for upcoming development
    4 the initial release may include support for non-primitives ... say low-poly terrains etc
    1280 x 720 - 141K
    edited October 2013
    Amy's death defying jump demonstrating Hinge-2 constraints !
    http://www.youtube.com/watch?v=vuYMvRh8iGg
    also see the giraffianesque version
    http://www.youtube.com/watch?v=ZSxLUgnbj8M
    1280 x 720 - 146K
    1280 x 720 - 239K
    You realize of course that she'll be asking you for danger pay soon ;-)
    she may need a protective dangerfield
    or at least a helmet
    ( that's actually Nicole Kidman in the 1983 BMX Bandits )
    600 x 356 - 108K
    There goes the hairdo lol ...
    edited October 2013
    the physics tests will look better with a brand new bike
    soon ( but not that soon ) i'll probably post the bike on my site
    1920 x 1080 - 438K
    1920 x 1080 - 311K
    1280 x 720 - 184K
    1920 x 1080 - 282K
    Oh that's a nice new prezzie for her.
    {not to worry you but the uh, giraffe is growing!}
    in the early pics the giraffe was as tall as the ramp then later on it was looking smaller, so i unshrunk it :)
    Amy's bike promo teaser video YT
    https://www.youtube.com/watch?v=VNeHLTwfYmQ
    1280 x 960 - 155K
    so far in the test cases
    physical bodies were made of boxes ( or cylinders, spheres, cones, capsules )
    now i'll introduce the "triangle meshes"
    so you'll be able, for example, to specify that a shirt is a physical object
    or that a terrain ( google/youtube-search) for mcjElevate is a physical object
    only non-moving objects will be supported for this script version
    in the inage below the green surfaces will be our test "triangle mesh"
    and Amy is still on board for the experiments with her brand new unchained bike
    1920 x 1080 - 2M
    see see ?
    exactly like the movie 'Contact'
    ok maybe not exactly
    180 x 360 - 187K
    edited November 2013
    the moment many-a-few have been waiting for
    the physics server became aware of the existence of the green triangleMesh
    meaning terrains will be supported ! mountain roads !
    and meaning the video where Amy rides her bike don't the ramp is nigh ( ish )
    600 x 337 - 225K
