Heads up! New release on the horizon, time to save a way back
namffuaknamffuak Posts: 4,403
edited May 2019 in The Commons
Heads up! New release on the horizon, time to save a way back to 4.10 if you want it.
There have been three 4.11 beta releases pretty much on top of each other (April 17, May 14, and May 29). Significantly we now have 'Strand Based Hair' (SBH). In addition, we have at least one vendor showing off the PA-only upgrade to SBH - dForce hair over here. There are probably others in the pipeline and they will (probably) not be released to us until 4.11 goes live.
Once 4.11 goes live access to the current 4.10 release will go away - so if you want a way back, you need to pro-acively keep a copy of 4.10 yourself.
If you use DIM for the install and still have the files, make a copy of these outside your DIM download directory:
IM00009032-01_DynamicClothingControlforDAZStudio410Win32bit.dsx
IM00009032-01_DynamicClothingControlforDAZStudio410Win32bit.zip
IM00009032-02_DynamicClothingControlforDAZStudio410Win64bit.dsx
IM00009032-02_DynamicClothingControlforDAZStudio410Win64bit.zip
IM00010673-01_DecimatorforDAZStudio410Win32bit.dsx
IM00010673-01_DecimatorforDAZStudio410Win32bit.zip
IM00010673-02_DecimatorforDAZStudio410Win64bit.dsx
IM00010673-02_DecimatorforDAZStudio410Win64bit.zip
IM00013173-01_GoZforDAZStudio410Win32bit.dsx
IM00013173-01_GoZforDAZStudio410Win32bit.zip
IM00013173-02_GoZforDAZStudio410Win64bit.dsx
IM00013173-02_GoZforDAZStudio410Win64bit.zip
IM00013176-01_DAZStudio410Win32bit.dsx
IM00013176-01_DAZStudio410Win32bit.zip
IM00013176-02_DAZStudio410Win64bit.dsx
IM00013176-02_DAZStudio410Win64bit.zip
IM00013176-45_InteractiveLessonsforDAZStudio410.dsx
IM00013176-45_InteractiveLessonsforDAZStudio410.zip
IM00016558-01_AlembicforDAZStudio410Win32bit.dsx
IM00016558-01_AlembicforDAZStudio410Win32bit.zip
IM00016558-02_AlembicforDAZStudio410Win64bit.dsx
IM00016558-02_AlembicforDAZStudio410Win64bit.zip
IM00016684-01_MeasureMetricsforDAZStudio410Win32bit.dsx
IM00016684-01_MeasureMetricsforDAZStudio410Win32bit.zip
IM00016684-02_MeasureMetricsforDAZStudio410Win64bit.dsx
IM00016684-02_MeasureMetricsforDAZStudio410Win64bit.zip
The windows explorer search string (on 8.1 anyway) is *DAZStudio410 (and if you're using the photoshop bridge it should show up with that search- I don't own it)
Alternatively you can (until the release of 4.11) go to your product library and search (filter) studio 4.x pro and any other DAZ plugins not part of the bundle.
Post edited by namffuak on
«1
  • barbultbarbult Posts: 26,156
    Thanks, you made it so easy.
  • HylasHylas Posts: 5,221
    n00b here... I searched for "IM00009032-01_DynamicClothingControlforDAZStudio410Win32bit.dsx" on my harddrive and didn't get any results. Perhaps because I'm using a mac? Anybody know what the mac equivalent is?
  • tj_1ca9500btj_1ca9500b Posts: 2,057
    edited June 2019
    OK, stupid related question.
    If the computer that you are using for Daz doesn't have an internet connection, will there be a way to do an offline install of the new version, as a separate install of course?
    After some malware/rootkit shennanigans a while back, I've air-gapped my primary Daz Studio system from the internet, and have no intentions of attaching it to the internet ever again.  Probably a bit drastic on my part, but i absolutely do NOT want my Daz computer being [corrupted].
    Edited for profanity
  • kyoto kidkyoto kid Posts: 41,837
    ...thank you for the notification. Saving 4.10 now.
  • It would be rather rash to make a full public release so soon after introducing a major new feature (like strand-based hair).  But if that does happen, it's certainly worth taking a back up of the installer for 4.10 since the new public release may be a bit buggy due to a limited time in beta for the bugs to pop out.  Hope it isn't released too early, that never ends well.
  • alexhcowleyalexhcowley Posts: 2,402
    There used to be a joke back in the days of MS/DOS: never buy the .0 version, always wait for .1.
    Cheers,
    Alex.
  • Pack58Pack58 Posts: 750
    IM00009032-03_DynamicClothingControlforDAZStudio410Mac32bit.dsx
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,000
    You do have the dynamic clothing plugin?
  • TaozTaoz Posts: 10,230
    edited June 2019
    I have installed older versions with DIM simply by uninstalling the current version, replacing the DS ZIP installer and related DSX file in the "downloads" folder with the old ones temporarily, and then find DS in DIM and install it again. So I assume you can do the same with newer versions as well, if you have the related DSX file (the one from a different version will probably not work). Just be sure not to go online again until after you have installed the old version, as DIM will update the old version with the latest again as soon as it goes online and updates the file list.
    Post edited by Taoz on
  • davesodaveso Posts: 7,743
    hmm..I only have 11 of those files on my system after a search.  Perhaps I didn't DL the 32 bit files, but even then should be more. will need to compare.
  • mwokeemwokee Posts: 1,275
    So what does this mean? Current products will not work on the new version?
  • namffuaknamffuak Posts: 4,403
    Some people run into issues - and start looking for a way back. The official line from Daz is there is no way back unless you prepare it yourself. This is the prep.
    That is for the old dynamic cloth and was (is?) an extra cost add-on.If you haven't purchased it you won't have it.
    Cheers,
    Alex.
    And Daz has this covered in spades! The beta is version .380 . . .
  • ElgyfuElgyfu Posts: 279
    Please excuse my being thick.
    Could someone explain what all this means in very simple terms?
    Am I right in thinking a new version of Daz Studio is coming,and once released one will not be able to access the existing one?
    Will the new version cause issues? Or just MIGHT cause issues?
    Will there be a difference in what specs one needs to run it?
    This sounds complicated. I am not very well and struggling to think properly at the moment.  Sorry.
    edited June 2019
    Yes once installed in DIM unless you save the ZIP you cannot go back likewise any updated plugins
    manual downloads you have your installers
    mostly it’s OK but sometimes it can be an issue such as needing a newer Nvidia driver my other software could not use  or a third party plugin being broken
    and a pretty big one
    dsa files might not load especially Optitex dynamic ones!
    edited June 2019
    If only Daz kept past versions around for situations like this. They don't even keep previous versions of the beta around, which is completely illogical as betas are testing software.
    That this thread exists shows what a problem this is. This thread should not exist. Period. This is something users should not have to be concerned about. You should be able to revert back if something goes wrong.
    Also, 4.10 renders faster for me most of the time. I have tested multiple scenes in both versions, and they almost always render quite a bit faster in 4.10, and yes I have updated drivers. I know some people say the beta renders faster for them, but this just hasn't been the case for me. Scene makeup plays a role. Upgrading to be slower isn't exactly ideal.
    Give us the option to revert back if something goes wrong, Daz.
    Post edited by outrider42 on
  • MattymanxMattymanx Posts: 6,995
    When a new version of Daz Studio is released, you want to make sure that you update your plugins along with it so that they are all of the same version.  Old version of plugins may not work correctly with newer versions of Daz Studio and have been known to cause issues..
    However, you dont have to upgrade if you dont want to.  The stable release of Daz Studio can co-excist on the same computer as the beta version.  So if you want to remain with Ds 4.10.0.123 (or older) yet still use the newer features that are comming, just have both versions installed.
    I will agree that you should always keep a personal back up of all your installers incase you need them.
    As for the current beta, as long as you are running Nvidia drivers 4.18 and up, you will be fine as there was an update to Iray that needs the newer drivers.
  • Richard HaseltineRichard Haseltine Posts: 107,858
    .daz, not .dsa, were the problem - the latest beta is meant to have resolved this (for files that worked in 4.10.0.123); if you still have problems with the beta but not the release please report the issues. .daz files have always been prone to issues, with older files not opening beyond a certain point in the updates, which was why the format changed to .duf/.dsf.
    Yeah sorry meant .daz blush
    will admit not tried in beta I installed yesterday yet
  • JOdelJOdel Posts: 6,306
    If you install manually, it's not an issue, because you can just arcive the installer and use it later.
    However, if you install manually, you have to wait for the official release, since the beta is not available for manual installation.
    Correct - Daz only provides 2 versions of Studio - the current release - 4.10.0.123 and the current beta now 4.11.0.380; The moment that Daz announces that 4.11 ia available as a general release 4.10.0.123 will no longer be available. And there might be issues - any non-trivial software will have bugs. Daz does what they can to avoid them, but there are so many options and features in Studio that testing all combinations just isn't feasible.
    As I understand it - each build goes through automated regression testing and then in-house alpha testing. The builds that survive this get passed tto the small group of beta testers under nda. This continues until Daz determines that the new feature(s) are nearing ready for release. That's when the beta gets turned loose to the rest of us. And after several iterations this beta goes live. The more people that play with the pre-release beta the better the chances of a trouble-free release.
    There may be  difference in the requirements to run the new release - these are usually called out on the first post of the release announcement. Here's Rob's post on the beta requirements.
  • SixDsSixDs Posts: 2,384
    edited June 2019
    The advice given is valid, but, as some have pointed out, it has become difficult to predict when the current beta version of DAZ Studio will become a General Release, since new features seem to be added to the beta before the bugs are worked out of existing features. Since version 4.10.123 (current General Release) isn't going to change, then backing it up now while it is still available isn't a bad idea. But when a new General Release is coming, well a picture is worth a thousand words:
    661 x 504 - 121K
    Post edited by SixDs on
  • SimonJMSimonJM Posts: 6,067
    Just to add another sunny point of biew to this, if you have the Octane plug-in under the 'old' licence scehme and, like me, so not intend to 'upgradfe' to their new subscription licence scheme you will be left using the version 4 of OcDS so when a newer version of DS is released with an updated SDK ithen OcDS may cease to work - the developer has said he intends to re-compile, or whatever it is that needs doing as and when that happens, so we can but hope.
    edited June 2019
    I get all my updates through the DIM, including the DS Betas and nothing is installed automatically.  I do it all manually.  In the DIM, you can tell it to NOT install after download.
    Post edited by Mattymanx on
  • ImagoImago Posts: 5,650
    Thanks for the advice, Namffuak! All the backups are done.
    Can I suppose the General Release will be up about next monday?
  • scorpioscorpio Posts: 8,533
    May I ask why you woulld think that its so close to release?
  • nicsttnicstt Posts: 11,715
    I always keep backups, but it is nice to get a reminder.
    I was curious when I took the backup of 4.10.0.123 - 31/03/2018. I have numerous 4.11 betas, and of course 4.9, 4.8 and earlier, although fewer of those
  • L'AdairL'Adair Posts: 9,479
    edited June 2019
    I use DIM and I found the easiest way to save a backup (imo) is to save the files to a backup directory when they come available. I then copy from the backup directory to the DIM downloads directory to install. If I want to get back, (and I've done this several times,) I just go to the backup folder for the older version and copy/paste those files. DIM actually makes it really easy to do.
    1. Open and log on DIM.
    2. At the bottom of the Ready to Download tab, disable Install After Download.
    3. Click on the Download Filters button at the top of the Ready to Download tab. This will open DIM settings on the Downloads tab.
    4. The first option is the path to your Package Archive. Click on the "…" button and browse to your backup folder. I recommend a separate directory for each release.
      • I keep program backups on a drive I use just for data, with directories for both the released and beta versions.
      • F:\3D Content\daz3d\DS Backups\Beta\
      • F:\3D Content\daz3d\DS Backups\Release\
      • Each release has it's own directory within those.
      • For example, I just archived the beta, v 4.11.0.382 in F:\3D Content\daz3d\DS Backups\Beta\Beta 4.11.0.382
    5. Optional: While still in this tab, if it's the beta you want to download and archive, scroll down the list of items in Show, and select Public Build.
    6. Click on the Accept button to save and close the settings dialog.
    7. Download the files for the new release.
    8. Once the files finish downloading, click on the Download Filters button again.
    9. Change the Package Archive path back to your DIM downloads directory.
    10. Optionally, if you enabled Public Build, disable it now.
    11. Click on the Accept button to save and close the settings dialog.
    12. At the bottom of the Ready to Download tab, enable Install After Download, (if DIM is your preferred method of installing.)
    13. Open the directory where you archived the files.
    14. Select the files you just downloaded and copy.
    15. Open the DIM Downloads directory.
    16. Paste the files you just downloaded.
    17. Refresh DIM. Your new files will now show up under the Ready to Install tab.
    18. Install as usual.
    This will ensure you always have a backup of the files. I have a backup for every release since  4.9.3.166, and every beta since 4.9.3.117. (I suppose I really should purge some of those!)
    Post edited by L'Adair on
