(Solved) Moved library to diff drive, updated pathing everywhere, DIM still looking at old location.
Lissa_xyzLissa_xyz Posts: 6,116
A while back, instead of probably going the right way and uninstalling from the old location and reinstalling to the new ( F: to E: ), I simply copied my library folder and changed all of my pathing. This seems to have created a situation where I cannot uninstall items properly via DIM as it thinks the folders are missing. Is there any way to correct this without completely redoing my library?
/edit
Decided to crack open VSCode and took a peek at the *.dsx manifests. If I do a find/replace across all files of the line
 <UserInstallPath VALUE="F:/DAZ 3D/Daz Studio Content"/>
to
 <UserInstallPath VALUE="E:/Documents/DAZ 3D/Daz Studio Content"/>
will that do the trick?
/edit 2
Because I'm too curious for my own good, this seem to have worked flawlessly. Leaving post here in case anyone else should need it.
Post edited by Lissa_xyz on
    They're actually both right, as in, they'll both work, and the manifest fix you worked out is actually what you're supposed to do when you do the copy/move. There are very few things in DAZ|Studio that can only be done in one way.
