Dforce Fail
Hello,
I'm trying to simulate animations with dforce and i have this problem when using dforce cloth or when i add dforce modifier to a "standard" cloth...
This problem comes when hand is close the cloth but even when it's not very close (file in attachment). I'm ok with dforce explosion when a hand is in collision with th cloth but in this case, i d'ont know what to do...
Thank you for the help and sorry for my limited english !
  • kenshaw011267kenshaw011267 Posts: 3,805
    From my experience with dForce this looks like something that happens when you simulate from the memorized pose. As the actor moves to the final pose position the forearm collided with the pants and the simulation tried to drape over the forearm and then as it moved away it kept trying to maintain the draping.
    I know it is tedious but watch the simulation run and if that's what's happening you can simulate using an animation, which gives the simulation longer to resolve this.
  • SimonJMSimonJM Posts: 6,110
    If you select the arm surface you can set it to be not visibel to simulation which should avoid this happening - so long as you don't need the arms to be involved with anything else dForce related.
