RDNA GRassland products..anyone try in DS?
davesodaveso Posts: 8,262
edited May 2019 in The Commons
https://www.daz3d.com/rdna-grasslands-volume-8  as example.
They appear to be alpha planes .. but even using DIM to install, there are files missing. I had to do a search in the Content Manager to find them at all ...
do you think the transparency, etc and all texture levels need to be manually set up?
Post edited by daveso on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,572
    You would need to convert the surfaces to iray but otherwise work, are a bit better than alpha planes are simple branched leaved geometry shapes with alpha like many hairs are
  • LeanaLeana Posts: 13,516
    I don't have this one but I have quite a few other RDNA Grasslands products, the props load with the textures without problem for me. They're poser props so you may need to adjust surface settings in DS.
  • barbultbarbult Posts: 27,527
    Here is a nice Iray grass product (free!).
  • davesodaveso Posts: 8,262
    thanks..lots of cool stuff there for sure.
  • TaozTaoz Posts: 10,351
    Thanks for the link, this grass looks really good! I had to use 3 layers on top of each other to get it look dense enough, but it doesn't seem to use a lot of resources.
    1377 x 921 - 2M
