RDNA GRassland products..anyone try in DS?
daveso
https://www.daz3d.com/rdna-grasslands-volume-8 as example.
They appear to be alpha planes .. but even using DIM to install, there are files missing. I had to do a search in the Content Manager to find them at all ...
do you think the transparency, etc and all texture levels need to be manually set up?
Post edited by daveso on
You would need to convert the surfaces to iray but otherwise work, are a bit better than alpha planes are simple branched leaved geometry shapes with alpha like many hairs are
I don't have this one but I have quite a few other RDNA Grasslands products, the props load with the textures without problem for me. They're poser props so you may need to adjust surface settings in DS.
Here is a nice Iray grass product (free!).
thanks..lots of cool stuff there for sure.
Thanks for the link, this grass looks really good! I had to use 3 layers on top of each other to get it look dense enough, but it doesn't seem to use a lot of resources.
