how to fix this problem
i do reset to content DB maintenance
but not fixed
but not fixed
What figure or character are you using? Can you provied a link to the store page?
It looks like you only have part of a product, and the object files are missing.
I would expect you are getting an error message on loading the item - what is it?
I've had that happen when an object/figure's geometry data is not in the expected location (typically because it isn't installed, but also sometimes freebies aren't packaged correctly). Uninstall/remove the item and reinstall. If the problem persists, verify you have any prerequisite content.
this is character
https://www.daz3d.com/reject-for-genesis-8-male-s
and message on loading an error occurred while reading the file see the log file for more details
but This message appeared to me at another product and I did the work of Reset content DB maintenance and worked for me but this product did not work with him Reset content DB maintenance
