dForce Hair for Geneis 8 work on Genesis 3?
I would like to know if it is possible and if there is any way to make Gforce hair Genesis 8 work on Genesis 3. Thank you.
    Sure, load your GF3, then make sure you ARE NOT SELECTING the figure and then load the hair you want to use. Then while in the scene tab and the hair selected, go to the four little lines in the upper right of the scene tab and select EDIT - SCENE IDENTIFICATION and change the figure to genesis 3 female and save. Now it will fit to Genesis 3 female just like it would with genesis 8 female and you can now run a simulation.
    edited April 2019
    Yes, they will work on G3, as long as you don't "Fit to" the G8 hair.
    There are two ways:
    1/ Parent the hair to G3's head, adjusting the position and scale manually. or
    2/ Select the hair only, then change the Identification from G8Female to G3Female with this method:
    (In image 4, make sure you click on the '...' )
    1374 x 628 - 279K
    1392 x 594 - 266K
    1296 x 714 - 311K
    1232 x 720 - 296K
    938 x 724 - 160K
    Post edited by frankrblow on
  • DrykeDryke Posts: 32
    Thank you so much guys
  • LenioTGLenioTG Posts: 2,118
    There are two ways:
    This is interesting, thank you! ^^
