Figure explodes when I change pose
I'm working on a scene with a figure that explodes when I adjust her pose. I think this is caused by the lighting, as she didn't do it before I added the lights. She's actually fine when I render or do a quickie preview render. If I save the scene, close Daz, then reopen it, she's as she should be. However, this is quite the hassle when posing--closing and opening over and over. Is there a way to refresh the scene to get rid of the triangle mess without having to close and reopen?
  • scorpioscorpio Posts: 8,534
    Smoothing on clothing can sometimes cause weird effects like you describe if smoothing is turned on try turning it off, or try changing the smoothing type.
  • BamboozlerBamboozler Posts: 249
    I'll try that, thanks. :)
