adding sub D to V4/M4
is there a way to increase the subdivision level on V4 and M4 figures in DS 4.10?
  • LeanaLeana Posts: 13,642
    You should be able to convert any model to SubD using command "Convert to SubD" in Edit > Object > Geometry menu
    But you wouldn't gain anything except polygons.  When you apply the default SubD settings the mesh's verts get smoothed or averaged a bit so you actually lose detail.
