adding sub D to V4/M4
StratDragon
is there a way to increase the subdivision level on V4 and M4 figures in DS 4.10?
StratDragon
You should be able to convert any model to SubD using command "Convert to SubD" in Edit > Object > Geometry menu
But you wouldn't gain anything except polygons. When you apply the default SubD settings the mesh's verts get smoothed or averaged a bit so you actually lose detail.
