Genesis 9 delayed until at least 2020. Will you be buying it?
1121315171830
  • Taoz said:
    Tech always changes, when Iray first came to Daz the biggest gaming card was a 980ti with 6gb. That was only a few short years ago. The 1080ti nearly doubled that. The 2080ti has the same 11gb, but it is capable of pooling its VRAM with Nvlink. (This has been proven, it is no longer speculation.)
    So with 2 x 2080ti you can get 22 GB VRAM? How many can you combine?
    Not the full 22 (then again you don't get a full 11 with a single card either). The reason is some data must be duplicated for performance. The problem is, no app currently reports exactly how much VRAM is pooled, so right now nobody really knows exactly how much you get in Nvlink mode. But vray was able get a scene to run on Nvlink 2080ti's that would not run a single card due to its size. Running in Nvlink is also a bit slower than running the two cards without, but the penalty is not much. My guess (and I stress this is a guess) is that you might get 16-18GB when using Nvlink. You can only link 2 2080ti's or 2080's.
    Here is a link with details on what they did. They also have pics of the scenes they created for testing.
    https://www.chaosgroup.com/blog/profiling-the-nvidia-rtx-cards
    So this is a cost/benefit evaluation, and nothing more.  I think it would be rare to need more than the 11 GB of one card, but to help with the kitchen table math, I think it would good to have some form of understanding of "how much" would require NVLINK.
    How much is how big?  11 GB is a lot.  What is the overhead for one card?  Is it a few meg or a few gig?  What is the overhead for two cards running in NVLINK?  Just how big of a scene is that?  Can I leave the connector in place and selectively engage or disengage SLI to address my current project?  The last thing I want to do is to have to crack open the case and attach/detach the cable each time.
    But if I could change it in software, that's doable.  I'd get 2 cards and mostly run them separately, only combining them when I had to render a big scene.
    Nvlink can be disabled with a click. 11GB being a lot depends on who you ask. There are plenty of users who want more than 11 because they want to use more than 11. There has been considerable increase in how much data things use in Daz. Many G8 characters can take over half a gig by themselves, and that's not counting clothes. Some environment props will use a ton of data just loading them up. And some people want to render very large images, which greatly increases the amount of VRAM needed.
    The information on Nvlink is still scarce and people are still learning as they go. Nvidia has not provided many details themselves about pooling VRAM, so everything we know is because of people testing it out. Eventually this will come to light. If you have questions, I would direct them to chaosgroup as they are doing a lot of this work.
    But there is always a cost benefit relationship regardless of what you buy. Two 2080ti's with Nvlink are going to be well over $2700. You can buy a Quadro 5000 for $2300 which comes with 16GB on one card. And Quadro can use TCC mode, which means you can use the entire 16GB bank and the card will run faster than normal because this cuts the card off from Windows. Gaming cards cannot do TCC mode, and like I said, there is that small speed penalty running full Nvlink. Even so, I would assume that two 2080ti's will render faster than a Quadro 5000. The 5000 is basically the Quadro version of the non ti 2080. But as you can see, there are trade offs.
    I only just saw this, all the way from November until April, ouch.  Thank you for sharing your thoughts on it.
  • StezzaStezza Posts: 8,909
    Be good if Daz brought all their software up to industry standard if and when they get the resources to do so.
  • Bluefox25Bluefox25 Posts: 21
    edited April 2019
    I’ll keep building Gen 8. I’ll probably start Gen 9 during the holiday sales. Only if enough content is out. It’s not useful until a ton of characters, clothes and sets/vehicles with interactive poses are out. It would probably start with the right pro bundle on sale.
    But I won’t avoid it. Plenty of G3. I can probably skip G8M. G8F is just getting built here.
    Post edited by Bluefox25 on
    edited April 2019
    Accidental double post while trying to edit. Sorry.
  • WillowRavenWillowRaven Posts: 3,787
    Unless it's absolutely miraculous, not likely.
  • ParadigmParadigm Posts: 425
    Would require some sort of major technical overhaul like bullet physics or (even harder apparently) working pins. Much more interested in them putting their time into adding features to the platform.
  • I will echo others and say i would rather daz refine G8 than to push a half baked G9 unless behind the scenes they are ready to release an all encompasing G9 But will not be holiding my breath. But what i am more interested is the what daz maybe going to introduce in  studio . maybe better skin and hair shader set up thats top of my wishlist  wich has to come from the program and not the model
  • hzrhzr Posts: 210
    Flortale said:
    I'll only switch to Genesis 9 if they have an HD addon that's as detailed as Ophelia 7's HD-Addon. If Genesis 9 female doesn't have a proper HD-addon, then no, I won't use it and will be forced to stay with Genesis 3 using Ophelia 7 HD addon
    Try baking those morphs into normals with substance painter or Marmoset. Then you can use them on all the g8 characters aswell due to the same base UV. I did this with most of the HD morphs from both g3 and g8 and it works very well, also keeping the figure light.
  • ArtAngelArtAngel Posts: 2,074
    Nope. Not unless they create a psychic G9 that can forecast trends and suggest better ROI on investments.
  • Joe.CotterJoe.Cotter Posts: 3,362
    edited May 2019
    ... something like being done at  https://texturing.xyz is crucial for those of us desiring realism.
    That looks amazing. :)
    Things such as more realistic hair ...
    We already have that... the problem is the (hardware) resources it requires.
    This brings up the real issue I think. The major changes we would like all require more hardware requirements. Just as some are sticking with 3DLight for that reason, most of the rest of us would be sticking with current gen products as most can't afford dual rtx cards with 64gb of memory (or more) and the latest CPU. I think it's a matter of refinement untill new hardware gets established as a base, at which point we can start to consider significant changes.
    That being said, it might be possible for continued refinement is in rigging and associated topology tuning as well as texturing like the example above. Just anything that takes too much hardware will probably not find a current market.
    Post edited by Joe.Cotter on
  • rrwardrrward Posts: 556
    I'm just getting caught up with Genesis 8 (after taking too long to migrate from Poser to DS). I'm not spending that much money for a new figure set unless it blows G8 so far out of the water it makes them look like Victoria 3 era products.
  • JamesJABJamesJAB Posts: 1,766
    I will grab the G9 figures when they come out because the base figures and starter essentials will probably be free.
    Then after that I will start expanding into that generation when a named figure comes out that interests me.
  • RAMWolffRAMWolff Posts: 10,373
    Exactly.  That's why I'm curious as to why folks are doing this back and forth dance.  We always get the Essentials for free so that gives the end user a chance to play with the figure and check it out first before investing in it further.
    AND as stated by an official DAZ person there will not be a Generation 9 this year so just relax and enjoy what we got!
    Do you have a link to this? I would like to read it.
  • LeanaLeana Posts: 12,975
    A few pages earlier in this thread: https://www.daz3d.com/forums/discussion/comment/4455636/#Comment_4455636
    Thanks! Much appreciated!
  • KordouaneKordouane Posts: 2
    I have worked a lot with Genesis 3, now I only work with Genesis 8 much easier to handle, but I was extremely disappointed by the quality of some products especially babies (Caryn and Tobyn) real monsters (no finesse in the features of these 2 characters and not many choices in hair and clothing). I had been waiting for years for babies, the wait was long but very poorly rewarded! Then, since the Dforce system, clothes all look the same and don't always work very well. Moreover, I noticed that for a year now some salespeople hadn't given the same quality of work, you might think they were working on a line ( example: The hair, the hairstyle is different but the colours are identical throughout the range of the same salesman, the same for the eyes. Some major exceptions for rare products of high quality. So I am very disappointed with this past year. Finally, if Genesis 9 is released, it is in its interest to bring a huge bonus and especially that the hair, accessories and clothing are of impeccable quality.
    Translated with www.DeepL.com/Translator
  • freni-kynfreni-kyn Posts: 394
    DAZ_Steve said:
    Okay, so I know we tend to be very close lipped on most upcoming things, but I will tell you this: Genesis 8 currently has the features that we need from a figure base, and to provide for the various things we intend to release this year.  As such Genesis 9 is definitely not slated for 2019.  We do however, have a lot of other cool stuff that will be releasing in Q2-Q4.  Watch, you'll start to see a lot of new functionality in content and Studio itself over the next several months that will let you do a lot of things with Genesis 8 that you haven't been able to.
    I've been dealing with medical stuff and just now saw this. Thanks for the update!
    if it works in carrara i'll be front of the queue to buy it smiley
    even better if it comes with a face rigged dragon and rider and dragon poses.
    Visuimag said:
    I wouldn't call the skipping of G9 in 2019 'good news' per se, rather, info that everyone will have to wait longer.
    Totally agree!
    Like L'Adair said, why just cycle through the same content repeatedly and not really do anything exciting or create character bases that the buyers might be looking for.
    I agree to a point.  I would love to see a Gen 9 this year (not going to happen) if we see significant improvements such as much better facial expressions.  See below:
    To me this is mandatory in the next figure.  Keep in mind that Snappers Systems in not a huge company like Disney, and the rigging was done in Maya.  I love their blue dot manipulaton system directly over the mesh (not off to the side on a seperate representation of the figure)  It was rendered in Unreal Engine 4.
    Other things such as advanced and completely accurate HD morphs to the body based upon something like being done at  https://texturing.xyz is crucial for those of us desiring realism.  The HD morphs I have purchased look pretty good to me so this might already be being done in all fairness, and can be done for Gen 8 without the need for a new figure.   I would love to see a bit more rigging for the toes, and a re-work of the balls of the feet.  Because of increased tessellation for the toes there is a transition from bigger quads to smaller ones which means splitting tri's to make quads.  In SubD this causes unrealistic ripples in the balls of the feet because the quads are so close together.  All I can do is go into Zbrush and try to spread the geometry a bit to relax those ripples.
    I have almost 80 figures now for Gen 8 female and probably 10 for Gen 8 male plus all the content I need for these figures, I'm kind of done buying for a bit unless something really grabs me.
    Things such as more realistic hair, better soft body dynamics, better more efficient collision detection with multiple objects, much faster DForce (Marvelous Designer comes to mind) that is greatly expanded in capabilities, and applying a brush to control the amount of HD morph in certain body areas vs HD morph for only the whole body are some improvements that come to mind.  This is more applicable to the application (DAZ Studio) versus a new figure so I think DAZ is on the right course for delaying a new figure release and concentrating on Studio updates this year.
    I am super excited and can't wait to see a new Gen 9 male and female figure line, but as long as it is a big leap forward.
    Wow.  Great video!  I would love to see this ability come to daz.
    edited August 2019
    BlueIrene said:
    nicstt said:
    Guess, I'll get the Dragon Girl bundle; I'd stopped buying anything, since january hit.
    I'd have made the announcement more prominent as I expect there are a number of folks like me.
    I would definitely have made the announcement more prominent too, especially since the title of the thread says the opposite. My brain saw the question mark as well as the words but didn't process it - I only read this thread after reading of the announcement on another one. It was subsequently locked for being too similar, but was actually titled 'No Genesis 9' or something a lot like it. It's now sinking to the bottom of the forum, and people will be seeing only this thread and not even opening it because they've made the same assumptions that I did. Meanwhile, I'm still reading of people reining back their G8 spending because G9 will be showing in a couple of months. It seems a shame.
    Hopefully @freni-kyn will see this and update the thread's title and first post to cut down on the confusion.
    Sorry, what do you want me to update it to?  I'm taking suggestions for what to rename this forum.  Although it went up a very long time ago, it seems that it is still relavent, since the g9 won't be out until 2020, at the earliest.  It's not really an announcement thread, even though Steve did throw us a bone, which I really appreciate.  I've noticed a huge improvement in the quality of some of the characters lately.  Very exciting to me and I can't wait to see more of that.  And we are all looking forward to great new capabilities with the actual DAZ program.  After reading that tantalizing teaser I'm probably going to have dreams about it like one of the other people did.  :)
    Post edited by freni-kyn on
  • brainmuffinbrainmuffin Posts: 1,282
    freni-kyn said:
    I see we have hit the one year mark for Genesis 8.  Wow this last year went fast!  Am I wrong in thinking Genesis 9 will be out next year?  If so I really hope all my old stuff works because wow, I've spent way too much money.
    Yes and after the Pro Bundle the first thing I will buy is the Morphing Fantasy Dress, because.
    I pretty much buy anything 'fantasy'  lol.
  • 3Diva3Diva Posts: 12,017
    edited August 2019
    Your first post was written in 2018 says: "I see we have hit the one year mark for Genesis 8.  Wow this last year went fast!  Am I wrong in thinking Genesis 9 will be out next year?"
    Most people will not read the 15 pages of this thread and many new people reading the thread will likely just read the OP and then comment. So what you could do is edit your first post with something like: "Edit - It looks like it's been announced that Genesis 9 isn't going to be released in 2019" and then a link to Steve's post: https://www.daz3d.com/forums/discussion/comment/4455636/#Comment_4455636 That would likely help cut down on confusion.
    And perhaps change the title of the thread (since it's a question that has been answered). Maybe something like: "When Genesis 9 is released, will you buy it?"
    Since the title of the thread is misleading and several posters have commented about how they've stopped purchasing G8 content thinking that G9 will be coming out in a few months, like this comment:
    Post edited by 3Diva on
    edited August 2019
    Sounds good, thanks for the suggestions!  May not get to this until tomorrow though.  Edit:  Ok, done!  Changing the forum name and editing the first post was easier than I expected.
  • SevrinSevrin Posts: 6,314
    G8 is pretty good.  What flaws it has are in large part a result of wanting to preserve the value of their customers investments in previous-gen assets.   Any advances sufficiently ground-breaking to justify a new generation would probably also break backward compatibility.   It would be nice to have soft tissue respond to collisions and stuff like female hips working differently from male hips, as they do IRL, but I think Daz is wise to tinker around the edges with stuff like SBH within the current, uh, there's that word: ecosystem.  On the one hand a completely new model would be a bonanza for PAs faced with a customer base needing to purchase a whole new range of characters, hair, clothing and pose assets.  On the other, there would be a lot of people faced with the choice of either starting from scratch but sticking  with Daz stuff or looking around to what other options are available, especially with new life being breathed into Poser as we speak.
    freni-kyn said:
    Totally agree!
    This does look really great, but it strikes me funny that with as far as we've come with CG, eyes still look deader than a doornail and it's immediately apparent to me ;).
    Laurie
    freni-kyn said:
    Totally agree!
    Auto Face Enhancer is a first attempt at this kind of thing.  I've played with it a bit.  The first thing it seems to do is add 5-10 years to your character.
    AllenArt said:
    freni-kyn said:
    Totally agree!
    Laurie
    I think a lot of that has to do with lighting.  Though I could not tell you how to fix it.
    Sevrin said:
    freni-kyn said:
    Totally agree!
    Is that a new product?  I missed the release.  That isn't what Siciliano1969 is using in his video is it?  Automatically aging the character is a huge downside but I think I'm going to have to try it.
