Poser Question- Have you lost your libraries recently?
McGyver
Today in Poser Pro 2010, I lost my library window... shows up "blank"... I asked at a couple of sites but either nobody has answered yet (except for renderosity) or they have no answer. After a pretty long search I still have no actual answer, but I got suspicious and tried running Poser with the internet disconnected... The library will then load. I tried it several times with internet connected and disconnected. It will only load disconnected from the internet. Very odd. But now it appears that several other people are experiencing this problem (I found this out from my thread at Rendo) and it appears that disconnecting from internet will get the library to load... I'm curious if this problem is showing up for others too... and also if disconnecting from the internet solves this issue.
I answered in your other thread in the Poser section, but here it is again:
Try updating your Adobe Air manually if you're using 64bit PP, and Flash if using 32bit.
http://www.daz3d.com/forums/discussion/28751/P30/#435586
http://get.adobe.com/air/
http://get.adobe.com/flashplayer/otherversions/
There seems to be some recent discussion of blank library in the official poser forum at RDNA -- but maybe that's you? I don't think it you though because that person solved their problem by reinstalling 5 times or so. But the thread has a description of the possible causes and better ways to fix it than that...
Nope thats not me at RDNA... but I just started a thread there too...
@Vaskania... Thank you. I did try that though and several other things I found... but nothing worked... well except for disconnecting from the internet...
I'm finding more people this has happened to... very odd.
Is your firewall blocking anything?
/edit
You could also try changing the launch behavior. Edit > preferences > library. If you're using embedded, change it to external, if you're using external, change it to embedded. Not sure if it'll do anything, but it's worth a shot.
It does not appear to be a firewall issue... also neither embedded or external work... but once I shut down Poser and start it up with the internet disconnected, both will load normally (actually I just realized the last time I tested it, that it actually loads quicker than normal)
This is Poser 8 but maybe it's still valid?
https://support.smithmicro.com/app/answers/detail/a_id/2211/~/poser-8-blank-library
Yeah, I found that too... I use Safari and Firefox, it doesn't explain how to do it in those browsers. Thanks.
Oh yea Mac wouldn't have IE. lol /facepalm
Sorry >.<</p>
I have encountered this situation before (and like you, I Googled the crap out of it, and finally found a solution that worked; I just wish I had bookmarked the site where I found my answer).
The problem I encountered involves your browser settings (believe it or not!) More specifically, your LAN settings.
If you're using IE under Windows, go to the Tools menu (that gear-looking icon on the top right). Select 'Internet options'. Then select the 'Connections' tab.
About three-fourths of the way down that dialog, look for the 'LAN settings' button. Click it.
In the 'Automatic configuration' group, near the top of the dialog box that opens, look for the 'Automatically detect settings' checkbox. If that box is checked, then clear it.
Click 'OK' (twice) to back out of the dialogs.
When you restart Poser, your libraries should be back where they belong.
This has worked for me in the past. (The alternative - as you discovered - was to turn off (i.e., disable) my network connection, and obviously, that was not a viable option!)
The next issue I need to run to ground is why that setting keeps getting changed, and what is doing it!
(Edited to include this addenda....)
It doesn't matter which browser you use; what matters is the one Poser uses. (And Adobe.) Both make calls into the IE DLLs (it's called 'code re-use', and it's, like, the Holy Grail of IT application development). So whether or not IE is even running, those settings have an impact on a lot of other applications, for that very reason.
But I am not on IE, only use FireFox
Sorry.
I probably should have made that 'addendum' (and I didn't even spell that right!) a separate post, as opposed to editing my initial comment.
Live and learn!
Except that if he's on a Mac then it better not be making IE calls or it will never work as there is no IE available on the Mac.
I would assume that the Mac versions are making calls to WebKit as that's the engine behind Safari and, like IE, is the one that is known to be available for other devs. Sadly, my Mac networking experience is lacking and I'm not sure what that "Automatic Configuration" setting is doing in Windows so I have no idea what to check on the Mac.
Copying this over from the Poser Forum
I just went back through the thread, and could find no references to what OS he's running. And like you, my Mac networking chops aren't quite up to speed anymore, so I'm not sure, off the top of my head, what settings to check. (Kind of ironic, too; I have four computers here, three of them are Macs, and all of them are currently powered down!)
Edited to add, sorry he isntalled Edited to say, sorry he installed 11.7.700.2
Well, I made the assumption of Mac based on Vaskania's comment about Mac not having IE. Also he said he was using Safari & Firefox and since no sane person would use Safari on Windows :) I just assumed he was on Mac.
Sorry, yes... I'm on a Mac, Vaskania probably noticed that because I had a different thread at the Poser forum, which was asking for help to figure this out... I started this thread here, to see how many other people were experiencing this issue and to alert anyone who hasn't opened Poser in a while who might do after this thread fades into history...( sort of "ya might want to check it now)... The poser forum here seems to get less traffic, so I figured this would be a better place for it... that and this is sort of a similar, but different subject... not looking for help, but trying to find out how widespread this is... which it seems to be.
But yeah... Mac- OS 10.6.8... Safari (and/or Firefox)... and no Chrome (that was brought up elsewhere so I added that too).
I use Safari. (Oh, wait.... Never mind. Overlooked the qualifier, there!)
Actually, I have five different browsers installed; I do web development, and browser-agnostic is the sine qua non in that game. I have IE, Safari, Firefox, Chrome, even Opera (to support the three-dozen people on the planet who actually use it!)
There are now only 35 people using Opera... Tim was run over by a bus last week.... And Nigel is not looking too well either.
I've done a bit of web development so I know how that is and yeah I have pretty much every browser known to man installed somewhere.
Still I wouldn't willingly use Safari for Windows for any longer than it takes to test something. I have enough problems using it on Mac where it's miles better.
Hi and thanks to everyone that replied here... I'm not 100% sure but I believe SmithMicro became aware of the problem sometime yesterday evening, and did some sort of update or automatic patch. That is more or less what I'm getting from one of the threads about this at Renderosity. By mid day yesterday many people started reporting this same issue... the most activity on the subject seemed to be at Renderosity's Poser forums... this is the thread where it seems to have an answer to what the issue was:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2873019&page=1
Too bad I have no idea what a LSMGUI.swf is... Thanks again to everyone who helped out on this!!
