Adding to Cart…
That's a stemay valentines for sure!
Really like the last one she looks very mysterious
" heh . . ahh maybe it's in the next grove"
" This is the third one," . . ."admit it, you don't know where we are, and we're lost"
been a while since I shared, so whipped this up for ya
G3F
petite 5'2"
Some great renders as always @XaatXuun
Perfect expression!
Thank you Saphirewild
Thanks IceDragonArt, when I came up with the expression I had to fill in the rest, forgot where I was going at first, but yeah, saw that expression and had to create something to go with it
been a while, dialed this G3F to post here
there were some previous ones, but not something I was happy with, I like this one, but one part, and you can't see it
maybe later, if I decide to fix it
fixed that problem I didn't want to show, but for some odd reason, I cant get the lighting light, every thing is dark, still going to show any ways, need a break and wanted to share
discovered these free body & Head morphs, for G8, and gave it a try. enough to get some desired morphs in, happy I found it
did another render of G8F I dialed in, one thing that was off was the left eye, for some reason it doesn't move correctly, not sure if it something due from using the fre morphs or not, had to select the left eye and dial it in to look close to normal.
my DOF seemed to be a bit off, showing the render any ways, don't have time tonight to do another render
dunno why I be having problems getting that camera right
2 things since last image of Genesis 8, I fixed the eye problem, what it was one of the eye dials I turned off limits,
and I have her height, by useing G3F, and measure metrics , I don't have Measure metrics for Genesis 8, so just did stand in same spot adjust G8F to G3F height.
dialed another G3F
just something to do, nothing special
I think I am going ot call you the dail in King @XaatXuun!
some great renders!
thought I try out Genesis 8 female again, had something that also happens with G3F, once it happens can't remove it, but I can hide it, doesn't happen all the tine, and I figured how to avoid it with G3F, just need some practice with Genesis8, and should have that taken care of. I used another free morph and did some scaling to get the desired look.
don't know measuements
I think she looks amazing!!
You've been busy! I actually quite like this one, its very moody. I know the lights werent working right but I like it!
thank you
I was surprised she came out like that, with the limited dials I have for Genesis 8, was happy with the results
thanks
I didn't mind it, and thought it worthy enough to post here, still wanted better lighting, still at aloss why the lighting ended up so dark, later I removed the scene, and place the lights back in, and everything was fine. just haver not got back to actual render of it, I just like creating
tonights new G3F, I decided to see if I could dial in a over byte, google didn't show me what I was looking for , for some examples to go from, so here is my attempt
thought I would see what I could do with those free dials for Genesis 8 Male.
interesting how quick one can dial in morphs when you have few dials to use
I used a hair from G3M, now that I look at it, it should had been adjusted some
Wow you did a great job on the dial morphs!!!
Keep up the great work!
thank you
been a while, thought I would post something I recently dialed in
Excellent render! Nicely dialed in!
Hey, been a whie thought I post something
G3F
just head, where I put 10% of ever head I have in the dials
adjusted brows and eyes, and scalled nose smaller using Gia7 mats, Awesome eyes for the eyes
and that's it. Later I finsih up the body
todays dials was with G3M
couldn't find a background to go with this
did some adjusting of a previous model
GM3
Wow where did you get that neat mustache and hair!
Great looking character for sure!
Adrian Hair and Beard for Genesis 3 Male(s)
