Help clothing is white
elly_denate
Hello
I have a problem. dazz studio 4.10
When i put the texture on the clothing, it's looking good.
But. when I have render, the clothing is white, no texture.
What do i wrong?
gr Elly
Hello
What do i wrong?
gr Elly
Is this using Iray or 3Delight to render?
3Delight to Render.
It's probably the issue with the Age of Aromour SSS shader (or other Shader Mixer shader) not compiling properly -I suspect if you check the end of the log after rendering (Help>Troubleshooting>View Log File) you will find an error message about that, usually it's enough to clear the Render/Shader folder in the Temp folder and restart the render (or reload the scene, which should do the same).
Thanks for youre answer.
this is the log:
2019-02-13 22:38:47.409 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:38:47.411 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:38:47.413 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:38:47.414 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:38:47.415 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:38:47.437 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:38:48.576 Loaded image FWAyakoFace_1001.jpg
2019-02-13 22:38:49.131 Loaded image FWAyakoFaceBlush_1001.png
2019-02-13 22:38:58.083 Saved image: C:\Users\Driesen\AppData\Roaming\DAZ 3D\Studio4\temp\d49.png
2019-02-13 22:38:58.388 Loaded image FWAyakoFace_1001.jpg
2019-02-13 22:38:58.942 Loaded image FWAyakoFaceBlush_1001.png
2019-02-13 22:39:07.903 Saved image: C:\Users\Driesen\AppData\Roaming\DAZ 3D\Studio4\temp\d50.png
2019-02-13 22:39:07.923 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:07.923 Loaded file: ThighTwist_75_R.dsf
2019-02-13 22:39:07.925 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:07.925 Loaded file: ThighTwist_75_L-.dsf
2019-02-13 22:39:08.467 Loaded Morph Deltas in 0 min 0.5 sec.
2019-02-13 22:39:08.467 Loaded file: PHMTeenJosie8Iris.dsf
2019-02-13 22:39:08.470 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.470 Loaded file: MCMTeenJosie8Navel.dsf
2019-02-13 22:39:08.485 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.485 Loaded file: PBMNavel.dsf
2019-02-13 22:39:08.552 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.552 Loaded file: PHMEyelashesExpand.dsf
2019-02-13 22:39:08.555 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.555 Loaded file: PHMTeenJosie8Lashes.dsf
2019-02-13 22:39:08.558 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.558 Loaded file: FHMTeenJosie8Head.dsf
2019-02-13 22:39:08.560 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.560 Loaded file: FW_PHMLashes (8).dsf
2019-02-13 22:39:08.625 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.626 Loaded file: pJCMThumb1Bend_50_R.dsf
2019-02-13 22:39:08.630 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.630 Loaded file: pJCMThumb1Bend_50_L.dsf
2019-02-13 22:39:08.639 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.639 Loaded file: pJCMThighTwist_p75_R.dsf
2019-02-13 22:39:08.651 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.651 Loaded file: pJCMThighTwist_n75_L.dsf
2019-02-13 22:39:08.657 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.657 Loaded file: pJCMThighSideIn_26_R.dsf
2019-02-13 22:39:08.667 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.667 Loaded file: pJCMThighSideIn_26_L.dsf
2019-02-13 22:39:08.679 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.680 Loaded file: pJCMThighFwd_57_R.dsf
2019-02-13 22:39:08.685 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.685 Loaded file: pJCMThighFwd_57_L.dsf
2019-02-13 22:39:08.692 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.692 Loaded file: pJCMThigh_Side_p26_Twist_p75_R.dsf
2019-02-13 22:39:08.706 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.706 Loaded file: pJCMThigh_Side_n26_Twist_n75_L.dsf
2019-02-13 22:39:08.716 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.716 Loaded file: pJCMThigh_Bend_n115_Twist_p75_R.dsf
2019-02-13 22:39:08.728 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.729 Loaded file: pJCMThigh_Bend_n115_Twist_n75_L.dsf
2019-02-13 22:39:08.743 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.743 Loaded file: pJCMThigh_Bend_n115_Side_p26_R.dsf
2019-02-13 22:39:08.755 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.755 Loaded file: pJCMThigh_Bend_n115_Side_n26_L.dsf
2019-02-13 22:39:08.768 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.768 Loaded file: pJCMShldrFwd_110_R.dsf
2019-02-13 22:39:08.782 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.782 Loaded file: pJCMShldrFront_p110_Bend_p40_R.dsf
2019-02-13 22:39:08.791 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.791 Loaded file: pJCMShldrDown_40_R.dsf
2019-02-13 22:39:08.796 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.796 Loaded file: pJCMShldrDown_40_L.dsf
2019-02-13 22:39:08.804 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.804 Loaded file: pJCMShinBend_90_R.dsf
2019-02-13 22:39:08.808 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.808 Loaded file: pJCMShinBend_90_L.dsf
2019-02-13 22:39:08.813 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.813 Loaded file: pJCMPectoralUp_10_R.dsf
2019-02-13 22:39:08.821 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.821 Loaded file: pJCMPectoralUp_10_L.dsf
2019-02-13 22:39:08.825 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.825 Loaded file: pJCMPectoralTwist_p15_R.dsf
2019-02-13 22:39:08.835 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.835 Loaded file: pJCMPectoralSide_In_R.dsf
2019-02-13 22:39:08.844 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.844 Loaded file: pJCMNeckUpperTwist_R.dsf
2019-02-13 22:39:08.874 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.874 Loaded file: pJCMNeckUpperSide_L.dsf
2019-02-13 22:39:08.889 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.890 Loaded file: pJCMNeckTwist_Reverse.dsf
2019-02-13 22:39:08.911 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.911 Loaded file: pJCMNeckTwist_22_L.dsf
2019-02-13 22:39:08.914 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.914 Loaded file: pJCMNeckLowerSide_40_R.dsf
2019-02-13 22:39:08.964 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.964 Loaded file: pJCMNeckFwd_35.dsf
2019-02-13 22:39:08.977 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.977 Loaded file: pJCMHeadBack_27.dsf
2019-02-13 22:39:08.981 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:08.981 Loaded file: pJCMHandUp_80_R.dsf
2019-02-13 22:39:09.016 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.016 Loaded file: pJCMHandUp_80_L.dsf
2019-02-13 22:39:09.028 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.028 Loaded file: pJCMForeArmFwd_75_R.dsf
2019-02-13 22:39:09.076 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.076 Loaded file: pJCMForeArmFwd_75_L.dsf
2019-02-13 22:39:09.082 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.082 Loaded file: pJCMForeArmFwd_135_L.dsf
2019-02-13 22:39:09.090 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.090 Loaded file: pJCMCollarUp_55_R.dsf
2019-02-13 22:39:09.102 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.102 Loaded file: pJCMCollarTwist_p30_R.dsf
2019-02-13 22:39:09.116 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.116 Loaded file: pJCMCollarTwist_p30_L.dsf
2019-02-13 22:39:09.128 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.128 Loaded file: pJCMCollarFwd_26_R.dsf
2019-02-13 22:39:09.139 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.139 Loaded file: pJCMCollarDown_10_L.dsf
2019-02-13 22:39:09.144 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.144 Loaded file: pJCMCollarBack_17_L.dsf
2019-02-13 22:39:09.152 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.152 Loaded file: pJCMChestSide_20_L.dsf
2019-02-13 22:39:09.163 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.163 Loaded file: pJCMBothLegsFront.dsf
2019-02-13 22:39:09.169 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.169 Loaded file: pJCMAbdomenUpperFwd_Navel.dsf
2019-02-13 22:39:09.181 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.181 Loaded file: pJCMAbdomen2Side_24_R.dsf
2019-02-13 22:39:09.196 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.196 Loaded file: pJCMAbdomen2Fwd_40.dsf
2019-02-13 22:39:09.214 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.214 Loaded file: FBMTeenJosie8Body.dsf
2019-02-13 22:39:09.412 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:09.413 Loaded file: pJCMShinBend_90_L.dsf
2019-02-13 22:39:09.563 Loaded Morph Deltas in 0 min 0.1 sec.
2019-02-13 22:39:09.563 Loaded file: FBMTeenJosie8Body.dsf
2019-02-13 22:39:10.179 Loaded Morph Deltas in 0 min 0.4 sec.
2019-02-13 22:39:10.179 Loaded file: FHMTeenJosie8Head.dsf
2019-02-13 22:39:10.481 Loaded Morph Deltas in 0 min 0.3 sec.
2019-02-13 22:39:10.481 Loaded file: FBMTeenJosie8Body.dsf
2019-02-13 22:39:10.535 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:10.536 Loaded file: pJCMNeckTwist_22_L.dsf
2019-02-13 22:39:10.701 Loaded Morph Deltas in 0 min 0.1 sec.
2019-02-13 22:39:10.701 Loaded file: pJCMNeckLowerSide_40_R.dsf
2019-02-13 22:39:10.989 Loaded Morph Deltas in 0 min 0.2 sec.
2019-02-13 22:39:10.989 Loaded file: pJCMNeckFwd_35.dsf
2019-02-13 22:39:11.287 Loaded Morph Deltas in 0 min 0.2 sec.
2019-02-13 22:39:11.287 Loaded file: pJCMHeadBack_27.dsf
2019-02-13 22:39:11.312 Loaded Morph Deltas in 0 min 0.0 sec.
2019-02-13 22:39:11.312 Loaded file: Right Behind Shoulder.dsf
2019-02-13 22:39:27.476 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:39:27.487 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:39:27.498 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:39:27.509 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:39:27.521 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:39:27.533 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:39:27.544 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:39:27.555 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:39:27.666 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-13 22:39:29.508 Loaded image FWAyakoLegs_1003.jpg
2019-02-13 22:39:29.792 Loaded image FWAyakoEyes04_1007.jpg
2019-02-13 22:39:30.133 Loaded image FWAyakoArms_1004.jpg
2019-02-13 22:39:30.382 Loaded image FWAyakoMouth_1005.jpg
2019-02-13 22:39:30.756 Loaded image FWAyakoFace_1001.jpg
2019-02-13 22:39:31.198 Loaded image FWAyakoFaceLips05_1001.jpg
2019-02-13 22:39:31.531 Loaded image FWAyakoFace_1001.jpg
2019-02-13 22:39:32.095 Loaded image FWAyakoFaceBlush_1001.png
2019-02-13 22:39:32.709 Loaded image FWAyakoTorso_1002.jpg
2019-02-13 22:39:32.811 Loaded image EM5B74~1.JPG
2019-02-13 22:39:32.988 Loaded image EM5421~1.JPG
2019-02-13 22:39:33.505 Loaded image EMF03B~1.JPG
2019-02-13 22:39:33.965 Loaded image EM330A~1.JPG
2019-02-13 22:39:34.252 Loaded image EM76FE~1.JPG
2019-02-13 22:39:34.625 Loaded image EM4E4D~1.JPG
2019-02-13 22:39:34.903 Loaded image EM7819~1.JPG
2019-02-13 22:39:35.127 Loaded image FWAyakoFaceEyemoistureMap_1001.jpg
2019-02-13 22:39:35.247 Loaded image FWAyakoLashes_1001.jpg
2019-02-13 22:39:35.606 Loaded image aprblth_txblueyellow.jpg
2019-02-13 22:39:35.858 Loaded image aprblth_trans.jpg
2019-02-13 22:39:36.016 Ran tdlmake on image I:/Alles van Poser en Dazz/Dazz materialen/000000 alle caracters bij elkaar-female/Content/Runtime/Textures/FWArt/Ayako/FWAyakoTorso_1002.jpg
2019-02-13 22:39:37.825 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement.sdl...
2019-02-13 22:39:37.825 stdin: in function shader_Displacement
stdin:447: WARNING: 'calculatenormal' function may have unexpected results since 'Pbp' in parameter number 1 is defined in a varying condition
stdin:460: WARNING: 'calculatenormal' function may have unexpected results since 'Pbp' in parameter number 1 is defined in a varying condition
2019-02-13 22:39:38.056 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement.sdl...
2019-02-13 22:39:38.056 stdin: in function shader_Displacement
2019-02-13 22:39:38.057 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement.sdl...
2019-02-13 22:39:38.057 stdin: in function shader_Displacement
2019-02-13 22:39:38.058 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement.sdl...
2019-02-13 22:39:38.058 stdin: in function shader_Displacement
2019-02-13 22:39:39.246 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface.sdl...
2019-02-13 22:39:39.324 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface.sdl...
2019-02-13 22:39:39.514 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface.sdl...
2019-02-13 22:39:39.829 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface.sdl...
2019-02-13 22:39:52.502 *** Scene Cleared ***
2019-02-13 22:39:53.770 Ran tdlmake on image I:/Alles van Poser en Dazz/Dazz materialen/000000 alle caracters bij elkaar-female/Content/Runtime/Textures/FWArt/Ayako/FWAyakoTorsoS_1002.jpg
2019-02-13 22:39:56.428 Ran tdlmake on image I:/Alles van Poser en Dazz/Dazz materialen/000000 alle caracters bij elkaar-female/Content/Runtime/Textures/FWArt/Ayako/FWAyakoTorsoN_1002.jpg
2019-02-13 22:39:57.148 Ran tdlmake on image I:/Alles van Poser en Dazz/Dazz materialen/000000 alle caracters bij elkaar-female/Content/Runtime/Textures/FWArt/Ayako/FWAyakoTorsoB_1002.jpg
2019-02-13 22:39:57.691 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2019-02-13 22:39:57.694 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2019-02-13 22:39:57.932 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2019-02-13 22:39:58.297 *** Scene Cleared ***
2019-02-13 22:39:58.435 File loaded in 0 min 0.1 sec.
2019-02-13 22:39:58.436 Loaded file: Cozy At Home Prop Mug.duf
2019-02-13 22:39:58.662 Loaded image emandjoAtHomeMug3.jpg
2019-02-13 22:39:58.684 Ran tdlmake on image H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg
2019-02-13 22:39:58.703 ERROR: 3Delight Process exited abnormally: "C:/Program Files/DAZ 3D/DAZStudio4/bin/tdlmake.exe -mode periodic -deflate H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/d91_emandjoAtHomeMug3.tdl"
tdlmake: cannot open input file 'H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg'
tdlmake: error while making texture file
2019-02-13 22:39:58.704 tdlmake failed to create tdl for image H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg
2019-02-13 22:40:01.091 Ran tdlmake on image C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/d49.png
2019-02-13 22:45:30.943 Loaded image EMDA74~1.JPG
2019-02-13 22:45:37.331 Loaded image EMDA74~1.JPG
2019-02-13 22:46:53.343 *** Scene Cleared ***
2019-02-13 22:46:58.694 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2019-02-13 22:46:58.695 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2019-02-13 22:46:59.079 *** Scene Cleared ***
2019-02-13 22:46:59.127 File loaded in 0 min 0.0 sec.
2019-02-13 22:46:59.127 Loaded file: Cozy At Home Prop Mug.duf
2019-02-13 22:46:59.362 Loaded image emandjoAtHomeMug3.jpg
2019-02-13 22:46:59.402 Ran tdlmake on image H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg
2019-02-13 22:46:59.403 ERROR: 3Delight Process exited abnormally: "C:/Program Files/DAZ 3D/DAZStudio4/bin/tdlmake.exe -mode periodic -deflate H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/d92_emandjoAtHomeMug3.tdl"
2019-02-13 22:46:59.404 tdlmake failed to create tdl for image H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg
2019-02-13 22:47:25.203 Loaded image EMDA74~1.JPG
2019-02-13 22:47:29.123 Loaded image EMDA74~1.JPG
2019-02-13 22:47:32.528 WARNING: Object::disconnect: Unexpected null parameter
2019-02-13 22:47:51.975 +++++++++++++++ DAZ Studio 4.10.0.123 starting +++++++++++++++++
2019-02-13 22:47:51.975 Platform bits: 64
2019-02-13 22:47:51.975 Qt Version: 4.8.7
2019-02-13 22:47:51.975 OpenSubdiv Version: 3.0.0
2019-02-13 22:47:51.975 Running on Windows 10, Build 9200, No Service Pack Installed
2019-02-13 22:47:51.975 CPU Information:
2019-02-13 22:47:51.975 CPU String: GenuineIntel
2019-02-13 22:47:51.975 CPU Brand String: Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
2019-02-13 22:47:51.975 Cache Line Size = 64
I hope you see what is wrong.
Greetings Elly
The errors relate to failures to process images, on the Emma and Jordi At Home Outfit https://www.daz3d.com/dforce-cozy-outfit--props-and-poses-for-genesis-8-females - is that what is giving you problems? How did you install it if so?
I have the content via edith prefence manager in Dazz 3D placed.
My girlfriend has do dit to, and she have no problems.
Why have i the problems and not she?
Thank you that you will help me.
greetings from Elly
I'm not sure what you mean about the installaltion method.
If you find the H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg in an image editor does it load correctly? (Is that all the path? Does that mean you have a separate content directory for every product?)
Pffffffffffff my Englisch is not so good
I ame from Holland.
I have this clothing on my externe HD.
in this case is this the H externe.
wen I make de clothing, en the texture it looks oke.
But when i Render it's not oke.
Sie my printscreens.
This is before render:
http://nl.tinypic.com/r/iodvzb/9
This is after Render:
http://i65.tinypic.com/312ifly.png
http://nl.tinypic.com/r/312ifly/9
I see. Could you try switching your render engine to Iray, apply the Iray materials, and render? If your system is slow you don't need to let it finish - I just want to see if it works at all.
oke
but I have trial this.....
i go to to this again, and let see it to you.
no that don't work, i see nothing.
maby you can looking with me, on my pc with teamviewer.
Than you can see what is wrong.
greetings from elly
I think you may need to open a Technical Support ticket https://www.daz3d.com/help/help-contact-us
Oke I trai
Thanxs
gr Elly
