Help clothing is white
Hello
I have a problem. dazz studio 4.10
When i put the texture on the clothing, it's looking good.
But. when I have render, the clothing is white, no texture.
What do i wrong?
gr Elly
  • Is this using Iray or 3Delight to render?
  • 3Delight to Render.
  • It's probably the issue with the Age of Aromour SSS shader (or other Shader Mixer shader) not compiling properly  -I suspect if you check the end of the log after rendering (Help>Troubleshooting>View Log File) you will find an error message about that, usually it's enough to clear the Render/Shader folder in the Temp folder and restart the render (or reload the scene, which should do the same).
  • Thanks for youre answer.
    this is the log:
    2019-02-13 22:38:47.409 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:38:47.411 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:38:47.413 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:38:47.414 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:38:47.415 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:38:47.437 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:38:48.576 Loaded image FWAyakoFace_1001.jpg
    2019-02-13 22:38:49.131 Loaded image FWAyakoFaceBlush_1001.png
    2019-02-13 22:38:58.083 Saved image: C:\Users\Driesen\AppData\Roaming\DAZ 3D\Studio4\temp\d49.png
    2019-02-13 22:38:58.388 Loaded image FWAyakoFace_1001.jpg
    2019-02-13 22:38:58.942 Loaded image FWAyakoFaceBlush_1001.png
    2019-02-13 22:39:07.903 Saved image: C:\Users\Driesen\AppData\Roaming\DAZ 3D\Studio4\temp\d50.png
    2019-02-13 22:39:07.923 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:07.923 Loaded file: ThighTwist_75_R.dsf
    2019-02-13 22:39:07.925 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:07.925 Loaded file: ThighTwist_75_L-.dsf
    2019-02-13 22:39:08.467 Loaded Morph Deltas in 0 min 0.5 sec.
    2019-02-13 22:39:08.467 Loaded file: PHMTeenJosie8Iris.dsf
    2019-02-13 22:39:08.470 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.470 Loaded file: MCMTeenJosie8Navel.dsf
    2019-02-13 22:39:08.485 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.485 Loaded file: PBMNavel.dsf
    2019-02-13 22:39:08.552 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.552 Loaded file: PHMEyelashesExpand.dsf
    2019-02-13 22:39:08.555 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.555 Loaded file: PHMTeenJosie8Lashes.dsf
    2019-02-13 22:39:08.558 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.558 Loaded file: FHMTeenJosie8Head.dsf
    2019-02-13 22:39:08.560 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.560 Loaded file: FW_PHMLashes (8).dsf
    2019-02-13 22:39:08.625 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.626 Loaded file: pJCMThumb1Bend_50_R.dsf
    2019-02-13 22:39:08.630 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.630 Loaded file: pJCMThumb1Bend_50_L.dsf
    2019-02-13 22:39:08.639 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.639 Loaded file: pJCMThighTwist_p75_R.dsf
    2019-02-13 22:39:08.651 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.651 Loaded file: pJCMThighTwist_n75_L.dsf
    2019-02-13 22:39:08.657 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.657 Loaded file: pJCMThighSideIn_26_R.dsf
    2019-02-13 22:39:08.667 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.667 Loaded file: pJCMThighSideIn_26_L.dsf
    2019-02-13 22:39:08.679 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.680 Loaded file: pJCMThighFwd_57_R.dsf
    2019-02-13 22:39:08.685 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.685 Loaded file: pJCMThighFwd_57_L.dsf
    2019-02-13 22:39:08.692 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.692 Loaded file: pJCMThigh_Side_p26_Twist_p75_R.dsf
    2019-02-13 22:39:08.706 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.706 Loaded file: pJCMThigh_Side_n26_Twist_n75_L.dsf
    2019-02-13 22:39:08.716 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.716 Loaded file: pJCMThigh_Bend_n115_Twist_p75_R.dsf
    2019-02-13 22:39:08.728 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.729 Loaded file: pJCMThigh_Bend_n115_Twist_n75_L.dsf
    2019-02-13 22:39:08.743 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.743 Loaded file: pJCMThigh_Bend_n115_Side_p26_R.dsf
    2019-02-13 22:39:08.755 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.755 Loaded file: pJCMThigh_Bend_n115_Side_n26_L.dsf
    2019-02-13 22:39:08.768 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.768 Loaded file: pJCMShldrFwd_110_R.dsf
    2019-02-13 22:39:08.782 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.782 Loaded file: pJCMShldrFront_p110_Bend_p40_R.dsf
    2019-02-13 22:39:08.791 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.791 Loaded file: pJCMShldrDown_40_R.dsf
    2019-02-13 22:39:08.796 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.796 Loaded file: pJCMShldrDown_40_L.dsf
    2019-02-13 22:39:08.804 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.804 Loaded file: pJCMShinBend_90_R.dsf
    2019-02-13 22:39:08.808 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.808 Loaded file: pJCMShinBend_90_L.dsf
    2019-02-13 22:39:08.813 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.813 Loaded file: pJCMPectoralUp_10_R.dsf
    2019-02-13 22:39:08.821 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.821 Loaded file: pJCMPectoralUp_10_L.dsf
    2019-02-13 22:39:08.825 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.825 Loaded file: pJCMPectoralTwist_p15_R.dsf
    2019-02-13 22:39:08.835 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.835 Loaded file: pJCMPectoralSide_In_R.dsf
    2019-02-13 22:39:08.844 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.844 Loaded file: pJCMNeckUpperTwist_R.dsf
    2019-02-13 22:39:08.874 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.874 Loaded file: pJCMNeckUpperSide_L.dsf
    2019-02-13 22:39:08.889 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.890 Loaded file: pJCMNeckTwist_Reverse.dsf
    2019-02-13 22:39:08.911 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.911 Loaded file: pJCMNeckTwist_22_L.dsf
    2019-02-13 22:39:08.914 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.914 Loaded file: pJCMNeckLowerSide_40_R.dsf
    2019-02-13 22:39:08.964 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.964 Loaded file: pJCMNeckFwd_35.dsf
    2019-02-13 22:39:08.977 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.977 Loaded file: pJCMHeadBack_27.dsf
    2019-02-13 22:39:08.981 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:08.981 Loaded file: pJCMHandUp_80_R.dsf
    2019-02-13 22:39:09.016 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.016 Loaded file: pJCMHandUp_80_L.dsf
    2019-02-13 22:39:09.028 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.028 Loaded file: pJCMForeArmFwd_75_R.dsf
    2019-02-13 22:39:09.076 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.076 Loaded file: pJCMForeArmFwd_75_L.dsf
    2019-02-13 22:39:09.082 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.082 Loaded file: pJCMForeArmFwd_135_L.dsf
    2019-02-13 22:39:09.090 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.090 Loaded file: pJCMCollarUp_55_R.dsf
    2019-02-13 22:39:09.102 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.102 Loaded file: pJCMCollarTwist_p30_R.dsf
    2019-02-13 22:39:09.116 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.116 Loaded file: pJCMCollarTwist_p30_L.dsf
    2019-02-13 22:39:09.128 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.128 Loaded file: pJCMCollarFwd_26_R.dsf
    2019-02-13 22:39:09.139 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.139 Loaded file: pJCMCollarDown_10_L.dsf
    2019-02-13 22:39:09.144 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.144 Loaded file: pJCMCollarBack_17_L.dsf
    2019-02-13 22:39:09.152 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.152 Loaded file: pJCMChestSide_20_L.dsf
    2019-02-13 22:39:09.163 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.163 Loaded file: pJCMBothLegsFront.dsf
    2019-02-13 22:39:09.169 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.169 Loaded file: pJCMAbdomenUpperFwd_Navel.dsf
    2019-02-13 22:39:09.181 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.181 Loaded file: pJCMAbdomen2Side_24_R.dsf
    2019-02-13 22:39:09.196 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.196 Loaded file: pJCMAbdomen2Fwd_40.dsf
    2019-02-13 22:39:09.214 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.214 Loaded file: FBMTeenJosie8Body.dsf
    2019-02-13 22:39:09.412 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:09.413 Loaded file: pJCMShinBend_90_L.dsf
    2019-02-13 22:39:09.563 Loaded Morph Deltas in 0 min 0.1 sec.
    2019-02-13 22:39:09.563 Loaded file: FBMTeenJosie8Body.dsf
    2019-02-13 22:39:10.179 Loaded Morph Deltas in 0 min 0.4 sec.
    2019-02-13 22:39:10.179 Loaded file: FHMTeenJosie8Head.dsf
    2019-02-13 22:39:10.481 Loaded Morph Deltas in 0 min 0.3 sec.
    2019-02-13 22:39:10.481 Loaded file: FBMTeenJosie8Body.dsf
    2019-02-13 22:39:10.535 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:10.536 Loaded file: pJCMNeckTwist_22_L.dsf
    2019-02-13 22:39:10.701 Loaded Morph Deltas in 0 min 0.1 sec.
    2019-02-13 22:39:10.701 Loaded file: pJCMNeckLowerSide_40_R.dsf
    2019-02-13 22:39:10.989 Loaded Morph Deltas in 0 min 0.2 sec.
    2019-02-13 22:39:10.989 Loaded file: pJCMNeckFwd_35.dsf
    2019-02-13 22:39:11.287 Loaded Morph Deltas in 0 min 0.2 sec.
    2019-02-13 22:39:11.287 Loaded file: pJCMHeadBack_27.dsf
    2019-02-13 22:39:11.312 Loaded Morph Deltas in 0 min 0.0 sec.
    2019-02-13 22:39:11.312 Loaded file: Right Behind Shoulder.dsf
    2019-02-13 22:39:27.476 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:39:27.487 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:39:27.498 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:39:27.509 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:39:27.521 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:39:27.533 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:39:27.544 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:39:27.555 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:39:27.666 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
    2019-02-13 22:39:29.508 Loaded image FWAyakoLegs_1003.jpg
    2019-02-13 22:39:29.792 Loaded image FWAyakoEyes04_1007.jpg
    2019-02-13 22:39:30.133 Loaded image FWAyakoArms_1004.jpg
    2019-02-13 22:39:30.382 Loaded image FWAyakoMouth_1005.jpg
    2019-02-13 22:39:30.756 Loaded image FWAyakoFace_1001.jpg
    2019-02-13 22:39:31.198 Loaded image FWAyakoFaceLips05_1001.jpg
    2019-02-13 22:39:31.531 Loaded image FWAyakoFace_1001.jpg
    2019-02-13 22:39:32.095 Loaded image FWAyakoFaceBlush_1001.png
    2019-02-13 22:39:32.709 Loaded image FWAyakoTorso_1002.jpg
    2019-02-13 22:39:32.811 Loaded image EM5B74~1.JPG
    2019-02-13 22:39:32.988 Loaded image EM5421~1.JPG
    2019-02-13 22:39:33.505 Loaded image EMF03B~1.JPG
    2019-02-13 22:39:33.965 Loaded image EM330A~1.JPG
    2019-02-13 22:39:34.252 Loaded image EM76FE~1.JPG
    2019-02-13 22:39:34.625 Loaded image EM4E4D~1.JPG
    2019-02-13 22:39:34.903 Loaded image EM7819~1.JPG
    2019-02-13 22:39:35.127 Loaded image FWAyakoFaceEyemoistureMap_1001.jpg
    2019-02-13 22:39:35.247 Loaded image FWAyakoLashes_1001.jpg
    2019-02-13 22:39:35.606 Loaded image aprblth_txblueyellow.jpg
    2019-02-13 22:39:35.858 Loaded image aprblth_trans.jpg
    2019-02-13 22:39:36.016 Ran tdlmake on image I:/Alles van Poser en Dazz/Dazz materialen/000000 alle caracters bij elkaar-female/Content/Runtime/Textures/FWArt/Ayako/FWAyakoTorso_1002.jpg
    2019-02-13 22:39:37.825 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement.sdl...
    2019-02-13 22:39:37.825 stdin: in function shader_Displacement
    stdin:447: WARNING: 'calculatenormal' function may have unexpected results since 'Pbp' in parameter number 1 is defined in a varying condition
    stdin:460: WARNING: 'calculatenormal' function may have unexpected results since 'Pbp' in parameter number 1 is defined in a varying condition
    2019-02-13 22:39:38.056 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement.sdl...
    2019-02-13 22:39:38.056 stdin: in function shader_Displacement
    2019-02-13 22:39:38.057 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement.sdl...
    2019-02-13 22:39:38.057 stdin: in function shader_Displacement
    2019-02-13 22:39:38.058 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement.sdl...
    2019-02-13 22:39:38.058 stdin: in function shader_Displacement
    2019-02-13 22:39:39.246 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface.sdl...
    2019-02-13 22:39:39.324 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface.sdl...
    2019-02-13 22:39:39.514 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface.sdl...
    2019-02-13 22:39:39.829 Compiled C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface.sdl...
    2019-02-13 22:39:52.502 *** Scene Cleared ***
    2019-02-13 22:39:53.770 Ran tdlmake on image I:/Alles van Poser en Dazz/Dazz materialen/000000 alle caracters bij elkaar-female/Content/Runtime/Textures/FWArt/Ayako/FWAyakoTorsoS_1002.jpg
    2019-02-13 22:39:56.428 Ran tdlmake on image I:/Alles van Poser en Dazz/Dazz materialen/000000 alle caracters bij elkaar-female/Content/Runtime/Textures/FWArt/Ayako/FWAyakoTorsoN_1002.jpg
    2019-02-13 22:39:57.148 Ran tdlmake on image I:/Alles van Poser en Dazz/Dazz materialen/000000 alle caracters bij elkaar-female/Content/Runtime/Textures/FWArt/Ayako/FWAyakoTorsoB_1002.jpg
    2019-02-13 22:39:57.691 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2019-02-13 22:39:57.694 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2019-02-13 22:39:57.932 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2019-02-13 22:39:58.297 *** Scene Cleared ***
    2019-02-13 22:39:58.435 File loaded in 0 min 0.1 sec.
    2019-02-13 22:39:58.436 Loaded file: Cozy At Home Prop Mug.duf
    2019-02-13 22:39:58.662 Loaded image emandjoAtHomeMug3.jpg
    2019-02-13 22:39:58.684 Ran tdlmake on image H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg
    2019-02-13 22:39:58.703 ERROR: 3Delight Process exited abnormally: "C:/Program Files/DAZ 3D/DAZStudio4/bin/tdlmake.exe -mode periodic -deflate H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/d91_emandjoAtHomeMug3.tdl"
     tdlmake: cannot open input file 'H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg'
    tdlmake: error while making texture file
    2019-02-13 22:39:58.704 tdlmake failed to create tdl for image H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg
    2019-02-13 22:40:01.091 Ran tdlmake on image C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/d49.png
    2019-02-13 22:45:30.943 Loaded image EMDA74~1.JPG
    2019-02-13 22:45:37.331 Loaded image EMDA74~1.JPG
    2019-02-13 22:46:53.343 *** Scene Cleared ***
    2019-02-13 22:46:58.694 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2019-02-13 22:46:58.695 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2019-02-13 22:46:59.079 *** Scene Cleared ***
    2019-02-13 22:46:59.127 File loaded in 0 min 0.0 sec.
    2019-02-13 22:46:59.127 Loaded file: Cozy At Home Prop Mug.duf
    2019-02-13 22:46:59.362 Loaded image emandjoAtHomeMug3.jpg
    2019-02-13 22:46:59.402 Ran tdlmake on image H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg
    2019-02-13 22:46:59.403 ERROR: 3Delight Process exited abnormally: "C:/Program Files/DAZ 3D/DAZStudio4/bin/tdlmake.exe -mode periodic -deflate H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg C:/Users/Driesen/AppData/Roaming/DAZ 3D/Studio4/temp/d92_emandjoAtHomeMug3.tdl"
    2019-02-13 22:46:59.404 tdlmake failed to create tdl for image H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg
    2019-02-13 22:47:25.203 Loaded image EMDA74~1.JPG
    2019-02-13 22:47:29.123 Loaded image EMDA74~1.JPG
    2019-02-13 22:47:32.528 WARNING: Object::disconnect: Unexpected null parameter
    2019-02-13 22:47:51.975 +++++++++++++++ DAZ Studio 4.10.0.123 starting +++++++++++++++++
    2019-02-13 22:47:51.975 Platform bits: 64
    2019-02-13 22:47:51.975 Qt Version: 4.8.7
    2019-02-13 22:47:51.975 OpenSubdiv Version: 3.0.0
    2019-02-13 22:47:51.975 Running on Windows 10, Build 9200, No Service Pack Installed
    2019-02-13 22:47:51.975 CPU Information:
    2019-02-13 22:47:51.975  CPU String: GenuineIntel
    2019-02-13 22:47:51.975  CPU Brand String: Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
    2019-02-13 22:47:51.975  Cache Line Size = 64
    I hope you see what is wrong.
    Greetings Elly
  • The errors relate to failures to process images, on the Emma and Jordi At Home Outfit https://www.daz3d.com/dforce-cozy-outfit--props-and-poses-for-genesis-8-females - is that what is giving you problems? How did you install it if so?
  • I have the content via edith prefence manager in Dazz 3D placed.
    My girlfriend has do dit to, and she have no problems.
    Why have i the problems and not she?
    Thank you that you will help me.
    greetings from Elly
  • I'm not sure what you mean about the installaltion method.
    If you find the H:/alles van poser en dazz/Dazz materialen 3 .vervolg/Gen 8 Female/kleding/dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/58327 dForce Cozy Outfit - Props and Poses For Genesis 8 Female(s)/Content/Runtime/Textures/EmmaAndJordi/AtHomeOutfit/emandjoAtHomeMug3.jpg in an image editor does it load correctly? (Is that all the path? Does that mean you have a separate content directory for every product?)
  • Pffffffffffff my Englisch is not so good
    I ame from Holland.
    I have this clothing on my externe HD.
    in this case is this the H externe.
    wen I make de clothing, en the texture it looks oke.
    But when i Render it's not oke.
    Sie my printscreens.
    This is before render:
    http://nl.tinypic.com/r/iodvzb/9
    This is after Render:
    http://i65.tinypic.com/312ifly.png
    http://nl.tinypic.com/r/312ifly/9
  • I see. Could you try switching your render engine to Iray, apply the Iray materials, and render? If your system is slow you don't need to let it finish - I just want to see if it works at all.
  • oke
    but I have trial this.....
    i go to to this again, and let see it to you.
  • no that don't work, i see nothing.
    maby you can looking with me, on my pc with teamviewer.
    Than you can see what is wrong.
    greetings from elly
  • I think you may need to open a Technical Support ticket https://www.daz3d.com/help/help-contact-us
  • Oke I trai
    Thanxs
    gr Elly
