Mec4d's Beards and Bodyhair are here! Hurray!
12346»
  • mawkroymawkroy Posts: 21
    I've tried using different settings including UberEnvironment, UberSurface2, etc and never get anything that even looks like the demo product pictures. Can you go into some more detail please?
    What are your settings on the Render tab?
    I am using the default best quality settings.
  • DisparateDreamerDisparateDreamer Posts: 2,520
    Under the rRender settings, click on advanced tab. what are your settings there?
    Render Style: Shader: Default
    Dimensions: Active Viewport
    Render To: Still Image (Current Frame)
    Render Engine: 3Delight
    Progressive Rendering: Unchecked
    Bucket Order: Horizontal
    Bucket Size: 16
    Max Ray Trace Depth: 2
    Pixel Samples (X): 4
    Pixel Samples (Y): 4
    Shadow Samples: 16
    Gain: 1.00
    Gamma Correction: Off
    Gamma: 1.00
    Shading Rate: 1.00
    Pixel Filter: Sinc
    Pixel Filter Width (X): 6.00
    Pixel Filter Width (Y): 6.00
    Motion Blur: Unchecked
    Render to RIB: Unchecked
    522 x 1051 - 131K
  • jepegraphicsjepegraphics Posts: 892
    These are my render settings, I would say the most important thing is the Shading Rate at 0.1 or lower, the Pixel Samples and the Shadow Samples - make sure that you have the light properties set accordingly too.
    Of course such render settings require a bit more time, sometimes with transmapped hair also a lot more time than usual 2 minutes renders.
    1000 x 796 - 219K
    442 x 858 - 49K
  • starionwolfstarionwolf Posts: 3,670
    nice render. I was looking for beards and bodyhair for Genesis. now just need to save some money to buy the products.
    Thank you, starionwolf, I should better say that half of the body hair is painted on already, the Mec4D hair adds the 3rd dimension and blends very well into the texture. Skin is my Kenny here at DAZ.
  • neweliesnewelies Posts: 18
    Sorry if it has been asked before but can you change the colour of the beard? Bought this the other day :)
  • Zev0Zev0 Posts: 7,123
    Yes, just change the diffuse colour. If the hair is using a texture map, alternatively edit the colour of that in photoshop.
    THANKYOU!
  • tdctdc Posts: 132
    I just bought this, installed it using Install Manager... and I can't find it within the program. Shouldn't it be under Hair?
  • fixmypcmikefixmypcmike Posts: 19,711
    You can find new icons for loading this product in the following Poser Libraries:
    Hair: “Unshaven Beard for Genesis”
    You can find new icons for loading this product in the following DAZ Studio Folders:
    “People:Genesis:Hair:Mec4D”
    You can find new icons for this product in the following DAZ Studio Categories:
    “Hair:Face”
  • tdctdc Posts: 132
    “Hair:Face”
    So, it's nowhere to be found. After I uninstalled, I reinstalled and still nothing. I'm new, so forgive me
    “Hair:Face”
    What application and version are you using?
  • edited March 2015
    I don't find any tutorial online. Is the hair mesh-based or fiber-hair?
    Or is the manual / tutorial only contained in the product?
    I would really like to know because I am looking for mesh-based hair.
    Post edited by johann.hesters_2e9dd0ece9 on
  • scathascatha Posts: 756
    I'm quite sure this is a fiber mesh. Fiber mesh hair is still a mesh however.
  • Oso3DOso3D Posts: 15,100
    Since this popped up, I'd love Genesis 2 versions...
