Adding to Cart…
Seems like a simple enough question. I haven't discovered an answer yet in these forums. Can Bryce 7.x work on a 64 bit Windows platform, yes or no? I'm using Windows 10 64 bit and would like to download Bryce 7.1. But the specs say 32 bit only - so I'm going to assume no.
Simple answer yes
For a more in depth answer you will need to check through the forum, there are several threads about using Bryce on a widows 10 machine.
I use mine on a quad core 64 bit machine, but have refused to upgrade past Windows 7. However I do know people are working onit Bryce on windows 10.
This is just one of several threads https://www.daz3d.com/forums/discussion/64708/bryce-7-1-pro-and-windows-10
I run Bryce Pro 7.1 on an I7-6700 Windows 10 build 1809 without the side by side. No trouble!
Thanks for the help Chohole.
Bonjour
J'ai un soucis avec Bryce, il se lance bien, mais si j'ouvre un fichier .brc j'ai le message "Bryce.exe caused an EXCEPTION_ACCESS_VIOLATION in module Bryce.exe at 0023:00617BCA"
Ce fichier a été exporté par le logiciel CarScanner.
Et dans lle Stack Trace il y a plein de dll ainsi bien sur que Bryce :
Axiom.dll
User32.dll
ntdl.dll
wrusr.dll
Comment donc utiliser Bryce sans ces erreurs ?
Merci
