dazStudio.exe caused ACCESS_VIOLATION at 0033:00000000631A295F
I'm getting this error ("dazStudio.exe caused ACCESS_VIOLATION at 0033:00000000631A295F"). I re-installed daz and grapichs card driver multiple times. I've been working on it for several hours but no solution. You can see my logs attached. can you please help?
I seem to recall that this may be something to do with the GPU driver. There have been other threads on this
I Have read all of them usually the problem is causing from GPU Driver as you say, but in this case I've already re-installed and updated every driver but I Could'nt solve it. Any spesific solutions?
Is the Intel GPU the only one your system has, or do you also have a dedicated nVidia/AMD GPU? If you do have a dedicated GPU try telling DS to use that - I beleive you will find the option in the nVidoa or Catalyst Control Panel, the nVidia at least being accessible via a right-click on the desktop.
I Have GTX 1050ti and i5 7300hq. But I'm using 1050ti to open DS
The log file shows it as using the Intel chip.
