dazStudio.exe caused ACCESS_VIOLATION at 0033:00000000631A295F
I'm getting this error ("dazStudio.exe caused ACCESS_VIOLATION at 0033:00000000631A295F"). I re-installed daz and grapichs card driver multiple times. I've been working on it for several hours but no solution. You can see my logs attached. can you please help?
txt
txt
cloudLog.txt
600B
txt
txt
log.txt
853K
I seem to recall that this may be something to do with the GPU driver. There have been other threads on this
I Have read all of them usually the problem is causing from GPU Driver as you say, but in this case I've already re-installed and updated every driver but I Could'nt solve it. Any spesific solutions?
Is the Intel GPU the only one your system has, or do you also have a dedicated nVidia/AMD GPU? If you do have a dedicated GPU try telling DS to use that - I beleive you will find the option in the nVidoa or Catalyst Control Panel, the nVidia at least being accessible via a right-click on the desktop.
I Have GTX 1050ti and i5 7300hq. But I'm using 1050ti to open DS
The log file shows it as using the Intel chip.
